Old Fri, Sep-30-2011, 01:21:22 AM   #1
Proskate81
Reputation: 0 Proskate81 is on a distinguished road
Default Seized Caliper or Time for New Brakes
I started hearing a scraping type noise coming from my rear right wheel a few nights ago. I haven't driven the car since.
Upon inspection, something is grinding against my rotor. The scratch is not deep, but I'm trying to determine if the problem is a seized caliper, I need new pads, or something else. I read other seized caliper posts and I did not experience any effects other than the noise... no vibrating or steering issues.
I am willing to rebuild the caliper if needbe, but don't want to go through that if the problem is a brake job. There looks to be a decent amount of pad left, but I'm not expert.
Has anybody experienced something like this?? Thanks for the help!
**Update**
We weren't able to get the calipers off entirely, but we were able to move them somewhat freely when loosening the 2 bolts holding them in. I looked down into the pads and didn't see anything unexpected. There wasn't much slack on the brake line to get the caliper the whole way off.
I put the caliper back on and hoped the noise would be gone. My buddy and I did a couple slow passes in my parking garage and the grinding is still there. It also looks like the outermost portion of the rotor is being scored now. See picture below. I alternated between brake and e-brake to see if there was a difference in grinding. It seemed like the grinding was worse when I was using the e-brake. Wtf would be hitting the rotor and causing this??
The rest is outside of my mechanical ability so I'm going to call my tech and see what he says/thinks.
_________________
Bogart
'04 Silver Gray M3
6MT - Dinan Exhaust - Tischer SSK - Alufelgen CS7 w 235/265 - Powerflex RTABs - CSL Rep Diffuser - 3M FXPM 30 - n'at
Jump to top Proskate81 is offline   Reply With Quote
Old Fri, Sep-30-2011, 01:24:04 AM   #2
m3 hal
Default Re: Seized Caliper or Time for New Brakes??
I'd take the pads out and inspect.
Old Fri, Sep-30-2011, 01:28:16 AM   #3
Proskate81
I assume it's pretty simple? I'll search on how to do it. I don't do much work myself on my car.
Knock on wood she hasn't needed much
_________________
Bogart
'04 Silver Gray M3
Old Fri, Sep-30-2011, 01:32:49 AM   #4
m3 hal
I'm not sure how comfortable you are with wrenching on cars but it's fairly easy to do. Check the madrussian m3 website for a DIY guide.
Old Fri, Sep-30-2011, 01:34:59 AM   #5
lmtfi
lmtfi's Avatar
It looks like you may have a foreign object jammed in there. You need to retract the piston and what whats going on.
Hard to be sure - but the rotor looks to be fairly scored.
Old Fri, Sep-30-2011, 01:41:50 AM   #6
greenhobby
greenhobby's Avatar
Reputation: 0 greenhobby is on a distinguished road
How many miles on it? Those aren't originals rotors are they? I just did a caliper rebuild and rotor/pad replacement. It was fairly easy with the right tools.
-gh
Jump to top greenhobby is offline   Reply With Quote
Old Fri, Sep-30-2011, 07:23:02 PM   #7
cducati
cducati's Avatar
Reputation: 0 cducati is on a distinguished road
-gh
This is a simple job and cheap.
You can also find rebuilt calipers for about $50 ($250 with no core)
Happened to me as well!
I rebuilt mine with a kit from Naps for $14
Jump to top cducati is offline   Reply With Quote
Old Fri, Sep-30-2011, 07:33:24 PM   #8
mpegripper
mpegripper's Avatar
United Kingdom
probably a pebble in there
Old Fri, Sep-30-2011, 08:35:28 PM   #9
Proskate81
I'm hoping that's the problem. The score in the rotors doesn't feel deep and hopefully won't affect anything other than the appearance.
-gh
I just hit 80K. They are not the original rotors, they are the Euro rotors. I've had them on for about 20K miles maybe.
I'm going to take the caliper off, see if there's something in there, and follow the DIYs to determine if the issue is a seized caliper. I don't really know how a seized caliper would cause the scratch in the rotor, but who knows.
_________________
Bogart
'04 Silver Gray M3
Old Fri, Sep-30-2011, 08:39:27 PM   #10
m3 hal
Just an opinion from sitting in my chair looking at the pics, but it seems very unlikely that the caliper is seized or otherwise at fault in this case.
brakes, caliper, rotor
Discussing Seized Caliper or Time for New Brakes in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
