Old Sun, Aug-05-2012, 05:14:46 AM   #1
M3novo
Reputation: 0 M3novo is on a distinguished road
Default how torque flywheel w/o lock
I am wondering if there is a way to torque the flywheel w/o tool to lock it in place.
Jump to top M3novo is offline   Reply With Quote
Old Sun, Aug-05-2012, 06:54:12 AM   #2
Taunto
Taunto's Avatar
Reputation: 0 Taunto is on a distinguished road
Default Re: how torque flywheel w/o lock
breaker bar ( or a long half in ratchet ) and the stocket to fit the crank bolt. Get someone to hold the ratchet or brace it to something when it turns while ur torqueing the flywheel.
* Technology is the Replacement for Displacement *
Jump to top Taunto is offline   Reply With Quote
Old Sun, Aug-05-2012, 08:40:40 AM   #3
VwAlex
Reputation: 0 VwAlex is on a distinguished road
Honnestly for flywheel, I usually do new bolts, red locktite and half inch impact in a star pattern twice. I know it's not rigth but it's never failed me before. Pressure plate however I use a calibrated torque wrench, new bolts, red loctite and if using a performance pressure plate 23ft-lbs.
I've done countless so far and this has proven the best method. Flywheel bolts arents half as important as pressure plate bolts.
Jump to top VwAlex is offline   Reply With Quote
Discussing how torque flywheel w/o lock in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
