Old Sat, May-12-2018, 04:54:49 PM   #1
nholmes
Track Junky
nholmes's Avatar
Thumbs down New Plugs + New Coilpacks = Rough Cold Idle?
Hey collective wisdom, I'm trying to find out what's up with my car and I wanted to see if the community might have some insight that can help.
I don't know if it's the plugs, the coilpacks or the ASC silicone elbow I installed all at the same time. I verified each plug was gapped to 0.32 prior to installation.
Car is a stock S52 motor, no tune with an intake, ASC silicone elbow, Dinan TB and Bimmerworld catless race exhaust.
Prior to installing new plugs and coilpacks, the car never had any issues with these mods and idling while cold. Now when I start the car it almost wants to die, the motor really shudders until I blip the throttle once or twice. It eventually recovers after a minute and then starts to equalize. I also can confirm with INPA that there is no knock. I connected my laptop to the car while starting and idling and everything looks good. No codes and the car has seen four drive cycles now since installation. I also did reset the DME adaptations following the installation of the parts.
At the advice of a friend, I opted to remove the OEM Bosch coilpacks and keep them as back-ups since I've been told they are known to fail on these cars. Because I didn't know the history of the plugs I decided to change them since I was going to be "in there anyway."
Here's what was in there prior, I have no idea is these are the right plugs or what for this car:
My engine knowledge is fairly limited since this is a hobby, but white is typically a leaner a/f mixture - right? Not that I'm worried.
After poking around, I found these NGK plugs to be a suitable OEM replacement. BKR6EGP
Does anyone have any comments on these? I don't think my car warrants a colder plug or anything or even fancy plugs. Stock photo because I don't have any pictures of them but this is what I purchased:
For the coil packs I went with the Delphi brands as it was reasonably priced, included boots and had a history of reliability.
So, I'm not sure what to do next.
I guess I could re-install the ASC throttle body and see if that makes a difference. I could also put the Bosch coilpacks back in. The old plugs are done, I tossed them not thinking there was a chance I might need them again.
Any help/tips/advice is appreciated!
Follow my build thread here:
Old Sat, May-12-2018, 05:08:32 PM   #2
NolliM3
NolliM3's Avatar
Default Re: New Plugs + New Coilpacks = Rough Cold Idle?
I am leaning towards the hose from the idle control valve to the elbow...I bet there's a crack by the elbow.
Old Sat, May-12-2018, 05:08:42 PM   #3
nholmes
Track Junky
nholmes's Avatar
One thing Iím going to investigate is if air is getting past the clamps holding the ASC elbow to the back of the MAF and the TB. Air getting in there might mess with the air/fuel mixture since the DME canít account for that additional airflow coming in behind the MAF.
Old Sat, May-12-2018, 05:09:27 PM   #4
nholmes
Track Junky
nholmes's Avatar
I will check that, thank you.
Old Sat, May-12-2018, 06:06:48 PM   #5
I would try the original coil packs.
Old Sat, May-12-2018, 06:54:48 PM   #6
T3AMFiSh
Your mom goes to college
T3AMFiSh's Avatar
check the plugs for any cracks in the porcelin,
Old Sat, May-12-2018, 08:48:41 PM   #7
nholmes
Track Junky
nholmes's Avatar
Thanks for the ideas, I’ll try these
Old Sat, May-12-2018, 08:59:51 PM   #8
englishtom1596q
englishtom1596q's Avatar
I would look for cracks in the IAC tube as they’re known to crack and cause this exact issue. Mine didn’t have idle issues by when I pulled the tube it was severely cracked. Maybe yours was the same and installing the elbow opened the cracks up to leak. After that I’d install old coils. Delphi is a decent company but they also have bad coils and sensors out of the box sometimes
Old Sun, May-13-2018, 09:11:52 PM   #9
nholmes
Track Junky
nholmes's Avatar
Cool. I’ll have to follow-up this evening
Old Tue, May-15-2018, 05:33:16 AM   #10
nholmes
Track Junky
nholmes's Avatar
Looks like it's the ACS delete elbow.
I put the ASC throttle body back in and the cold idle issues went away.
Probably air getting in behind the MAF somewhere.
Stay tuned
Discussing New Plugs + New Coilpacks = Rough Cold Idle? in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
