Old Fri, Dec-22-2017, 12:18:00 PM   #1
Default Obioban's Avin Avant 3 thread (eventually DIY to delete all stereo modules/harness)
I was debating putting this in the existing thread, but seems like it'll get lost in the shuffle... and this will be becoming a DIY to remove the stereo harness from the car completely, all stereo related modules, and replace their functionality with the Avant 3.
I'll tweak the thread title as that happens.
My goals for this project are:
-remove ~40 lbs of wiring/brackets/modules
-add GPS filtering to the V1 (via YaV1)
-bluetooth music streaming
-Waze on the main screen, for police locations and traffic avoidance without having my phone out
-Harry's GPS lap timer on track
-dash cam running full time when the car is on
-ability to pull/reset codes on the fly
In the short term, some pictures I took after wiring it up on my "test bench" (car battery with a trickle charger, connect to the unit) that I took last night. This weekend I'm looking to upload some videos of the interface, for those that are interested.
Right now, just some pictures of stuff I found cool in a couple minutes of fiddling:
Radio tuner interface-- supports RDS
Tire pressure/temp display, which you can use with TPMS sensors. Actually could be quite a useful track feature!
OBC functionality retained (and expanded)
Button backlighting can be tweaked, if you're not happy with the stock setting (I haven't compared it in a car yet, but from pictures I've seen of others I don't know if I'll feel the need to tweak it)
My super janky "test bench"
More to come/change in the coming days....
I'm super pleased with this thing so far. The button presses and knobs feel nice, it doesn't look cheap anywhere, and it's very much stock looking-- just with much more functionality. Can't wait to get it in the car!
Old Fri, Dec-22-2017, 12:18:44 PM   #2
Default Re: Obioban's Avin Avant 3 thread (eventually DIY to delete all stereo modules/harnes
Edit 7/5/18
Other than seats (and airbag-- waiting to make sure the steering wheel is straight to put that in), the car is finally back together. I'll be putting at least the driver seat in today or tomorrow.
This project spiraled WAY out of control. As in, I spent 100+ hours on this. I'm not going to say I'm glad I did it (sooooo much work), but I am going to say I'm super excited for the results!
In total, the project consisted of...
-remove all factory stereo modules, the stereo wiring harness, and all factory stereo mount brackets. Replace with Avin (which has all the stock module functionality built in) and make a new (tiny) wiring harness for the speakers, plugging them directly into the Avin
-do the above without altering the factory chassis harness at all. I did this entirely, 100% with the Avin only connecting to the chassis with the factory 7 pin chassis to stereo harness plug behind the dash. My goal here was to not have the chassis electronics be compromised in any way. This harness has everything you need for the Avin-- ibus, interior light dimming, ignition power, antenna power
-fuse all aftermarket electronic systems through new fuses in the factory fuse box. No vampire clips or inline fuses exist on my car any longer
-integrate aftermarket system functionality to factory buttons
-wrap all wiring bundles (OE and aftermarket) in OEM fabric tape, secure all wiring to the chassis with OE mounting hardware.
-relocate battery to the "drug bin" The idea here was that the 5.7 lithium polymer battery I'm running isn't meaningfully contributing to weight distribution, but the 8 lb battery cable that runs from the rear of the car to the front is making it heavier.
-relocate and downsize the washer tank to the drug bin. This car is no longer a DD, and never sees winter use, so I don't need anything like a full size washer tank... but I also don't want none, in a pinch. So, I have a ~1 pint tank in the drug bin now, as well. With the stock tank being in the front bumper, this should restore some of the 50/50 lost from not having a heavy battery in the trunk. It'll also make it easier to add brake ducting down the road.
And, add a ton of functionality via the Avin Avant 3, which is the first head unit that's look stock enough that I was comfortable running it in my car:
-CarPlay
-Waze
-YaV1 to add GPS filtering to the V1
-Extra gauges and code pulling on the fly via Torque
Some pics...
