Go Back   BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X) > M3Forum Marketplace > Cars for Sale/Wanted
Cars for Sale/Wanted Place to list your private cars for sale. ONLY BMW's.
Old Thu, Jul-13-2017, 12:56:54 AM   #1
jkreis
Reputation: 0 jkreis is on a distinguished road
Default FS: 2001 M3 Convertible 6MT, 126K New Clutch + $thousands more in RECENT Maintenance
Finally back from traveling for a month+ Have a new Cayman & fiancee, this NEEDS to go!
NEW Price $8,400 Slightly neg.
Please contact me directly at justin.kreis@gmail.com or 630-270-6555 as I don't monitor the forums.
2001 BMW M3 Convertible
Carbon Black/Grey
128,100
6 speed manual
All Stock except stereo & Angel eyes(disconnected currently)
Have most records(pdf of all maintenance and receipts for most parts and any shop work done as well as pics of vanos, timing work etc.)
Clean title
Never seen snow or salt
Stereo is a Eonon touch screen with components up front, Focal sub in the stock location & Directed amp. Installed so everything can go back to stock.
Highlights on recent and major maintenance.
10/2004 23,308 Rod bearing recall
4/4/14 78,050 Valve Adjustment
4/18/14 78,550 Radiator, Thermostat, Waterpump, Upper/Lower Hoses, temp sensor, Exp Tank
5/19/14 78,900 Beisan VANOS Rebuild (Seals, Rings, Oil pump disk, Solenoid pack)
5/19/14 78,900 Updated Cam Bolts and Cam Hub Bolts Installed with chain guide
5/20/14 78,900 FCABS replaced - Lemforder
5/20/14 78,900 Engine Mounts replaced - Lemforder
6/18/14 81,100 RTABS replaced - Powerflex Poly Bushings
7/10/14 82,250 Starter Replaced - Bosch
7/27/14 82,500 - Fuel Pump Replaced
- Front and Rear Shocks/Struts Replaced
1/25/16 101,500 -Alternator
2/14/16 -stereo
3/3/16- drivers side mirror glass replaced/mirror tightened
3/30/16 105,600 -cowl replacement; inner rear lights replaced
4/1/16 105,650 -review mirror repaired and replaced 1 yr warranty
4/22/16 106,900 -A/C Belt replaced
6/2/16 108,250 -Center support bearing & Gubio
6/5/16 -New emblems
6/8/16 -New center console
6/1/16 -Passenger sign mirror glass replaced/mirror tighten
8/1/16 -119,000 -Michelin Pilot Super Sport 225/45/18 & 255/40/18
9/9/16 - 119,500 -Akebono Euro Ceramic Pads & both pad level sensors
-Air Filter
2/2/17 - 120,100 -OEM front brake rotors
2/9/17 - 120,450 - LUK Oem Clutch/Flywheel kit installed(New Bolts, release fork & spring, Pivot Pin)
-Trans fluid change(Pentosin)
-Oil Change
-CPV replaced
-Exhaust Hanger
4/20/17 122,250 -New Headlight Lens & bulbs
5/17 -Cabin filter, OEM hood vent
6/19/17 -New amber corners, New drivers airbag(recall done), Liquid Moly 10-60 oil change, rebuilt starter with lifetime warrenty.
As you can see this car has been taken care of and I would feel confident to drive it anywhere. The air bag recall has been preformed per BMW(passenger & drivers), also where I found out about the rod bearings. Pulls very hard and sounds great doing it with a REAL 6 speed. It has ~6k miles on the brand new OEM clutch/trans fluid & oil change. The oil has been changed every 4500-5000 miles with either TWS 10-60 or Liqud Moly.
Cosmetically the paint has rock chips on the front & a few door dings throughout the body. The rear passenger side of the bumper has spider cracking in the paint and an indentation due to backing up into a pole, not bad, but there. The top is in great shape and goes up/down smoothly with no leaks. The drives seat is worn with a small tear on the bolster. The biggest issue with the car is the carpet under the drivers mat is cut. I have spent a lot of time and money cleaning this car up cosmetically and the paint has been polished, glazed, waxed and a sealant applied. I was also going to take it to get a professional buff and wax as they could do a better job than I, but the car still looks good. I do have another used skin with foam backing for the drivers seat that will go with the car.
