Old Sat, Dec-24-2011, 08:04:34 PM   #1
cornerjunkie
I wake up every morning and piss excellence.
cornerjunkie's Avatar
Reputation: 0 cornerjunkie is on a distinguished road
Exclamation Front suspension problem...
Recently I have been hearing some noise in my right front suspension. It sounded like there was something loose or a failed bushing. My car has Turner sways, PSS9's, and camber plates. I jacked the car up today to see if there was anything visual I could see that might be the issue. I notices that the bushing on my passenger side that holds the sway bar going through the middle of the car is gone and the bar is just floating. Jacked the driver side up and the bushing is there and there is no play in the bar.
Driver side:
Passenger side:
As you can see, there is nothing supporting the passenger side of the sway bar now. I haven't had the chance to take the splash pan off to see anymore. Does this look subframe related? or does the bushing just need to be replaced?
Any input would be appreciated, THANKS.
Merry Christmas to me
'02 DINAN M3-RIP
'03 Steel Gray M3
Jump to top cornerjunkie is offline   Reply With Quote
Old Sun, Dec-25-2011, 02:09:54 AM   #2
cornerjunkie
Anyone?
'02 DINAN M3-RIP
'03 Steel Gray M3
Old Sun, Dec-25-2011, 03:45:38 PM   #3
cntrvrsy
44
cntrvrsy's Avatar
United Nations
Default Re: Front suspension problem...
I don't even see the bushing on the passenger side
sig engineered by Fcukupayme
Jump to top cntrvrsy is offline   Reply With Quote
Old Sun, Dec-25-2011, 06:04:10 PM   #4
sicklyscott
Reputation: 0 sicklyscott is on a distinguished road
If the bracket is still there and solid just replace the bushing.
Jump to top sicklyscott is offline   Reply With Quote
Old Sun, Dec-25-2011, 06:21:47 PM   #5
Taunto
Taunto's Avatar
Reputation: 0 Taunto is on a distinguished road
ya them bushings are toast my friend. Like said above i also do not see the bushing on the passenger side but as long as the bracket is there new set of bushings will fix your concern.
ps...Dont want to sound rude or it could just be me... but DANG bro u got some long monkey fingers lol. maybe its just the camera but the finger on the 2nd picture looks almost broken... sorry its xmas hahaha
Jump to top Taunto is offline   Reply With Quote
Old Sun, Dec-25-2011, 06:58:00 PM   #6
grf
Reputation: 0 grf is on a distinguished road
Yep, bushings are shot/missing. Should get these from Turner as the bar diameter is probably different from stock.
Jump to top grf is offline   Reply With Quote
Old Sun, Dec-25-2011, 08:42:55 PM   #7
cornerjunkie
Yeah the passenger bushing is gone. I haven't had the time to drop the splash pan to see if the bracket is there. I read a thread that looked to have the same problem, the threads were ripped out of the bracket. Hopefully this isn't the case as he needed to get it welded and tapped for the fix.
And lol at the finger comment, it's mostly just the angle of the picture but I have broken that finger a few times...
'02 DINAN M3-RIP
'03 Steel Gray M3
Discussing Front suspension problem... in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
