Old Sat, Apr-20-2019, 06:02:25 PM   #681
gearhead55
gearhead55's Avatar
Reputation: 0 gearhead55 is on a distinguished road
Default Re: FCM E46 M3 Ride Harmonizer suspension spreadsheet (bounce freqs, FRC, roll stiffn
Update on my set up:
Installed my MCS 1WNR dampers with 448/840 springs. 27mm front bar on stiff with no rear bar. Iíve only just started playing with adjustment but right out of the box the dampers are amazing. This set up is a major improvement over the bilsteins with the progressive springs. The spring rates are definitely not too stiff and so far Iím pretty comfortable saying I could go higher and still utilize it as a daily driver. I can feel the flat ride working and that effect increases with speed (as predicted with the low % of flat ride). The dampers can be set up as a true coilover so I may try a 448/448 true coilover set up next, which would give me slightly higher flat ride percentage and bring the optimized speed down closer to highway speeds. No canyon runs yet but hopefully Iíll be able to get a feel for the cornering capabilities today or tomorrow.
Originally Posted by Serious View Post
nah this one dude on the forum said it was all good. I'm sure he knows what he's talking about.
Jump to top gearhead55 is offline   Reply With Quote
Old Sat, Apr-20-2019, 06:04:28 PM   #682
Kwakjoe
Kwakjoe's Avatar
Reputation: 0 Kwakjoe is on a distinguished road
What compression/rebound settings are you guys running? I ran fairly soft 3/8 clicks for compression and 1 full turn for rebound on my TCK DA's. The car was extremely oversteery on track. Once I bumped the compression up to 6/8 up front and 5/8 in the rear, it felt a lot better, but still not quite as balanced as I'd like.
My set up 392/750 with turner front set on medium. FRC 73.2% and 6% flat ride.
Jump to top Kwakjoe is offline   Reply With Quote
Old Sat, Apr-20-2019, 09:05:14 PM   #683
I wish the TCKs would offer a coil over rear. Their opinion is the beehive spring is just as good.
Iíd love to do a rear coil over so I can run an adjustable link in place of the upper control arm...save another 5 lbs! :lol
Old Sat, Apr-20-2019, 09:07:54 PM   #684
Iím right in the middle on both and my car is pretty close to where I want it. I have 450/400 fr and 700 rears, OEM front bar and no rear bar. Iím thinking about going higher in the rear but I want to talk to TC Kline first and get their thoughts. Sucks...I lose the beehive so Iíll have to get an articulating perch.
Old Sat, Apr-20-2019, 09:09:16 PM   #685
Kwakjoe
Kwakjoe's Avatar
Originally Posted by bigjae1976 View Post
I’m right in the middle on both and my car is pretty close to where I want it. I have 450/400 fr and 700 rears, OEM front bar and no rear bar. I’m thinking about going higher in the rear but I want to talk to TC Kline first and get their thoughts. Sucks...I lose the beehive so I’ll have to get an articulating perch.
so 4/8 clicks and 1.5 turns? Mine had to get revalved to handle 750+
Old Sat, Apr-20-2019, 09:24:12 PM   #686
gearhead55
gearhead55's Avatar
Yea, functionally Iím sure the beehive is just as good. The only downsides are the lack of rate options and the spring being too tall depending on how low you want to run.
I think user Obeewon on here was planning on using a true coilover and an adjustable upper arm replacement but I donít know if he ever got around to it.
Old Sat, Apr-20-2019, 09:35:21 PM   #687
empty
Where are adjustable upper arms available?
Thx
Old Sat, Apr-20-2019, 10:01:55 PM   #688
Thx
Just use a lower arm.
Old Sat, Apr-20-2019, 11:21:21 PM   #689
01M3Fan
01M3Fan's Avatar
Reputation: 0 01M3Fan is on a distinguished road
Does anyone know if the TCK beehive rear springs can be used with RE articulated spring perches or will I have to get the TCK height adjusters?
My build journal and mod list:
http://www.m3forum.net/m3forum/showthread.php?t=542798
Jump to top 01M3Fan is offline   Reply With Quote
Old Sun, Apr-21-2019, 01:29:09 AM   #690
I think both are 60mm, so would be fine.
/// 2004 SilberGrau M3 Coupe 6MT slicktop zero options ~3100lbs JOURNAL
Evolve-R Alpha N Evolve CF CSL Airbox Eventuri Scoop Supersprint V1 stepped 2.5" SS V1 2.5" sect 1 OE sect 2 SCZA 2.5" sect 3 Besian RE pulleys/fan delete CSL battery
Bilstein HD B6 + GroundControl/Eibach 325/550lb + GC "tall" RSMs Hotchkis front sway F & R strut bars TMS camber & subframe plates Eibach alu rear camber arms RE trans mounts AKG poly subf/diff 95a SDW RTAB OE weighted ///M knob + ZHP alcantara boot + UUC DSSR
OE CSL trunk Cobra Nogaros + BK + manual OE bases TMS black pedals Sportline 8S 18"x 8.5/9.5" MPSS 245/275 APEX 75mm Studs Brembo 996 4 pot 345mm CSL + Textar & 328mm CSL + ATE ZHP "712" rack
DD: 2012 TiAg/Blk 128i N52 ULEV Slicktop 6MT manual heated seats
Eibach springs & sways Koni STR.T Whiteline SF bushes Dinan camber plates M3 FCAs
Discussing FCM E46 M3 Ride Harmonizer suspension spreadsheet (bounce freqs, FRC, roll stiffness) in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
