Old Tue, Dec-17-2019, 07:26:40 PM   #111
Default Re: Seeking Help: VANOS Timing
Yeah, but I feel like frequently heating up small somewhat slippery pieces of metal to red hot (i.e >500șC) is drastically increasing the chance of personal injury for minimal gain. I currently have no leaks, and I've never bothered annealing a washer.
That, and the time it takes to go heat a stupid washer easily outweighs just pulling a 0.10 cent copper washer out of a pack.
I too have a pack of copper washers from Amazon/ China
Old Wed, Dec-18-2019, 02:46:45 AM   #112
jbfrancis3
Reputation: 0 jbfrancis3 is on a distinguished road
Two developments tonight:
1) I measured valve clearances before removing the cams, per sapote's helpful comment. For the 2 cylinders in which the cams were not on-lobe (ish), both the intake and exhaust were in spec, surprisingly. No intake valve (4 measured) was more than 0.009" and the exhausts (4 measured) were right at 0.012". Like I said, this was spot-checking 2 cylinders on each cam (they were the same 2 cylinders obviously) as I had already removed the hubs and did not want to spend time locking the cams to the sprockets which would have been required to spin the engine. The leakdown test of all cylinders will be the best test for me.
2) I compared the Cat cams to the stock cams by doing the following (w/ pics):
- the cam bridge pin is 6mm. Amazingly, I had a screw driver with a shaft that was exactly 6mm.
- The screwdriver afforded me the extra length to align both cams together.
- I put the intake signal disk on the Cat cam intake first. Took a picture of it laying flat on the table and noted location relative to flat surface of table (see next post)
- I put transferred the intake signal disk to the stock cam. Picture in same location (see next post)
- I repeated the procedure with both exhaust cams (see next post)
'05 M3 Convertible 6MT, Carbon Black/Cinnamon, Karbonius CSL Airbox, OEM Flap, Kassel CSL Conversion w/ Kassel MAP Sensor, Schrick 288/280 w/ DLC rockers, CPI Single Stepped Headers, KW Variant 2.
Jump to top jbfrancis3 is online now   Reply With Quote
Old Wed, Dec-18-2019, 02:52:11 AM   #113
When held like that, does to tooth to align the timing wheel match up on both cams?
Old Wed, Dec-18-2019, 02:54:53 AM   #114
jbfrancis3
The reference photos of the signal disks in the following order:
Photo 1: Cat cam intake
Photo 2: Stock cam intake
Photo 3: Cat cam exhaust
Photo 4: Stock cam exhaust
What do folks think about the comparisons? To me, the intake cams do NOT match but the exhaust cams do match.
(I couldn't easily rotate the photos with the upload feature but doesn't really change the story)
Old Wed, Dec-18-2019, 03:02:25 AM   #115
jbfrancis3
Markings on the Cat cams if anyone is curious.
Old Wed, Dec-18-2019, 03:06:40 AM   #116
If the camera is flat each time, I agree the intake cams seem to be different. Hard to say for sure though.
Old Wed, Dec-18-2019, 06:52:49 AM   #117
sapote
Reputation: 0 sapote is on a distinguished road
For a good comparison, lay the sensor wheel on a flat block, and a vise to hold the pin screwdriver vertical (jaws opening line along the cam length), such that the cam is horizontal or near to. Pic of each wheel on the flat block reference will give a clear comparison without the need to set the camera flat.
Jump to top sapote is online now   Reply With Quote
Old Wed, Dec-18-2019, 07:04:39 AM   #118
sapote
In the pictures if both cams were slotted together with screwdriver then the code wheels referenced to the flat glass table surface should be enough. Are the code wheels photos posted Upside down? Definitely wheels are not at same position.
Ignore my suggestion using the vise if the above assumption is true.
Old Wed, Dec-18-2019, 07:11:32 AM   #119
sapote
From the pic, Cat cam code wheel will cause cam angle readings more retarded than it should be.
Old Wed, Dec-18-2019, 07:16:45 AM   #120
sapote
So, either wheel key or the bridge pin hole was wrongly indexed on the Cat cam. Strong evidence to ask manufacturer for compression.
Discussing Seeking Help: VANOS Timing in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
