Old Fri, Mar-21-2014, 06:30:07 AM   #61
deilenberger
deilenberger's Avatar
Default Re: 'Vert trunk latch problems?
Originally Posted by CabrilloM3 View Post
No no no, you ain't no Evel Knievel. See, the dealer parts guru scolded me and said that it was only dangerous to use these on the coupe as these specific trunk buffers are for 'verts only! I think I'll go back and ask for valve stem caps for a convertible. Maybe some floor mats too.
Love it..
  • 2011 Lexus RX-350. SWMBO's toy.
  • 2011 Porsche Cayenne Turbo, white/black.
  • 2009 Porsche Boxster, white/blue. My new toy..
Old Fri, Dec-12-2014, 05:17:38 AM   #62
BubbaTree
BubbaTree
Reputation: 0 BubbaTree is on a distinguished road
Since we're poking around in the trunk of these convertible cars, here's a related ( I think ) question. Both trunk lights in my '03 convertible are out. I've checked every fuse, every other light inside the car, brake lights, turn signals, back-up, etc, and they all work correctly. The trunk light bulbs are both OK as tested with my 12v charger. There is zero voltage at the mounting prongs for the trunk lights. I just changed the trunk lid latch, with microswitch, and wish I had my money back; lights still dead. Any help? Thanks!
Jump to top BubbaTree is offline   Reply With Quote
Old Fri, Dec-12-2014, 03:50:48 PM   #63
casper3t
casper3t's Avatar
Reputation: 0 casper3t is on a distinguished road
Have you check the wiring if there a break in it? one of my reverse light went out because one of the wire ripped coming from the car to the trunk.
'02 Euro Tuned ///M3 6spd Carbon Black cover with a layer of dust and Grey Int.
Jump to top casper3t is offline   Reply With Quote
Old Sat, Dec-13-2014, 01:31:44 AM   #64
BubbaTree
BubbaTree
I'll have a go at finding a frayed wire for those lights. I didn't mention earlier, but after replacing that latch/micro switch, I now have the dash light that indicates the trunk lid is open. For you guys who have replaced those bumpers with the new ejector version, did that fix the trunk lid open light? Thanks!
Here's an update on that trunk lid open light issue: turns out that the bottom part of that latch, the part that is not bolted to the trunk lid, is adjustable. With the trunk open, you're looking straight down into the stationary part of the latch. Pop out 2 plastic covers over the torx bolts, and you can adjust the latch up or down as needed. That's the good news; bad news is I still have no trunk lights! Can't find any frayed wiring; assuming the large brown wire in the harness is the ground. I've seen a posted fix where someone made a jumper wire to fix a bad ground. If you know where that post is located, I'd appreciate a note. Thanks!
Last edited by BubbaTree; Sat, Dec-13-2014 at 10:40:11 PM. Reason: Updated information
Old Tue, Dec-23-2014, 03:43:13 PM   #65
BubbaTree
BubbaTree
Not to drag this one out too much, but those trunk lights are still dead. Replaced the latch, old trunk lid bumpers with the new version, visually looked for a frayed wire, and no change. For you electrical guys, since all the other lights in the trunk work, i.e., stops, back ups, directionals, and they all share that big brown ground wire, would you suspect a bad ground is killing those 2 inside trunk lights? I can sometimes get my 12v test lamp to light by grounding it to the chassis, and probing the interior trunk light. Clues?
Thanks,
Steve
Old Wed, Dec-24-2014, 03:42:19 PM   #66
wjibby
wjibby's Avatar
Reputation: 0 wjibby is on a distinguished road
Thumbs up Re: Fixed it..
Originally Posted by deilenberger View Post
Got 2 of PN 51-24-8-137-994 (which was the part - PN-7 - I mentioned above on realoem.com) - cost was $9.30 each, $8.30 each with my CCA discount.
Unscrewed the old rubber bumpers, screwed these in - and it works great. Now when I pop the trunk, it pops up about 1/2" - and the latch fully releases.
I found a 21mm deep socket was ideal for removing the old one and installing the new ones - it had just enough grab on the rubber so they could be turned. I used a bit of GummiPhledge (silicone grease) on the threads on the new ones so they would go in easier.
Attached are photos..
The first photo is the new one on the left and one of the old ones on the right. The second photo is a new one installed in the trunk lid.
On a difficulty scale of 1-10, this is a 1..
Thanks for the post. This solves my problem also.....
A pleasure to drive and fun filled every day...
Jump to top wjibby is offline   Reply With Quote
Old Wed, Dec-24-2014, 07:30:14 PM   #67
Kansas Corey
Reputation: 0 Kansas Corey is on a distinguished road
Thanks,
Steve
BubbaTree,
For what it's worth, when I got my car (used) my interior rear trunk lights were intermittent at best. Most of the time they were out. When trying to diagnose similar to you, I "accidently" bump my hand into one of the lights and viola'... it turned on
Turns out that apparently with the way they clip in (at least mine) the connection isn't very good to the actual bulb holder. Previous owner had upgraded to newer LED light units but gave me the old incandescent units as well. For giggles, I tried pushing in the old unit and it fired up with no issues
Next step - swap back in the LED version and... drum roll please... no light...
Simple solution and explanation is the connection on the back of the new unit just wasn't making good contact with the connectors on the car. After a little fiddling, although I don't remember what I did exactly, the LED versions now light up as they should.
Jump to top Kansas Corey is offline   Reply With Quote
Old Wed, Dec-24-2014, 11:55:45 PM   #68
BubbaTree
BubbaTree
If this post doesn't show clearly on your monitor, it's because of all the egg I have all over my face. Finally took the advice everyone had been offering, and opened that wire loom from the chassis to the trunk lid. To no one's surprise except mine, the hot wire to those interior trunk lights was completely broken. Touched one end to the other, and I have lights! I'll fix that as soon as I finish eating this load of humble pie! Thanks to all for your help and patience!
Steve
latch, problems, trunk, vert
FIXED: Water in Trunk on a Vert! VMen E46 M3 (2001-2006) 6 Sat, Dec-13-2008 10:17:04 PM
Trunk latch recall? notopM3 E36 M3 (1992-1999) 1 Fri, Aug-29-2008 03:59:28 PM
Wtb: Oem Vert Trunk JOHNNYBEGOOD Parts for Sale/Wanted 11 Wed, Jun-04-2008 08:03:56 PM
Trunk help...vert if that matters IDM3 E46 M3 (2001-2006) 10 Fri, Mar-28-2008 02:56:47 AM
trunk latch and cruise control M3 Cougar E46 M3 (2001-2006) 1 Thu, Dec-30-2004 11:56:05 AM
Discussing 'Vert trunk latch problems? in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
