Old Thu, Apr-14-2011, 06:40:56 AM   #1
motomo
Reputation: 0 motomo is on a distinguished road
Default Bleeding Brakes
Over the past two evenings, i installed the Bimmerworld SS brake lines and bled the brakes and clutch on my M3, but I have a few questions.
1. According to the madrussian guide, bleeding the brakes and clutch will use 1.5L of fluid, but I used less then 1L. Did I not do it enough? The fluid in the car was Amber, and i put in ATE Superblue, and each corner clearly had blue fluid coming through.
2. The car was not running while bleeding. Just read a thread talking about having the car running while doing bleeding, should I bleed again with the car running?
3. Pretty sure that I didn't have the cap on the master cylinder while bleeding one corner, does that make a difference?
Jump to top motomo is offline   Reply With Quote
Old Thu, Apr-14-2011, 06:55:20 AM   #2
vtn86
Reputation: 0 vtn86 is on a distinguished road
Default Re: Bleeding Brakes
1. It's just for reference. As long as there's no air and the fluid is swapped, you're set.
2. Car does not need to be on.
3. Doesn't matter as long as you didn't introduce air into the system.
Jump to top vtn86 is offline   Reply With Quote
Old Thu, Apr-14-2011, 06:58:35 AM   #3
Taunto
Taunto's Avatar
Reputation: 0 Taunto is on a distinguished road
Cant get any much simplier than that. As long as you have no leaks, and your brake pedal isnt soft or doesnt go right to the floor each and evey time, life is good.
Jump to top Taunto is offline   Reply With Quote
Old Thu, Apr-14-2011, 08:46:26 AM   #4
ImTooLazy
Reputation: 0 ImTooLazy is on a distinguished road
Just make sure to avoid air bubles.
Jump to top ImTooLazy is offline   Reply With Quote
Old Thu, Apr-14-2011, 01:15:26 PM   #5
VPM3
Reputation: 0 VPM3 is on a distinguished road
Iv never heard of anyone running the car while bleeding the brakes. Remember start bleeding from farthest from the master cylinder. Dont forget the clutch
Jump to top VPM3 is offline   Reply With Quote
Old Thu, Apr-14-2011, 03:39:32 PM   #6
motomo
What i had read about running the car while bleeding brakes was that it would activate the ABS and get more fluid squeezed out from it. If it's nothing to worry about, then i won't worry about it. I haven't driven the car yet to tell how the pedal response is yet, so that will be the real test.
Old Thu, Apr-14-2011, 05:16:45 PM   #7
tjpatte
Reputation: 0 tjpatte is a jewel in the rough
Tap the calipers with a rubber mallet as you bleed them to dislodge and air bubbles. Since you replaced the lines you pushed a decent amount of air through the calipers and sometime the bubbles like to stick in there.
2004 Mystic Blue M3
Jump to top tjpatte is offline   Reply With Quote
Old Thu, Apr-14-2011, 05:17:32 PM   #8
mredwin25
mredwin25's Avatar
Reputation: 0 mredwin25 is on a distinguished road
To bleed the abs you'll need to activate it with a gt1. No need to do that
E90 Jerez M3
335i Vert
Jump to top mredwin25 is offline   Reply With Quote
Old Thu, Apr-14-2011, 07:17:57 PM   #9
e4604
e4604's Avatar
Reputation: 0 e4604 is on a distinguished road
Sorry to threadjack but is it recommended that I bleed clutch after replacing a caliper?
Jump to top e4604 is offline   Reply With Quote
Old Thu, Apr-14-2011, 07:27:17 PM   #10
mredwin25
mredwin25's Avatar
Yes all the lines should be bled
E90 Jerez M3
335i Vert
Discussing Bleeding Brakes in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