The wheels are in good shape with a bit of driving wear and tear and 1 rear wheel having curb rash that goes around the whole wheel. The tires have about 7k miles on them. Michelin Pilot Super Sports in OEM sizes.
I am the 3rd owner and have records and spread sheet from the previous 2 owners as well from myself. I am an enthusiast and love driving this car. When it is not being driven it sits under a cover in my garage. I can give a more in depth explanation about the state of the car to anyone interested.
Currently has OEM 18" wheels with Michelin PSS. The grills are plasi-dipped black and I have the stock corner lights. It could be put back to 100% stock(minus the stereo) for the sale.
These pictures are from last fall when I put the car up for sale before the Clutch job. I no longer have the ZCP wheels that are pictured. The car sits on OEM 18" Style 67 wheels.
Miles are at 126,850 right now and will go up as it is my daily. LCD for miles is starting to fade can still see miles, Willing to go to dealer to have miles read.
http://imgur.com/a/Ksr0Y
This is how the car currently looks.
http://imgur.com/a/71bxh
Maintenance spread sheet up to my ownership.
http://imgur.com/a/vrUr0
Jump to top jkreis is offline
Rate Seller View Rating
Old Fri, Jul-14-2017, 03:57:10 PM   #2
jkreis
Default Re: FS:2001 M3 Convertible 6MT, Newer Clutch + $$thousands more in Maintenance done!
Bump tons of work, cheap M3 that you can drive and enjoy for a long time with just oil changes!
Jump to top jkreis is offline   Reply With Quote
Old Wed, Aug-16-2017, 05:26:54 PM   #3
RedOctober330
RedOctober330's Avatar
Reputation: 0 RedOctober330 is on a distinguished road
Default Re: FS: 2001 M3 Convertible 6MT, 126K New Clutch + $thousands more in RECENT Maintena
Location? Pics are dead.
Jump to top RedOctober330 is offline   Reply With Quote
Old Wed, Aug-16-2017, 05:47:21 PM   #4
jkreis
There was 1 dead link all the others work fine? Located in Nw burbs of Chicago
Old Wed, Aug-16-2017, 05:50:05 PM   #5
jkreis
Also Just replacing the fan & fan clutch they started to squeak to I just took care of it.
Old Mon, Sep-04-2017, 02:53:23 AM   #6
jkreis
Ok, Finally back from traveling for a month + I have a new Cayman & fiancee so I really need to get rid of this. Car drives great. 127,5xx miles. NEW price $8750 OBO-only slightly negotiable.
Old Fri, Sep-08-2017, 06:23:21 PM   #7
flipm3
E46 M3 | E90 M3
flipm3's Avatar
Reputation: 0 flipm3 is on a distinguished road
I've seen the car in person.
Very trust worthy individual.
Buy with confidence! Car is as advertised for a killer price.
2004 E46 M3 6MT | Silver Grey . Cloth | My E46 M3 Build Thread
2009 E90 M3 DCT | Melbourne Red . Speed Cloth | My E90 M3 Build Thread
2002 E46 M3 6MT | Jet Black . Black Nappa | My E46 M3 Build Thread
2016 981 Cayman 6MT | White . Black | Coming Soon
POST YOUR DYNO GRAPH HERE: The Official Dyno Thread
Jump to top flipm3 is offline   Reply With Quote
Old Fri, Sep-08-2017, 06:28:22 PM   #8
RedOctober330
For a 5spd Vert it's a smokin deal.
Old Mon, Sep-18-2017, 10:18:36 PM   #9
jkreis
@RedOctober330 - 6-Speed
@FlipM3 -Thanks!
Old Fri, Sep-29-2017, 01:53:18 AM   #10
jkreis
Bump price drop $8400! Miles now at 128,100
Discussing FS:2001 M3 Convertible 6MT, Newer Clutch + $$thousands more in Maintenance done! in the Cars for Sale/Wanted Forum - Place to list your private cars for sale. ONLY BMW's. at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
