Old Tue, Jun-30-2009, 07:30:22 PM   #11
Mvez
RS-aholic
Mvez's Avatar
Reputation: 0 Mvez is on a distinguished road
Originally Posted by silber View Post
Bumping this thread. I did a three day event up at Grattan this past weekend and I am concerned about the oil temps that I saw. Water temps looked alright (slightly pegged above center), but the oil temp was borderline near 300 at the end of a 30 minute session -- definitely way beyond the 255F mark. Dropped significantly during a cool down lap. Ambient was around 90 for the weekend.
I rode in mmmpowr's car which was equipped with the Turner kit. I don't remember seeing anything above the 255F mark in his car. Maybe David will chime in here.
Just get the oil cooler...in the long term it's going to pay for itself. Drew has the machined-aluminum brackets at the shop, and he can save you a few bucks with his shop discount. I know you are driving hard, and when you have the oil cooler, you can redline all the time, never shortshift and you'll be hard pressed to get oil temps above the 255 dot.
I just did 3 days in 90+ temps, never shortshifted and my temps hung around the dot all weekend long (and that was with an oil level just below the max line, which is higher than I normally run, so my temps were higher than normal). When I run oil levels of about midway between min & max line, my temps usually run even lower......the S54 is VERY sensitive to oil levels, and affects temps greatly, even with upgraded capacity. So if you recently got an oil change, perhaps your oil level was a bit higher than normal. Drew overfilled my car recently at an oil change, and I made him drain some out...it makes a huge difference, even in street driving. I was able to tell he put more oil in than I liked just from seeing my normal operating temp from daily driving.
The devil's in the details.
'13 E92 M3 Coupe - Daily
'00 Miata - DE toy
'11 E92 M3 Coupe - track build starting
'12 Cayenne
'09 Ford F350 DRW - tow rig
Jump to top Mvez is offline   Reply With Quote
Old Tue, Jun-30-2009, 08:48:28 PM   #12
hogger453
hogger453's Avatar
Reputation: 0 hogger453 is on a distinguished road
Bulgaria
That's exactly what mine looked at BW in 108 degrees driving the car very hard.
Two possibilities exist:
Either we are alone in the universe or we are not.
Both are equally terrifying.
Arthur C. Clarke
Jump to top hogger453 is offline   Reply With Quote
Old Tue, Jun-30-2009, 09:19:26 PM   #13
TitSprinksMcGee
TitSprinksMcGee's Avatar
Reputation: 0 TitSprinksMcGee is on a distinguished road
This is very true. I had an oil leak repaired at the dealership and I noticed my temps were significantly higher as well. I checked the oil level and it was overflown. Had them drain some out and the temps went back to normal.
Originally Posted by LALaw View Post
OP has been surprised by everything that's happened since the 13th Amendment
Coming soon to a post near you.
Jump to top TitSprinksMcGee is offline   Reply With Quote
Old Tue, Jun-30-2009, 10:47:57 PM   #14
mmmpowr
mmmpowr's Avatar
Reputation: 0 mmmpowr is on a distinguished road
My oil temp was a tad below the 3/4 dot, but by the time I complete the cool down lap, it's basically back to the middle. As for coolent temp, it never went beyond the middle.
I suspect that M3Seeto's radiator itself is clogged with dirt and bug buildup. Last year, when I installed the TMS oil cooler, I also took out the radiator because I needed to replace the PS cooler line too and that required removing the radiator. So I took a hose and sprayed water from the backside out and it was pretty clogged with stuff.
David
2001 ///M3
OEM: 6-Speed | Titanium Silver Metallic | Imola Nappa Leather | Power Seat Package | Cold Weather Package | Width adj. front seat with lumbar | Xenon | Moonroof | In-dash CD | HK | BMW alarm | Univeral transceiver
Mods: OEM Strut brace | OEM 19" wheels (street) | RAC RS110 9.5"(f)/10"(r) wheels (track) | Brembo 355(f)/345(r) BBK | Motul RBF600brake fluid | ACS rear shock tower brace | D/A Race software | SS Stepped Headers/S-pipe/X-pipe w/resonator/Race muffler | RE pullies | aFe CAI stg1 | Bimmerworld intake elbow | Bimmerworld CF brake ducts | BMW Motorsport thermostat | TCK D/A coilovers w/#600(f)/#700(r) | GC camber/castor Race plate | Powerflex FCAB | GC front sway bar links | h-Sport sway bars | RE Tranny mounts | TCK RTAB | GC RLCA| TCK shock mounts | V-CSL CF trunk | V-CSL CF diffuser | McMahan 4pt rollbar | TMS oil cooler | RE Octane SSK
Jump to top mmmpowr is offline   Reply With Quote
Old Mon, Jul-06-2009, 04:52:59 PM   #15
silber
Reputation: 0 silber is on a distinguished road
Hey guys, I haven't had a chance to reply until now. I'm planning to pick up the Turner kit soon. Oil wasn't overfilled (I changed it and checked it before the event). I've also thought about throwing in the motorsport thermostat as I don't drive the car in the winter anyways. Something to ponder I guess.
