Old Sat, Jul-14-2012, 02:20:49 PM   #1
E4603
Reputation: 0 E4603 is on a distinguished road
Default Multiple Cylinder Misfire-Help Needed
So I was driving home last night and while cruising at about 40mph, the car began to stutter and the SES light came on. Pulled out my scanner and the car gave me codes:
p0300- Random/Multiple misfires detected,
p0302- Cylinder 2 misfire detected
p0304- Cylinder 4 misfire detected
p0305- Cylinder 5 misfire detected
p1341- Multiple misfire with fuel cut-off
I am just beginning to try and diagnose this, and so far I have unplugged the MAF but that did not make it idle better. I have looked around the forum at other similar topics but have a hard time finding anything where anyone comes to a conclusion of what fixed the issue when they had it. Any help would be greatly appreciated.
CSL Replicas, Tein S-Techs.
Building a NEW M3 one misdiagnosis at a time.
Jump to top E4603 is offline   Reply With Quote
Old Sat, Jul-14-2012, 02:22:14 PM   #2
abakos
abakos's Avatar
Reputation: 0 abakos is on a distinguished road
Default Re: Multiple Cylinder Misfire-Help Needed
what coils are you running?
http://www.m3forum.net/m3forum//showthread.php?t=267154
-Aaron
2004 M3 - Coupe, 6spd, Silver Grey on Black
RAC RG63, PSS, ZCP Brakes, aFe, SS (V1, Res. X-pipe, Street Muffler), Epic Alpha-N, 319whp
2006 Jetta TDI/DSG, Pkg 2, Silver on Black - Sold
2004 M3 SMG - Silver Grey on Black, Convertible - RIP
1995 525I 5spd - Black on Black -Sold
2004 X3 3.0i AT- Blue on Tan - For the wife....
Jump to top abakos is offline   Reply With Quote
Old Sat, Jul-14-2012, 02:29:03 PM   #3
E4603
Coils are stock. Unfortunately since the car is an 03 I can't get it covered at the dealer. I wouldn't want to buy a bunch of new coils and have it not fix the issue. Is there a way to test if it is the coils before purchasing them to replace?
Old Sat, Jul-14-2012, 04:24:50 PM   #4
E4603
Changed the spark plugs this morning and that did not fix the issue either.
Old Sat, Jul-14-2012, 05:53:38 PM   #5
BezM3
Reputation: 0 BezM3 is on a distinguished road
Jersey
i would say to change the coils as this sounds like the problems with my 03 couple of months back which had the original stock ones in
IF ITS NOT SIDEWAYS..... YOUR NOT DRIVING IT PROPERLY!!!!
Jump to top BezM3 is offline   Reply With Quote
Old Sat, Jul-14-2012, 10:27:29 PM   #6
duracellttu
How many miles on the car? It could be the spark plugs, ignition coils, fuel injectors or fuel pump.
When was the last time you changed plugs and coils?
2005 BMW M3 ZCP - Black/Black 2M Autowerks Full Restoration: RKP CF Roof Conversion, OE CSL Trunk, JCSL Diffuser
Paul Claudes Custom Tune | Kassel Performance CSL ECU Conversion+MAP Sensor | Lang Stage Stage 2.5 Head | 288/280 Schrick Cams+DLC Coated Followers | CSL Karbonious Airbox+OE Snorkel | SS V1 Stepped+Catted Sec 1+Resonated Twin Pipe+Race | 3.91 w/ 3 stage clutch
TCK SA 450/500 | Vorshlag Camber Plates | Rogue Engineering ASP, RSM | AKG FCABs, RTABs, SFBs | TMS Sway Bars, Camber Arms, Pullies | Mason Race Strut, Rear X-Brace | AS 30% SSK | SPAL Fan | Redish Reinforcement | Turbo Toys V2 Hub | WPC Treated Rod Bearings
Old Sat, Jul-14-2012, 10:29:08 PM   #7
E4603
Did the plugs this morning, and working on getting coils to try replacements today. After some fishing around, I think coil pack 5 may not be on as I see no change in idle when I unplug it.
Old Sun, Jul-15-2012, 01:39:15 AM   #8
Taunto
Taunto's Avatar
Reputation: 0 Taunto is on a distinguished road
did u recently get fuel from a different service station than normal. Fuel filter been changed at all lately? sounds it could also be a problem with some bad fuel. If you start the car now does it still idle rough and throw codes? or did it only happen that one time on the drive home?
* Technology is the Replacement for Displacement *
Jump to top Taunto is offline   Reply With Quote
Old Sun, Jul-15-2012, 03:09:46 AM   #9
E4603
I replaced cylinder 5's coil pack and resolved the problem today. Very interesting that with one bad coil pack multiple cylinders will throw a code. For anyone who searches this issue and finds this thread, 1 coil pack can definitely solve this problem!
Old Mon, May-15-2017, 03:51:46 AM   #10
ultimateracer28
ultimateracer28's Avatar
Reputation: 0 ultimateracer28 is on a distinguished road
My 03 S54 lost all power from a dead miss on cylinder #3, come to find out later.
Codes:
P0300
P0301
P0303
P0304
P0305
AutoZone had a repop hecho en China Duralast for $62 in stock!
Down the road I go........
Jump to top ultimateracer28 is offline   Reply With Quote
Discussing Multiple Cylinder Misfire-Help Needed in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
