Old Mon, Apr-14-2014, 03:17:50 PM   #1
Ujwal Velagapud
Reputation: 0 Ujwal Velagapud is on a distinguished road
Default Rotora BBK on my 02 M3
I just bought an 02 M3 and would like to put my Rotora BBK from my 04 Acura TL. I want to see if this is a universal kit, and I can pull it off the TL, and put it on the M3. Is it not compatible? Any fitment issues since the TL is FWD, and the M3 is RWD?
It is a 13" Rotora Big brake kit 4 piston with 2 piece Rotors. 330 mm
Drilled/slotted rear rotors
As I did not purchase the BBK for the TL, I am not sure of any additional information regarding the dimensions unless I pull it off the car.
Thanks in advance!
Jump to top Ujwal Velagapud is offline   Reply With Quote
Old Mon, Apr-14-2014, 04:51:28 PM   #2
TEASE///M3
TEASE///M3's Avatar
Reputation: 0 TEASE///M3 is on a distinguished road
Default Re: Rotora BBK on my 02 M3
Thanks in advance!
Check the brake bias between the M3 and the TL I'm sure they're no where near the same so it likely wouldn't be ideal. The brakes will clear the wheels and everything however you'd need to make new brackets for the calipers. In short, it's not really worth it, pull them, sell them, get one for the M3 and smile all the way home from the bank
Untitled by . McFarlin, on Flickr
2006 M3 ZCP Interlagos Blue Manual Cinnamon 6MT Slicktop
RIP 2002 M3 Tiag Dove Grey 6MT
Jump to top TEASE///M3 is offline   Reply With Quote
Old Mon, Apr-14-2014, 07:18:30 PM   #3
EYEHAVEYOU
Simon
EYEHAVEYOU's Avatar
I'm going to guess the bias is off, just given the fact that the TL is a FF car, and the M3 is FR. Hopefully someone more knowledgeable about brakes can come in and do the bias calculation.
bbk, caliper, piston, rotor, rotora
Discussing Rotora BBK on my 02 M3 in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
