Old Sun, Mar-16-2014, 04:58:10 PM   #41
Mrmm3
Mrmm3's Avatar
Reputation: 0 Mrmm3 is on a distinguished road
Default Re: Trunk Handle Falling Off?
Originally Posted by bmwe46nyc View Post
'02 here and I just used bigger head screws, big enough to barely go inside holes and basically make a thread inside lid holes with the head. Its better than ever now =)
Hmmm ok, worth giving it a try... Do you remember what size head of the screws that you used was?
Jump to top Mrmm3 is offline   Reply With Quote
Old Sun, Mar-16-2014, 05:00:21 PM   #42
jpiazzam3
Reputation: 0 jpiazzam3 is on a distinguished road
http://www.m3forum.net/m3forum/showt...=326022&page=3 this is the fix I used it works awesome. No glue no nothing. (Bottom of the page)
Jump to top jpiazzam3 is offline   Reply With Quote
Old Sun, Mar-16-2014, 05:02:54 PM   #43
bmwe46nyc
Reputation: 0 bmwe46nyc is on a distinguished road
Just take the old ones and get some just a little bigger....I had a bunch of screws in toolbox and I just looked until I found correct size...
Jump to top bmwe46nyc is online now   Reply With Quote
Old Fri, Mar-28-2014, 07:26:43 PM   #44
Mrmm3
Mrmm3's Avatar
Figured out a fix and posted in my original thread...
http://www.m3forum.net/m3forum/showthread.php?t=467751
Old Fri, Mar-28-2014, 07:32:00 PM   #45
bmwJohhnyD
user formerly known as bmwbob
bmwJohhnyD's Avatar
United Nations
i have a new painted tiag silver trunk handle already ready to mount.
it is the older style short one.
come from 2002 m3
pm me for pricing!
Old Sun, Mar-30-2014, 02:33:18 PM   #46
Mrmm3
Mrmm3's Avatar
come from 2002 m3
pm me for pricing!
Thanks bmwbob, but the fix on my original handle from above seems to be working out so far. If I need to fully replace the handle at some point, will keep yours in mind
Old Fri, Apr-04-2014, 10:20:46 PM   #47
uscbeemerM3
uscbeemerM3's Avatar
Reputation: 0 uscbeemerM3 has disabled reputation
Same thing happened to my buddies 2003. Just close the trunk from the two handle grooves on the inside trunk liner.
Current Car; 2008 S63 AMG. Still active on m3f, benz forums are empty.
Sold to my cousin; 2005 SMG II. Imola Red Inside
Koni Yellow struts/shocks with stock springs. M Track Mode (with M Track Mode light in the cluster),
CSL factory software via autologic (launch control is at 4800rpm), genuine CSL sway bars; front (30.8mm/hollow/8lb) and rear (22.5mm/solid/8lb), brake light mod all LEDs enabled when braking.
Jump to top uscbeemerM3 is offline   Reply With Quote
Old Fri, Apr-04-2014, 11:52:26 PM   #48
Mrmm3
Mrmm3's Avatar
Thanks for the tip! Will do that or anything besides using the handle so I don't break it again lol
Old Sun, Apr-06-2014, 01:01:02 AM   #49
e30will
Reputation: 0 e30will has disabled reputation
I was able to separate the painted cover from the black inner part (which has the license plate lights, the ports for the mounting screws, and the trunk release button).
When you purchase the new trunk handle, the black inner part and the primed outer cover are separate. Take a look at the back of the cover to get an idea of how it clips/attaches to the inner black part. Then I used a blow dryer/heat gun to heat up the adhesive and then a small flathead screw driver to carefully pry at the various mounting points.
It took about an hour or so of fiddling around. I ended up using a dremal to cut away parts of the inner black handle where it clips to the cover to make it easier to separate.
Jump to top e30will is offline   Reply With Quote
falling, handle, trunk
CF trunk handle? EveRfLy E46 M3 (2001-2006) 4 Mon, Jul-21-2008 10:55:03 PM
WTB/WTT: Prefacelift Trunk Handle for my Facelift Handle! M3 Garage Queen Northeast 3 Fri, Apr-25-2008 11:16:41 AM
WTB: Carbon Black OEM Updated Look M3 Trunk (the one with the longer trunk handle) DrkMnX Parts for Sale/Wanted 20 Mon, Nov-12-2007 07:31:09 PM
What is the little handle in the trunk?? sjehrlich E46 M3 (2001-2006) 25 Fri, Dec-02-2005 10:05:41 PM
Trunk handle MEATBAG E46 M3 (2001-2006) 8 Sat, Jun-28-2003 02:31:42 AM
Discussing Trunk Handle Falling Off? in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
