Old Mon, Dec-16-2019, 08:40:33 PM   #21
Default Re: Burbles/Flames- harmful to motor?
Let's make a flamethrower out of the combustion chamber burning everything in sight starting with the valves/headers/cats/etc, what can go wrong. (I know you are catless).
By asking LONG TERM, you want to have fun with it and flip the car to the next owner in case something does go wrong?
Cars and coffee, here I come.
'04 S2000
All DIY: VANOS, WPC rod bearings, full SS (SS stepped V1 headers, catted S1, resonated S2, SS sport), AFD E85 Proflex kit, Ohlins R&T/Hyperco 375f Swift 672r/GC street tops and camber plates, ST40 355 pfc08, 330 ZHP steering rack, diffsonline 4.1 diff with rem polish, E60 short shifter lever, AKG black diff bushings/subframe bushings, Rogue rtab, Sachs clutch/flywheel, rear main, Beyer driveshaft, valve adjustment, cooling refresh.
Old Mon, Dec-16-2019, 08:42:59 PM   #22
Originally Posted by Sandeep1212 View Post
I sounded like sh1t before they started putting it on new cars.
Anti lag is the only time I want to hear something similar.
Hyundai did that stock with the Veloster N - kinda cool
Old Mon, Dec-16-2019, 08:45:25 PM   #23
New cars all having artificial burble/pop stock has taken away an desire I might have ever had for it.
That, and my S54 pops and burbles a *lot* just stock with a modified exhaust. I've shot a bit of flame on high RPM upshifts with the bimmerworld street/ track exhaust.. hard to imagine how much fuel they're dumping to make it happen all the time
Old Mon, Dec-16-2019, 09:03:00 PM   #24
HassanEido
HassanEido's Avatar
Lebanon
It's probably running a bit rich up top to do that
Sent from my JKM-LX1 using Tapatalk
PM for performance tune requests
Mods:
-Custom CF airbox
-Cat Cams 280 272.
-Custom dyno tune
385.7 whp 288 wtq
Old Mon, Dec-16-2019, 09:35:28 PM   #25
Bimmerman325i
Beardface McMountainMan
Bimmerman325i's Avatar
Reputation: 0 Bimmerman325i is on a distinguished road
I greatly enjoy my SS burbling and popping from the factory. But it's a V8 and is to be expected.
I also very much do not want my S54 to sound like that, as I don't want to encourage the gremlins.
1995 BMW M3/2/5-- S54/Mk60 California Smog Legal (Build Thread)
2017 Chevrolet SS, 6MT -- DD with burbly murrca
Jump to top Bimmerman325i is offline   Reply With Quote
Old Mon, Dec-16-2019, 10:57:22 PM   #26
umichchris
Reputation: 0 umichchris is on a distinguished road
ive got it on mind. i went with the mildest option BuildJournal offers. i love it. but, its a weekend car that i don't daily drive so it would be a long time before i could speak on long-term effects.
i think its fine...any modification comes with risk. if you want to be 100% safe then leave it all stock, anything beyond that...you are taking risk.
Jump to top umichchris is offline   Reply With Quote
Old Mon, Dec-16-2019, 11:32:28 PM   #27
HassanEido
HassanEido's Avatar
Lebanon
Tuning isn't taking a risk. There are things that are genuinely harmful.
This essentially combusts fuel in your exhaust ports /headers instead of inside in the cylinders. This will torch your exhaust valves and jack up the temps on 1 side of ur engine head(uneven heating).
Putting aside the potential head gasket issues, if it's a catted car, this will kill the cats.
O2s, wide bands and narrow bands, wont last etc.. Not to mention that this wastes fuel... To each their own, but those are the cons.
Mods:
-Custom CF airbox
-Cat Cams 280 272.
-Custom dyno tune
385.7 whp 288 wtq
Old Tue, Dec-17-2019, 12:24:35 AM   #28
umichchris
Ok...
Old Tue, Dec-17-2019, 02:59:15 PM   #29
Kurty
Reputation: 0 Kurty is on a distinguished road
It's not even burble, it's just makes a tin can pop. Doesn't sound cool like those open wastegate 335s. I've tried it to hear it. At the most aggressive setting it just makes a high pitch pop.
Jump to top Kurty is offline   Reply With Quote
Old Tue, Dec-17-2019, 03:23:48 PM   #30
New cars have made it so lame that I want to not have it even before there's any engine damage.
FS: Intravee and various compatible AI Net components.
Discussing Burbles/Flames- harmful to motor? in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
