Old Sat, Nov-17-2012, 08:20:16 PM   #21
jyi
jyi's Avatar
Reputation: 0 jyi is on a distinguished road
Default Re: oil drain plug spins free
Could someone link me to the exact part(s) I need from Time-Sert?
This just happened to me...
Jump to top jyi is offline   Reply With Quote
Old Sun, Nov-18-2012, 11:35:27 AM   #22
dafoe
dafoe's Avatar
I had sold mine with only one cert used, perhaps the guy I sold it to is done with it...
Here's the kit if not...
I got mine from this guy on Ebay.
http://www.ebay.com/itm/NEW-TIME-SER...E:L:OU:US:1123
Old Sun, Nov-18-2012, 04:45:51 PM   #23
jyi
jyi's Avatar
The drain bolts just keeps spinning in place!
I tried to pull on it with a vice grip while turning it... I tried prying it with a flathead while trying to back it out with the wrench... nothing is working. It just keeps spinning in place.
What are my options here!?
Old Sun, Nov-18-2012, 06:44:06 PM   #24
Tech1
Reputation: 0 Tech1 is on a distinguished road
You will have to drill it out. No other way around it.
Jump to top Tech1 is offline   Reply With Quote
Old Sun, Nov-18-2012, 07:30:34 PM   #25
OtisM3
Reputation: 0 OtisM3 is on a distinguished road
Same thing happened to me. Used a timesert to fix.
Jump to top OtisM3 is offline   Reply With Quote
Old Sun, Nov-18-2012, 09:21:05 PM   #26
dafoe
dafoe's Avatar
My buddy welded a bolt to the bottom of the drain plug, used vice grips and pulled down HARD and turned at the same time, it eventually came out.
When you get it out via drilling, or whatever, get about four or five quarts of cheap oil to drain out any possible metal shavings after the cert kit is installed.
Old Tue, May-24-2016, 01:37:26 AM   #27
Sh0ty
Reputation: 0 Sh0ty is on a distinguished road
Apologies to the board for raising this from the dead, however I seem to be experiencing a similar issue today on my S54.
I noticed that while re-installing my drain plug, it never seemed to fully tighten, and is just spinning indefinitely. From previous posts in this thread, I gather that the threads are not cut into the pan, but some threaded bung is welded to the interior of the pan. My guess is that I broke this weld. Does anyone happen to have a pan off their car to take a photo of that bung? I'd like to be able to see it before I make a decision regarding next steps.
Thanks in advance.
Jump to top Sh0ty is offline   Reply With Quote
Old Tue, May-24-2016, 06:45:32 AM   #28
DanAvoN7
Reputation: 0 DanAvoN7 is on a distinguished road
That is not correct. The threads are cut in to the pan itself. It is easy to strip the threads if the drain plug bolt is over-torqued.
04 BMW M3 6spd - Alpine White/Black
Apex ARC-8 w/ Hankook Z214, Apex ARC-8 w/ BFGoodrich R1, MCS 3-way Coilovers, GC Race Camber Plates, PFC BBK, Turner Camber Arms, Turner Sway Bars, Turner Subframe bushings, Turner Solid Diff Bushings, Turner Solid RTAB, Turner Solid Control Arm bushings, Treehouse Racing FCAB, Reinforced Subframe, OS Giken LSD, Rogue Engineering Transmission Mounts, SGT Headers, SGT Section 1, AFE Stage 2 Intake, EPIC Tune, Dinan Exhaust, Bimmerworld Airdam/Splitter/Dive Planes, Bimmerworld V2 Wing, TC Design Roll Cage, Racetech RT4119, Scroth Profi 2 Harness
NORCAL Rod Bearing/Vanos/Valve Adjustment/Inspections Member Feedback
Jump to top DanAvoN7 is offline   Reply With Quote
Old Tue, May-24-2016, 02:16:48 PM   #29
natethegreat
Reputation: 0 natethegreat is on a distinguished road
Originally Posted by dafoe View Post
Well... This sucks! Is the only fix to replace the whole dam pan? Dam magnetic plug!
SAME SAME SAME issue with me. Undid the plug and heard a crack. Plug came out and drained the oil. Went to thread back in and got to a point to where it just kept spinning. Plug is still like that till this day and just do oil changes currently through the dipstick. Does not leak thank god, but possibly a heli coil this winter.
So sad
2001 BMW M3 Steel Grey with LED Tails, Status Gruppe Catless Headers, AR20 Welded Section 1, Manzo Exhaust, Rouge Engineering Section 2 with QTP valve, Halos, EAS Filter and Silicon Elbow, VMR V703 CSL Replica Gunmetal Grey Rims, Michelin PSS tires, Stoptech rotors and pads, CSL one piece splitter.
Jump to top natethegreat is offline   Reply With Quote
Old Tue, May-24-2016, 05:42:27 PM   #30
Sandeep1212
Sandeep1212's Avatar
Reputation: 0 Sandeep1212 is on a distinguished road
So sad
Until one day it all comes out.
Just got to an indy and have them tap a new hole. Will not be more than a hundred bucks.
2003.5 TIAG Black 6MT Gone
2003.5 Carbon Black Laguna Seca Blue SMG Current
Supersprint V1/Supersprint straight pipe sec 1/ Supersprint X-pipe/OEM Muffler/Eventuri Intake/TCKline Single Adjustable 500lbs Front 600lbs Rear/TCKline Camber Plates/Turner Adjustable Rear Control Arm/Turner Monoball RTABs/Turner Monoball FCABS/ Whiteline Front Sway / Brembo GT 6 piston Front 4 Piston Rear/OEM CSL Trunk/ CSL rep 1 piece lip
Jump to top Sandeep1212 is online now   Reply With Quote
drain, free, oil, plug, spins
Discussing oil drain plug spins free in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
