Old Tue, May-08-2012, 12:58:10 AM   #1
dhahlen
Reputation: 0 dhahlen is on a distinguished road
Default Misfires on 1, 3, 6 - Valve adjustment just done, can't figure it out
Valve adjustment just completed, car drives nice. However, I need to get emissions done and I keep throwing a CEL for misfires. Car is also supercharged with VF Stage 1.
I did see a code for the EGT this morning, but I cleared it (that's why it's not pictured).
I rather not spend $1000 to get this sorted out, but it's going that way....
List of things I'd like to replace to rule them out:
-All four o2 sensors ~$350-400
-Intake/Exhaust CPS ~$250
-EGT ~$175
-TPS
Things I've already done / replaced
-New bosch coils
-New Spark Plugs
-Oil Change
-Valve Adjustment
-New Injectors
-VF's Stage 1 MAF-less reflash
-Vacuum Tested
-Compression / Leak down
I've attached an idle data log, full data starts at line 57. Also see the attached video to see what my AFR is doing. Car is not fully warmed up.
The data log on 5-12-12 is while the car is warming up. It also has more data categories than the previous log.
" title="66a181fd.mp4 video by dhahlen - Photobucket" target="_blank">66a181fd.mp4 video by dhahlen - Photobucket
" title="1743c705.mp4 video by dhahlen - Photobucket" target="_blank">1743c705.mp4 video by dhahlen - Photobucket
Suggestions, please and thanks.
1993 GP220 RX-7 (sold, no more headaches!)
1996 EB M3 (sold to a friend)
2004 AW M3 (RIP)
2005 JB M3 (sold)
2007 SG 335i (wife's)
2002 911tt x50 (sold the BEAST)
1991 318is (daily)
2008 AW/FR M3 (sold)
2003 AW/IR M3 (sold to a friend)
2001 911tt Alpha 28s
2003 911tt Alpha 30s
2003 911 GT2
1993 LS2 RX-7
2007 911tt EFR7163
Jump to top dhahlen is offline   Reply With Quote
Old Tue, May-08-2012, 01:40:27 AM   #2
lorkar
Ulitimate Fahrmaschine Spezialist
lorkar's Avatar
Reputation: 0 lorkar is on a distinguished road
Norway
Default Re: Misfires on 1, 3, 6 - Valve adjustment just done, can't figure it out
-EGT ~$175
-TPS
-New bosch coils
-New Spark Plugs
-Oil Change
-Valve Adjustment
-New Injectors
-Vacuum Tested
How does it run? Do you feel the misfires? You changed the coils but it can still be coils. (I had to replace my bosche ones after just 40k) Can you pull up your fuel trims on Bavarian Tech? If you don't feel the misfires under load its likely not the coils. Possible lean misfires at idle. Since your Supercharged look for air getting in around your clamps. VF uses the hard plastic molded plenum and they often leak if not clamped well. Don't go changing parts yet.
19"SSR GT3s Satin finish,General UHPs, Eisenmann Race Exhaust, Sharked,CSL bumper, CSL diffuser,Depo smoked clears, Authentic ACS rear lip spoiler, Angel eyes.
Jump to top lorkar is offline   Reply With Quote
Old Tue, May-08-2012, 02:12:05 AM   #3
Taunto
Taunto's Avatar
Reputation: 0 Taunto is on a distinguished road
^ Like states above. Fuel trims would be a great thing for you to post up. maf readings, o2 sensor voltage readings, tps are tools that you can post.....(if the tool allows it) for us to help you diagnose the concern. Does the C.E.L come right back on if you clear the codes? if not, does it come on at idle, or cruising speed, accel,decel....
* Technology is the Replacement for Displacement *
Jump to top Taunto is offline   Reply With Quote
Old Tue, May-08-2012, 06:51:46 AM   #4
dhahlen
-smoke test was performed, car is not leaking air, everything tightened down pretty well
-coils have about 150 miles on them same with plugs
I believe I can pull fuel trim.
-Tune is mafless (i.e., doesn't use the maf, it uses an alpha-n tune)
I can pull o2 sensor voltages and I believe tps.
I'll gather all of this data tomorrow evening, if you have specifics on what you're looking for, please let me know. I'll graph out a few minutes of it idle and under load.
EDIT: Code reappears within a couple of minutes of clearing it, during idle.
2004 AW M3 (RIP)
2005 JB M3 (sold)
1991 318is (daily)
2003 911 GT2
1993 LS2 RX-7
2007 911tt EFR7163
Old Wed, May-09-2012, 06:00:27 AM   #5
dhahlen
no time to get data logs this evening, will try tomorrow ;/
Also replacing #12 on this diagram:
http://realoem.com/bmw/showparts.do?...10&hg=13&fg=15
The clip broke and it's zip tied to the rail temporarily. Buddy thinks a leak here could cause misfires under load. Part will be here Thursday/Friday. Anyone have thoughts on that?
2004 AW M3 (RIP)
2005 JB M3 (sold)
1991 318is (daily)
2003 911 GT2
1993 LS2 RX-7
2007 911tt EFR7163
Old Thu, May-10-2012, 07:48:55 AM   #6
Taunto
Taunto's Avatar
if im looking at the diagram correctly it seems to be a quick connector attaching to the fuel rail or from a fuel line? just a lil confused to where exactly im looking on the car. (when you smoke tested the vehicle where to you "T" into?
Awaiting on graphing results..
BTW i was thinking... have you looked at the exhaust tabs on your vanos lately? or done a cylinder leak down test?
Old Thu, May-10-2012, 02:22:52 PM   #7
deadlysyns
deadlysyns's Avatar
Reputation: 0 deadlysyns is on a distinguished road
make sure you push all your coils down
Jump to top deadlysyns is offline   Reply With Quote
Old Thu, May-10-2012, 03:11:25 PM   #8
dhahlen
Vanos was replaced roughly 20k ago. I am not throwing any vanos codes, exhaust or intake cps codes, so I'm not sure what to do?
Compression and leak down was done a week ago while I had it at the shop for the valve adjustment.
There is a rail to the right of the fuel rail if you're looking at the vehicle from the front. That T-line goes down to the ICV. The connector on that rail holds vacuum, if I pull it off while the car is running, the engine dies.
2004 AW M3 (RIP)
2005 JB M3 (sold)
1991 318is (daily)
2003 911 GT2
1993 LS2 RX-7
2007 911tt EFR7163
Old Thu, May-10-2012, 03:12:01 PM   #9
dhahlen
Checked and double checked.
2004 AW M3 (RIP)
2005 JB M3 (sold)
1991 318is (daily)
2003 911 GT2
1993 LS2 RX-7
2007 911tt EFR7163
Old Thu, May-10-2012, 03:13:38 PM   #10
dhahlen
Also note, the vacuum is a little odd when warming up. I did notice it sitting closer to 18inHg and being fairly stable.
2004 AW M3 (RIP)
2005 JB M3 (sold)
1991 318is (daily)
2003 911 GT2
1993 LS2 RX-7
2007 911tt EFR7163
Discussing Misfires on 1, 3, 6 - Valve adjustment just done, can't figure it out in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
