Old Tue, May-08-2018, 03:35:27 PM   #11
SQ13
Default Re: Top speed?
You guys underestimate the capabilities of my E36
Old Tue, May-08-2018, 04:23:29 PM   #12
englishtom1596q
englishtom1596q's Avatar
Which is obviously not “stock.” A “stock” m3 cannot do that from the factory
Old Tue, May-08-2018, 04:41:32 PM   #13
Texaz3
I think we know what a STOCK E36 is capable of.
Old Tue, May-08-2018, 05:07:33 PM   #14
LateBraking
LateBraking's Avatar
Reputation: 0 LateBraking is on a distinguished road
I hit 88 miles per hour then my car disappeared.
One of the common failings among honorable people is a failure to appreciate how thoroughly dishonorable some other people can be, and how dangerous it is to trust them. ― Thomas Sowell
Jump to top LateBraking is online now   Reply With Quote
Old Tue, May-08-2018, 05:22:34 PM   #15
Play with the gearing calculator.
http://diffsonline.com/images/GearingCalculator.xls
Plug in your diff and tires. Use 5th gear 1:1 if you have a 5 speed ZF or Getrag.
Old Tue, May-08-2018, 05:54:21 PM   #16
The stock ecu controlled speed limit is 223km/h or 138mph.
I've gone to gear limited 3.23 + 310z when supercharged. It was really fun having the bypass valve blow off on the boost side at that speed.
Old Tue, May-08-2018, 08:29:54 PM   #17
bluptgm3
Default Top speed?
Stock - 137mph by ECU limit, 142 mph gear limited redline with ECU speed limit removed.
Old Tue, May-08-2018, 09:21:47 PM   #18
That is incorrect. Gear limitation is right around edit: ~160mph @7k rpm with a 3.23 and 310/320z 5-speed. Most speed limit removal tunes increase rpm to 7k, and many go to 7200rpm. BMW isn't going to a put a 4mph speed cap on a "142mph" gear limitation...
Old Tue, May-08-2018, 09:32:58 PM   #19
TheJDub-E36
TheJDub-E36's Avatar
Reputation: 0 TheJDub-E36 is on a distinguished road
That is incorrect. Gear limitation is right around 165mph @7k rpm with a 3.23 and 310/320z 5-speed. Most speed limit removal tunes increase rpm to 7k, and many go to 7200rpm. BMW isn't going to a put a 4mph speed cap on a "142mph" gear limitation...
That’s very accurate to my real time speed, I wasn’t using GPS or anything fancy so who knows what I actually was doing but the analog gauge looked like 156
Jump to top TheJDub-E36 is offline   Reply With Quote
Old Tue, May-08-2018, 09:51:56 PM   #20
A stock car has a power peak around 6200 and drops off thereafter. At some point the dropping power and added drag may limit top speed even if the redline is raised. This is where power mods would help. In other words, I am not sure an E36M3 that is stock apart from removal of the speed limiter and raising the redline to 7200 will hit its theoretical maximum of 164 mph. Don’t know for sure but my guess is that more power is needed. Fortunately, I am making over 650 rwhp at 7200 rpm.
Discussing Top speed? in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