New, Harmon Kardon branding free, speaker covers
Increased trunk space carpeting (no door/rack for the CD changer/nav)
What's behind that carpeting now
Vs before (not my car)
New battery location, with the washer tank visible (pump not installed yet)
And in the area where the battery used to be installed, it turns out BMW makes a deeper storage bin! Key pictured for scale.
Some integrated bit….
Front fog light button is now brake light kills (cluster indicator still reminds me when this is on, stock functionality no longer required because I’ll be doing a CSL bumper)
Rear fog light button kills all reverse brake lights (with cluster indicator to remind me when this is on)
e39 high intensity wash button is wired up to activate M track mode (currently requires CSL/ZCP MK60 unit)
HK button is now Laser jammer power (retains memory of on/off from last drive, and power status light)
And the interior all back together, minus seats/airbag. Probably looks like nothing to most of you, but having been looking at chassis and wiring for the last couple months, this is like magic to me
I'm pretty pleased with the new, black gauge faces, too!
Huge thanks to Terra for dealing with my stream of conscious questions/thoughts/ramblings as I did this project
Old Fri, Dec-22-2017, 01:11:20 PM   #3
Chapelle
Chapelle's Avatar
Reputation: 0 Chapelle is on a distinguished road
Looking forward to see how this progresses. Iíve been on the fence on this upgrade, in lieu of all the other cool stuff on sale over the holidays.
Jump to top Chapelle is offline   Reply With Quote
Old Fri, Dec-22-2017, 02:12:27 PM   #4
KubinB
BMMMR
KubinB's Avatar
Reputation: 0 KubinB is on a distinguished road
So for your initial experience how responsive is the UI and how seamless is it opening/navigating through apps and features? has anything popped out to you as an annoyance or bug?
///M3 2002 TiAg / Imola 6MT
The Transformation
Jump to top KubinB is offline   Reply With Quote
Old Fri, Dec-22-2017, 04:07:39 PM   #5
Mr. Wolfe
Anti-Bling
Mr. Wolfe's Avatar
Can't wait to see a picture of the wires/weight removed. I am assuming you are going to weigh it?
Mr. Wolfe
1994 Porsche 911 Factory Widebody
Old Fri, Dec-22-2017, 04:25:51 PM   #6
BubbaTree
BubbaTree
Reputation: 0 BubbaTree is on a distinguished road
From what you have so far seen, will this unit show me the actual tire pressure per wheel on my 2003 M3?
Jump to top BubbaTree is offline   Reply With Quote
Old Fri, Dec-22-2017, 04:26:16 PM   #7
Mr. Wolfe
Of course
Though I've already lightened my stereo previously, so it won't be fully representative of the possible losses-- I'll add the previous weight savings, so people starting from stock can know what to expect.
I've only briefly played with it, but so far pretty seamless and bug free.
If you add TPMS sensors, yes. It can't pull that off our wheel speed sensors (which is what the stock TPMS works from)
Old Fri, Dec-22-2017, 04:47:11 PM   #8
Paulo M
Do these use same screen as factory?
In case they develop dead pixels (I’ve had to replace my factory ones twice bcs of that)
BREMBO APEX DIXIS
Old Fri, Dec-22-2017, 04:48:48 PM   #9
In case they develop dead pixels (Iíve had to replace my factory ones twice bcs of that)
No, they're not the same screen. No shared parts with OE Nav display-- just shared look.
Old Fri, Dec-22-2017, 05:25:59 PM   #10
Grayson777
Reputation: 0 Grayson777 is on a distinguished road
I can ask in another thread if this is too off topic, but what's the big difference between this and the N6 from Dynavin? Seems like this unit coming out finally is a pretty big deal for some of you guys and the N6 has been out for a good while and at a glance is very similar. Wondering if I'm missing something.
Jump to top Grayson777 is offline   Reply With Quote
Discussing Obioban's Avin Avant 3 thread (eventually DIY to delete all stereo modules/harness) in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
