Old Fri, Aug-21-2009, 05:32:09 PM   #21
See-Fu
Reputation: 0 See-Fu is on a distinguished road
yea 18mm works out good. when i'm on the square 18" oem setup, i use the spacer in the rear, and when i'm on the zcp, i move the spacer up front.
Jump to top See-Fu is offline   Reply With Quote
Old Fri, Aug-21-2009, 05:47:52 PM   #22
DOCTOR 3VIL
DOCTOR 3VIL's Avatar
Reputation: 0 DOCTOR 3VIL is on a distinguished road
Armenia
what no pictures
02 E46 M3 Jet Black
11 E92 M3 Le Mans Blue
Jump to top DOCTOR 3VIL is offline   Reply With Quote
Old Fri, Aug-21-2009, 06:53:18 PM   #23
FastM3CT
FastM3CT's Avatar
Reputation: 0 FastM3CT is on a distinguished road
You may want to run a 10mm in rear when you are running the ZCP setup to give the car nice balanced look.
Jump to top FastM3CT is offline   Reply With Quote
Old Fri, Aug-21-2009, 07:18:27 PM   #24
daytonaviolet
OEM CSL Whoore
daytonaviolet's Avatar
yea i saw that, but section "b" is changing. because the 380mm rotor pushes the caliper further out you have more clearance from the spokes.
gotcha but just as long as your running oem zcp's 8" with the 355mm, 4piston brembo.. i believe your fine with 15mm as we put that on fast eddies car like 3yrs ago. he had the identical setup your getting now. but yes, you can play it safe and just get the 18mm rather then the 15mm.
Tischer aka GetBmwParts
Old Fri, Aug-21-2009, 07:27:34 PM   #25
JYeo
JYeo's Avatar
Reputation: 0 JYeo is on a distinguished road
Originally Posted by daytonaviolet View Post
guys this has been discussed several times before. check out this link post #35
when using brembo 355mm or 380mm (4 piston)
csl wheels 8.5" require 10mm spacer
zcp wheels 8" require 15mm spacer
Thanks, great info here.
If this is true I think I'll just go 10 mm spacers all around!
E30 M3 - Stock
E46 M3 - Performance: -Dinan S1+- Dinan CAI, Dinan Throttle Bodies, Dinan Stage IV Software, Dinan Exhaust, Dinan Stage II JRZ Suspension, Dinan Front & Rear Tower Braces, Dinan SSK
Streamline Filter, OEM CSL Headers, OEM CSL Cats, OEM CSL Wheels, TCK Rear Shock Mounts
Aesthetics: Vorsteiner CSL Full CF Trunk, Vorsteiner CSL Full CF Diffuser, Vorsteiner CF Engine Cover, ACS Style CF Front Spoiler, CF Kidney Grills and Side Grills, CF Roundels, Black Roof (haha), Depo Smoked Corners, Dinan Pedal Set, Recaro Pole Positions w/ Suede.
Dyno: 300 rwhp
Wish List: 3.91..
Jump to top JYeo is offline   Reply With Quote
Old Fri, Aug-21-2009, 07:36:22 PM   #26
daytonaviolet
OEM CSL Whoore
yup.. im running 10mm on all 4 corners
Old Wed, Jun-22-2011, 10:50:46 AM   #27
Flow
Flow's Avatar
France
Default Re: 4 piston brembo caliper clearance & ZCP rims
Hi all!
I found this thread, but not the answer I was looking for, so let me dig it out a little.
My problem : I have a BMW Performance front BBK and ZCP OEM wheels. In order for the wheel to clear the caliped, I had to use 10mm spacers, but it barely clears it (maybe 1 - 2 mm).
I guess I can get a name card to fit between caliper & spokes, but nothing more.
Here is a picture of my setup :
Do you think a very tight clearing is enough? Or should I use wider spacers?
My biggest concern is that the rim is not completely stiff and that the caliper might extend because of heat.
Any input is appreciated!
2004 M3 TiAg / LSB SMG
Old Wed, Jun-22-2011, 01:30:37 PM   #28
vndkshn
Goin' crazy... wanna come?
Reputation: 0 vndkshn is on a distinguished road
Use an 18 or even 20... that way you know you clear AND it looks ALOT better.
2005 Interlagos Blue M3 - Cinammon Interior - ZCP - 6MT - Premium - HK Sound
Performance Mods: D/A Race Software, D/A VAC Lightweight UnderDrive Pulleys, Streamline Panel, Ceramic Coated Stainless headers, Race-cats, B&B Tri-Flow, Motons, Vorshlag plates, GC Adj. Rear Camber Arms, GC Race Hybrid FCAB, Powerflex RTABs, H-Sport Sways, GC adjustable endlinks, GSP Clutch Pedal, 40% Autosolutions SSK, Rogue Trans Mounts, PFC WC/GAC front brake kit, PFC-01s for the track.
Click Here for nightmare ECS story. - LOL, it was deleted, guess it shows the sponsors can get away with anything here.
Jump to top vndkshn is offline   Reply With Quote
brembo, caliper, calipers, clearance, piston, rims, zcp
Discussing 4 piston brembo caliper clearance & ZCP rims in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