Here's a short video of a couple laps at Grattan. I did get down to a 1:28.9 but the Chase Cam ran out of memory and I didn't realize it until I got home. There are several areas of improvement (particularly braking into turn 1, after the jump, the hairpin, and turn in for the blind turn before the main straight).
http://www.youtube.com/watch?v=zyNCsK5uk50
Jump to top silber is offline   Reply With Quote
Old Mon, Jul-06-2009, 05:05:52 PM   #16
NPalacioM3
NPalacioM3's Avatar
Reputation: 0 NPalacioM3 is on a distinguished road
Spain
Originally Posted by vndkshn View Post
I wish that was the max mine gets to......
+1. I would be happy to see those ranges.
Nick
Real race cars don't have roofs or fenders.
Jump to top NPalacioM3 is offline   Reply With Quote
Old Mon, Jul-06-2009, 07:21:16 PM   #17
PKumarM3
Reputation: 0 PKumarM3 is on a distinguished road
i learned a trick on cool down laps from Don Fields, MrMCar
i turn the defroster on and set it at 80F on full blast on my cool down lap
the oil temps come down considerably.
Jump to top PKumarM3 is offline   Reply With Quote
Old Fri, Jul-10-2009, 10:56:03 PM   #18
ninekrpm
TrakJunky
ninekrpm's Avatar
Reputation: 0 ninekrpm will become famous soon enough
RyanO is absolutely right...he knows as he had one of the best E46 M3's that he raced to win many races.
I have spent hours troubleshooting the water temp problems (search for my threads)
- new water pump (was not the issue
- motorpsort t-stat (POS gimmick)
- new oem radiator (was not the issue)
- new zionsville radiator (looks can kill)
and finally what fixed the issue was removal of the stupid factory aux fan in-front of the radiator and installing an electric fan...have never seen water temps above dead center...this includes driving in 95 plus degree temps...
my current setup does not include a factory aux fan, pointless clutch fan, oem radiator setup with (10% coolant, 2 bottles of water wetter and distilled water) and 2000 CFM electric SPAL fan.
this sub $200 setup can help you lower your water temps...period.
Jump to top ninekrpm is offline   Reply With Quote
Old Sat, Aug-29-2015, 08:26:33 PM   #19
bngl3rt
Reputation: 0 bngl3rt is on a distinguished road
Default Re: Trackday Temperature (oil+coolant)
Originally Posted by nolocontendere View Post
you might as well check your oil level to ensure it is midway between the min and max on the dipstick. excess oil will definitely cause increased oil temps.
Bump from the dead. Is this really advisable for tracked E46 M3s? Don't fill to the second dot?
Jump to top bngl3rt is offline   Reply With Quote
Old Sat, Aug-29-2015, 08:45:09 PM   #20
ML///M3
Sunday Drive NYC
ML///M3's Avatar
Reputation: 0 ML///M3 is on a distinguished road
False. Mine is filled to the top and my oil temps are stable at 240 on track (AiM solo ecu readings)
2005 /// M3 Coupe ZCP - Road & Track | BMWCCA Instructor
Jump to top ML///M3 is offline   Reply With Quote
coolant, oil, temperature, trackday
Oil temperature flyingmachine E46 M3 (2001-2006) 21 Wed, Oct-06-2010 02:54:11 AM
-coolant temperature removal-replacement- kewlwhip E46 M3 (2001-2006) 11 Wed, Mar-24-2010 03:29:10 AM
CHECK COOLANT...Coolant all over my oil pan...is this bad?? Master_Yoda E36 M3 (1992-1999) 15 Thu, Mar-29-2007 03:33:48 PM
Coolant Temperature Sensor GOALSTOPR E36 M3 (1992-1999) 17 Fri, Aug-18-2006 03:01:30 PM
oil temperature mm28 E46 M3 (2001-2006) 13 Fri, Apr-29-2005 03:27:55 AM
Discussing Trackday Temperature (oil+coolant) in the M3 Track: Racing and DE Forum - Best mod for speed is learning to get the most out of what you currently have. Tracks and DE's is the place to start! at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
