Old Mon, May-07-2018, 02:03:01 AM   #1
_JohnnyD_
Reputation: 0 _JohnnyD_ is on a distinguished road
Default Recommended Koni SA settings
I noticed the last few drives Iíve been on my suspension feels under dampened on the highways. When the car hits expansion joints at 75 mph the car bounces more than I would like.
I installed new Koni SAs and Eibach pro kit springs, spring of 2017 and replaced all of the bushings with OE parts last winter.
The car feels great on smooth roads and over larger bumps at slow speed.
The front and rear dampers are both set to 1/2 turn up from full soft. There a quite a few threads recommending 1/2 to 1 full turn up from full soft. Any more is supposed to be too firm.
Any advice from people running Konis on daily drivers or people that have experienced this high speed dampening issue? What setting are you running?
Jump to top _JohnnyD_ is offline   Reply With Quote
Old Mon, May-07-2018, 05:08:35 AM   #2
bhennrich
bhennrich's Avatar
Reputation: 0 bhennrich is on a distinguished road
Default Re: Recommended Koni SA settings
Subscribed as I am running a very similar setup (HR OE Sport) with Konis, and I bounce down the road...
Jump to top bhennrich is offline   Reply With Quote
Old Mon, May-07-2018, 04:32:02 PM   #3
Richardsperry
95 SC M3
Richardsperry's Avatar
I've had mine at 3/4 from full soft for 15 years. (OE Sport spings) It's a fine street car. Yes I would do something different if I took it to a track often, but as a street car, it's fine.
It handles as well as my C7 Z51 corvette does with magnetic ride set to tour mode. Really pretty amazing.
Old Mon, May-07-2018, 04:53:44 PM   #4
jared212
Reputation: 0 jared212 is on a distinguished road
I added eibach pro kit several years after konis. It was the springs(lowering) that increased the ride harshness for me.
'04 SGM/Blk Nappa|SMG|AA/FS Prima Elite kit|Hacksaw built engine w/ JE/Molnar/Supertech/ARP/lots of ceramic TBC|ID1050x injectors|Radium rail+FPD-XR|Aeromotive FPR|-6an fuel system w/walbro 450L pumping e85|RMS headers|Magnaflow w/custom 2.5" sec1|Besian|Redish|Eibach springs/Koni's|Hotchkis front sway bar+deleted rear|Turner Pulleys|Southbend stg 3 DD clutch|Innovate/Spek gauges|relocated SMG|Mishimoto Catch can|Koyo Radiator|CSF oil cooler|basically stock interior and exterior
Jump to top jared212 is offline   Reply With Quote
Old Mon, May-07-2018, 09:15:00 PM   #5
frbz
I have a Dinan supplied kit with the springs at the default setting. I believe it is 1 1/8 turns from full soft. It works well
Jump to top frbz is offline   Reply With Quote
Old Wed, May-09-2018, 02:28:57 PM   #6
nckwrnr
Reputation: 0 nckwrnr is on a distinguished road
That's the same for front and rear?
Yikes I have had mine at full soft for 4 years with H&R sports and was thinking recently its just too soft I need to try this adjustment.
Jump to top nckwrnr is offline   Reply With Quote
Old Wed, May-09-2018, 02:30:40 PM   #7
nckwrnr
I have had the dinans they are valved different than the off the shelf ones. To me they are softer which makes sense with your settings being set stiffer.
Old Thu, May-10-2018, 01:11:42 AM   #8
frbz
My understanding of the Dinans was they were shock dynoed and matched in pairs and sold as such. No idea if Dinan had special valving. Any historians here know the whole story? I got them on one of their sales at 20% off in 2011 so the price was the same as the off the shelf Konis and pick your spring.
Discussing Recommended Koni SA settings in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
