Go Back   BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X) > M3Forum Marketplace > Parts for Sale/Wanted
Parts for Sale/Wanted Post your Parts Wanted, and non commercial bmw related items for sale. We ask that companies selling goods become a Sponsor to advertise your goods.
Old Tue, May-28-2019, 05:01:35 AM   #1
.'s Avatar
Reputation: 0 . is on a distinguished road
Default Clutch Masters FX725 Twin Disc Clutch Kit and Hydraulic Release Bearing
Up for sale is my used Clutch masters FX725 twin disc kit (03040-TD7S-A) and hydraulic release bearing (N03040-H). The whole kit is in great condition, has about 25k street miles that are mostly highway on it so it has lots of life left in the clutch discs. Replacement discs are about ~$300 for both from CM if you wanted a basically new setup at a fraction of the cost. Includes all hardware including shim kit for the release bearing though it's already properly spaced for this setup saving you that process. Asking $SOLD for everything. this would run you close to 2k new so this is a well of a deal.
More information on the clutch kit and release bearing can be found here:
https://www.bimmerworld.com/Clutch-M...40-TD7S-A.html
http://www.clutchmasters.com/n03040-h-bmw-e46/
2001 E46 M3 - Slicktop Manual Coupe - Alpine White on Imola Red
Engine: Karbonius CSL airbox, Lang Racing stage 2.5 head, Schrick 288/280 cams & followers, Lang Racing rod journal widening kit w/ CP 12:1 87.5mm pistons & Carrillo rods, Kassel CSL DME & MAP conversion, 36lb injectors, Hassan tuned, APE Flex fuel kit, TMS Power Pulleys, SS V1 stepped headers & catless section 1, SS 2.5” twin-piped resonated section 2, SGT scza section 3.
Drivetrain: DKM Stage 2 Clutch, E60 Shifter, RE trans mounts, Motorsport 4.10 R&P, Revshift 80A diff bushings.
Suspension/Brakes: Ohlins 3DM “track day” kit, RE strut bar, AKG RSM's, UUC front sway bar, BW camber arms, TMS monoball RTABs, ZCP rotors, BW solid caliper guide bushings, PFC 08's, Motorsport Hardware stud kit.
Interior: Cobra Nogaro seats, alcantara headliner, BMW Performance pedals, OE alcantara boots, mason clutch pedal, Xtrons 9" headunit w/ carplay
IG: Zach_e46M
Jump to top . is online now
Rate Seller View Rating
Old Wed, May-29-2019, 02:05:15 PM   #2
WALKD_U
WALKD_U's Avatar
Reputation: 0 WALKD_U is on a distinguished road
Default Re: Clutch Masters FX725 Twin Disc Clutch Kit and Hydraulic Release Bearing
Would you sell the bearing only?
Rides:
2005 AW/IR M3
BMB Stage 4
940whp/765wtq SAE Corrected
1996 BLU/BLK M3
NA Bolt-ons
235whp/225wtq SAE Corrected
Instagram:
M3HNGRY
EURO.techniks
<a href=https://www.instagram.com/m3hngry/ target=_blank>M3HNGRY</a>
Jump to top WALKD_U is offline   Reply With Quote
Old Wed, May-29-2019, 02:14:42 PM   #3
kokgo20
kokgo20's Avatar
Reputation: 0 kokgo20 is on a distinguished road
Was this installed on SMG or MT?
Assuming the bearing was used instead of the clutch fork?
Any chatter with this setup?
Build thread---------- INSTAGRAM ------------ROTREX REBUILD-------------Now offering custom digital gauges
2004 SMG PY/BLK - 600 TCKline - CPI Headers & resonated Sec1- Stoptech BBK 6 pod front & 4 pod rear with steel lines - 75mm Studs conversion - SDW monoball RTABs - AKG subframe bushings - Multi color AEs - FR-X 3.0 Projectors - Smoked Side markers - Euro bumper - V1 with hard wire & Stealth one - M Track Mod - ZCP steering rack - Dual LI - CSL Style diffuser - SCZA Exhaust - E9x Door handle LED retrofit - SCZA CSL bootlid - VEI systems custom air vent A/F & boost gauge - VEI custom air vent Water temp & oil pressure guage- Active Prima plus + HTE performance tune - Custome fab intercooler - Mishimoto Radiator & Oil cooler - H&R front Sway - UUC camber arms - keyless & push to start system - clear bra - interiors red stitching contrast - Apex PS7s - 16" Spal fan
Jump to top kokgo20 is online now   Reply With Quote
Old Wed, May-29-2019, 02:58:23 PM   #4
empty
Can this work for SMG?
Old Wed, May-29-2019, 04:40:13 PM   #5
.'s Avatar
Thanks for the interest guys but it’s now sold.
IG: Zach_e46M
Jump to top . is online now   Reply With Quote
Discussing Clutch Masters FX725 Twin Disc Clutch Kit and Hydraulic Release Bearing in the Parts for Sale/Wanted Forum - Post your Parts Wanted, and non commercial bmw related items for sale. We ask that companies selling goods become a Sponsor to advertise your goods. at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
