Old Mon, Feb-25-2019, 06:06:54 PM   #511
TheGenius46M
TheGenius46M's Avatar
Reputation: 0 TheGenius46M is on a distinguished road
Default Re: FCM E46 M3 Ride Harmonizer suspension spreadsheet (bounce freqs, FRC, roll stiffn
Running into a slight dilemma here as I am looking to move from 750F 850R to 425F 850R to give me the ideal flat ride I am seeking based on the spreadsheet. Issue I'm hearing I could be facing would be with the 425 front springs in 7."
I am looking to run 18x10 +33 265/35/18 for track wheels and have heard that the 7" spring may pose some fitment issues.
Can a 6" spring be run with 425 lb spring without compromise (I'm pretty low) or will there not be enough travel for that rate?
I need to know like asap because the wheels I'm ordering from bimmerworld are only on sale through Thursday lol.
2003 E46 M3 TiAg/Cinnamon 6MT
Purchased: 11/13 with 58k miles
Karbonius | MCS | Volk | Recaro | OMP | Hyperco | Ground Control | Besian | AKG | Schroth | Bimmerworld | Turner | PFC | CSF | SuperSprint | Radium Engineering |
Bay Area/ Nor Cal Coding and DME Tuning Specialist. PM for inquiries.
My Build Thread | My Build Journal | Instagram:@thegenius46m
Jump to top TheGenius46M is offline   Reply With Quote
Old Mon, Feb-25-2019, 06:19:42 PM   #512
As long as you have room on the body for the collar to adjust upwards, I don't see why you couldn't run a 6" spring?
/// 2004 SilberGrau M3 · Coupe · 6MT · slicktop · zero options · ~3100lbs · JOURNAL
Evolve-R Alpha N · Evolve CF CSL Airbox · Eventuri Scoop · Supersprint V1 stepped 2.5" · SS V1 2.5" sect 1 · OE sect 2 · SCZA 2.5" sect 3 · Besian · RE pulleys/fan delete · CSL battery
Bilstein HD B6 + GroundControl/Eibach 325/550lb + GC "tall" RSMs · Hotchkis front sway · F & R strut bars · TMS camber & subframe plates · Eibach alu rear camber arms · RE trans mounts · AKG poly subf/diff 95a · SDW RTAB · OE weighted ///M knob + ZHP alcantara boot + UUC DSSR
OE CSL trunk · Cobra Nogaros + BK + manual OE bases · TMS black pedals · Sportline 8S 18"x 8.5/9.5" · MPSS 245/275 · APEX 75mm Studs · Brembo 996 4 pot 345mm CSL + Textar & 328mm CSL + ATE · ZHP "712" rack
DD: 2012 TiAg/Blk 128i · N52 · ULEV · Slicktop · 6MT · manual heated seats
Eibach springs & sways · Koni STR.T · Whiteline SF bushes · Dinan camber plates · M3 FCAs
Old Mon, Feb-25-2019, 06:25:50 PM   #513
Spring should have a usable stroke listed on their spec page. You need need enough usable stroke so that you can bottom out your shock without running out. Anythi ng beyond that is useless.
How far that is depends on spring rate, ride height, shock design, etc/
Example of stroke listing:
FS: Intravee and various compatible AI Net components.
Old Mon, Feb-25-2019, 06:43:32 PM   #514
TheGenius46M
So here is what Swift’s chart is approximating for 448 (closest to 425 I can find)
And here is what Shaik’s calculator shows for travel:
I should be fine right? Also want to make sure I don’t run into any issues with the shock bottoming out or having too much travel to cause the wheel to hit the fender on dips, etc.
Old Mon, Feb-25-2019, 07:00:26 PM   #515
Swift springs tend to have more usable stroke that other springs of the same length. I'd find the specs for the springs you're actually running.
Old Mon, Feb-25-2019, 07:14:11 PM   #516
TheGenius46M
Planning to run hyperco 425 6” 2.25ID but can’t seem to find a similar table on their website with the relevant info unless I’m blind and someone else can find that info? Lol. Would appreciate it.
Old Mon, Feb-25-2019, 07:27:13 PM   #517
Might be OT but is it possible to convert a TC Kline strut to a 2.25” spring?
Old Mon, Feb-25-2019, 07:41:49 PM   #518
empty
^ should be if it will accept a standard bilstein 2.25” spring perch
Old Mon, Feb-25-2019, 08:01:09 PM   #519
I'd give them a call or shoot them an email, asking. You should have usable stroke >= metal to metal travel of your shocks + spring preload distance (or minus helper spring covered distance when in full droop, if you have them).
Old Wed, Feb-27-2019, 09:10:42 PM   #520
M3 dude
Reputation: 0 M3 dude is on a distinguished road
you *might* struggle.
if we assume a useable shock stroke of 120mm, ~4.5"
-you'll have 2" of droop
-2.5" of bump.
(some shocks have way more droop, but we're limited by bump travel)
a 400-450 spring compresses almost 2" when loaded on the front of a std weight m3 - basically the spring is fully captive but unloaded at full droop.
Jump to top M3 dude is offline   Reply With Quote
Discussing FCM E46 M3 Ride Harmonizer suspension spreadsheet (bounce freqs, FRC, roll stiffness) in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
