Old Thu, Jun-28-2012, 04:14:44 AM   #1
Steezy
Reputation: 0 Steezy is on a distinguished road
Default Is this healthy for an M3 (SMG)
I've been wanting to get this answer for a while, just never got the time...
Let's say I'm on the highway, on 6th gear with an M3 E46 (SMG), would it hurt the transmission if I downshift all the way to 3rd gear (pushing the left paddle 3 times quickly), then gunning it? Also, do I have to take my foot of the pedal while downshifting/upshifting?
Thanks for the feedback; just wanted to clear this up;.
Jump to top Steezy is offline   Reply With Quote
Old Thu, Jun-28-2012, 04:24:26 AM   #2
itzjohnnynguy3n
itzjohnnynguy3n's Avatar
Reputation: 0 itzjohnnynguy3n is on a distinguished road
Default Re: Is this healthy for an M3 (SMG)
a good habbit of mine is to release the pedal when i shift. computers are computers, it's good to ease off the pedal when shifting. I also see no harm shifting 6 to 3 and gunning it... i do it all the time hahah and it's fun. at 119k miles, still original clutch, smg tranny, and pump.
- 02 bmw m3
- 05 Viper srt
Jump to top itzjohnnynguy3n is offline   Reply With Quote
Old Thu, Jun-28-2012, 04:35:37 AM   #3
digger2
Reputation: 0 digger2 is on a distinguished road
you do not need to lift. The computer will cut the gas and spark etc. Plus it will also stop you from over revving if the shift is unsafe
Jump to top digger2 is offline   Reply With Quote
Old Thu, Jun-28-2012, 05:15:08 AM   #4
Foo2rama
2004 E46 M3
Foo2rama's Avatar
Reputation: 0 Foo2rama is on a distinguished road
Generally speaking the SMG will not let you damage the engine or gearbox...
That being said if you lift on WOT shifts or do other violent things... you can increase the wear and tear on your car which can lead to premature wear and tear on bushings, tranny/engine mounts, guibo, diff mounts, diff or subframe failure (rare).
2004 Mystic Blau Imola Rot ///M3 Coupe Manual converted from SMG in Dec 2017
Jump to top Foo2rama is offline   Reply With Quote
Old Thu, Jun-28-2012, 05:31:22 AM   #5
Taunto
Taunto's Avatar
Reputation: 0 Taunto is on a distinguished road
like stated above u dont not need to lift when shifting. This information is also available to you in your Owners Manual
* Technology is the Replacement for Displacement *
Jump to top Taunto is offline   Reply With Quote
Old Thu, Jun-28-2012, 05:31:46 AM   #6
Steezy
Okay, thanks, so I DON'T need to lift the pedal off. Now, what about dropping it from 6 to third? (Pressing the left paddle 3 times quickly, and gunning it...) Is that safe to do?
Old Thu, Jun-28-2012, 07:16:39 AM   #7
M3ANMACHINE
@coleslawjay
M3ANMACHINE's Avatar
Reputation: 0 M3ANMACHINE can only hope to improve
Depends on what speed you're going...
2011 E90///M3 | Space Grey | Fox Red | DCT | ZCP | Slicktop
APEX | BIMMERWORLD | COBY WHEEL | CORSA | H&R | MACHT SCHNELL | PEDALHAUS | RECARO
2014 F15 X5 | Space Grey | M-Sport
Jump to top M3ANMACHINE is offline   Reply With Quote
Old Thu, Jun-28-2012, 07:17:25 AM   #8
NICKBRUM
NICKBRUM's Avatar
Reputation: 0 NICKBRUM is on a distinguished road
Why would you assume its unsafe? If dumping it to third still allows for safe engine rpm, I see no problem. I do it all the the time anywhere between 70-80 MPH. Would you hesitate to do it in a MT????? Remember the SMG is the same gear box.
Drive a Prius, I need your gas!
Current: 2006 silver gray on black SMG ZCP.
|Style 219M Wheels| ST40 X 355mm BBK Front & Rear|GC coilovers 440/550lbs| Rougue RSM|
|Ceramic coated Euro headers|Custom 200 cell section one|TTFS|
Previous: 2004 silver gray on black SMG. TOTALED..
|SG type intake|AA GEN3|Victory UDP|HPF Reinforcement|PF subframe bushings|Rtab limiters|
|AC strutbrace|Eibach/Koni's|CSL SMG Flash|PFC DD|
Jump to top NICKBRUM is offline   Reply With Quote
Old Thu, Jun-28-2012, 07:34:43 AM   #9
rdoebel
///M Power
rdoebel's Avatar
Reputation: 0 rdoebel is on a distinguished road
Well in an SMG if he's going too fast (fast enough that the RPMs in 3rd are redline) the car simply won't go into 3rd.
I say if the transmission lets you do it, there's no problem. (I love dropping into 3rd for dat acceleration)
'03 BMW M3///SMG///Carbon Black: Khoalty|Stoptech|Status Gruppe
Jump to top rdoebel is offline   Reply With Quote
Old Thu, Jun-28-2012, 07:39:14 AM   #10
see.m3.go
see.m3.go's Avatar
Reputation: 0 see.m3.go is on a distinguished road
Not harmful for the tranny at all, it is the same transmission as the 6MT.
2003 TiAg/Imola SMG to 6MT: AST 4100, Vorshlag Camber Plates, Status Gruppe Headers, Status Gruppe Muffler, Recaro SPG, VAC Floor Mounts, TiAg Kirk Roll bar, G-force 6pt Harnesses, Evolve Tune, TMS Power Pullies, AKG DTM Shifter, Macht Schnell Stage 1 Intake, Hardwired V1, MH Stud Conversion, APEX ARC-8, AKG 75D Subframe Bushings, 95A Diff Bushings, BMW Motorsport 4.10 diff
My Journal
Jump to top see.m3.go is online now   Reply With Quote
Discussing Is this healthy for an M3 (SMG) in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
