Old Sat, Mar-18-2017, 07:05:03 PM   #1
Malloy
Reputation: 0 Malloy is on a distinguished road
Default Dimensions of OE Foam Supports/Shims for Front Bumper Bar
Photo: Braymond141
Does anyone have the dims of these 5 stock pieces?
I saw this thread but his dims are based on an aftermarket cover.
Any help is greatly appreciated as these are really hard to find.
Thanks!!
My OE Euro cover fits like a POS rep
Jump to top Malloy is offline   Reply With Quote
Old Sat, Mar-18-2017, 07:46:05 PM   #2
rpearl555
So Shiny So Chrome
Default Re: Dimensions of OE Foam Supports/Shims for Front Bumper Bar
Subscribed
Old Sat, Mar-18-2017, 08:51:02 PM   #3
FK
Sub'd. I need dis.
Old Sat, Mar-18-2017, 10:05:22 PM   #4
Malloy
FWIW: If I could get a complete set I'd probably be able to duplicate them for a pretty fair price.
Old Mon, May-01-2017, 03:12:56 AM   #5
WyattH
Bump .. can't find dimensions (height) for foam replacement ...
Old Mon, May-01-2017, 03:49:00 AM   #6
Hungry hippo
Reputation: 0 Hungry hippo is on a distinguished road
if someone can make these... ��
Jump to top Hungry hippo is offline   Reply With Quote
Old Mon, May-01-2017, 03:53:12 AM   #7
Kdubski
Kdubski's Avatar
Ironic that you post this literally a week after I followed that CSL shimming DIY.
I botched the cutting and the gluing. You can see where I had trouble under the driver side headlight. The real hard part for me is adjusting the bumper using the white mount behind the turn signal.
If you cut the foam straight and glue it down right, it should work fine. Use the old dried glue for reference of where to glue the new pieces. Also, be sure to use a glue that wont melt the foam. The big difference is, styrofoam is a lot softer compared to the OEM shims.
Old Mon, May-01-2017, 05:19:46 AM   #8
Malloy
FWIW: Skillzo provided shims that I will have scanned this week. My goal is to have pieces produced to OE spec. Material and completion date are TBD.
Old Mon, May-01-2017, 05:56:43 AM   #9
WyattH
If you had to guess, would it be more like 1mo or 6mo out?
I haven't found the shim thread but I did find this:
http://www.m3forum.net/m3forum/showthread.php?t=563198
Old Mon, May-01-2017, 01:26:51 PM   #10
FK
I have one week lmao.
Thanks Lloyd for donating to the cause!
Discussing Dimensions of OE Foam Supports/Shims for Front Bumper Bar in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
