Old Wed, Oct-27-2010, 05:49:34 PM   #21
M///Fanatic
M///Fanatic's Avatar
Reputation: 0 M///Fanatic is on a distinguished road
Originally Posted by OahuMPower View Post
1) are you doing this on the car?
2) did u ever take apart the caliper?
3) how are you trying to push the piston back into the caliper?
1) Yes, I unbolted the caliper and opened the bleeder bolt and attempted to compress with a c clamp.
2) Not completely no.
3) With a c clamp
Jump to top M///Fanatic is offline   Reply With Quote
Old Wed, Oct-27-2010, 06:37:28 PM   #22
epj3
Reputation: 0 epj3 is on a distinguished road
Originally Posted by Roland H View Post
If it doesn't pull when driving or braking.... It could possibly be the guide bushings.
I rebuilt all four of my calipers, put on new pads and rotors, and they started squeeling terribly after bed-in. I couldn't figure it out until looked and saw that the pad was only touching the outside edges of the rotor... Just ordered some solid guide bushings from TMS, if that doesn't do the trick, I'm getting a BBK, but I doubt that these won't fix my issue.
If they aren't touching using the stock guides, the solid guide bushings will only make it worse. Did you use new pads after the rebuild? Likely the pad material had wear patterns from before the rebuild. When I went from solid guide bushings back to stock, my brakes squealed for at least 4 months.
Jump to top epj3 is offline   Reply With Quote
Old Thu, Oct-28-2010, 12:30:47 AM   #23
WRXEATR
The Frugal and Outspoken One
Reputation: 0 WRXEATR is on a distinguished road
3) With a c clamp
If you cannot get the piston in with a C clamp with the bleeder even open, something is seized up pretty bad. Your piston seal may have rolled over or you may just have some bad corrosion in there. I would advise to pull the calipers and rebuild them. If the pistons have ANY corrosion on them at all, get some new SS ones.
Jump to top WRXEATR is offline   Reply With Quote
Old Thu, Oct-28-2010, 03:52:38 AM   #24
Agree with this and I'm betting it's heavily rusted given the location.
Who is supplying replacement pistons other than BMW currently?
Old Thu, Oct-28-2010, 03:57:25 AM   #25
WRXEATR
For the stainless, they are made by a company I believe that goes by the name of Stomskie Racing
http://store.bimmerworld.com/stainle...tons-p755.aspx
....and how do I get my hands on some of these BMW supplied pistons?
I wasn't aware they were available
brake, caliper, clogged, line, seized
Brake line nuts are seized...NEED HELP!!! pininfarina1960 E36 M3 (1992-1999) 13 Tue, Jun-24-2008 05:17:06 PM
Brake caliper froze benz4matik E46 M3 (2001-2006) 12 Fri, Jul-20-2007 02:26:31 PM
Brake caliper maintainence... Greek Bastard Jr Off Topic 0 Sun, Jun-25-2006 11:14:41 PM
***Rotora Full Line of Big Brake & Caliper Kits @ Custom Performance*** Custom Performance Parts for Sale/Wanted 23 Mon, Mar-13-2006 07:51:08 PM
Painted Brake Caliper??? MMMMMM 3 E36 M3 (1992-1999) 2 Sun, May-15-2005 11:48:25 PM
Discussing seized caliper or clogged brake line? in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
