Old Wed, May-02-2018, 02:33:10 PM   #11
NolliM3
NolliM3's Avatar
Default Re: Differential output Seal and Snap Ring
Originally Posted by pbonsalb View Post
As for replacement cost, shop around. Beware M3 bolts are a little longer than non M3 bolts do get the right length. One person used hex socket head bolts as a replacement. I donít think there is anything wrong with that other than that the socket head actually strips more easily than the torx head.
I was searching last night on ECS with part number 33111214144 and it turn up not found. So, I looked through their drivetrain section and saw only hex bolts. I am surprised the torx head is much stronger...I'll get that replacement if it turns out only one or two is really bad.
Old Wed, May-02-2018, 05:24:26 PM   #12
For small head bolts the torx head with proper size torx socket and proper flush even seating of socket on bolt seems less strip able than Allen head bolts. I have Allen head on my driveshafts. They are cheaper to replace and easier to find, though. They would work fine if you can get the right grade— probably 10.9 or 12.9.
Old Sat, May-05-2018, 03:46:13 PM   #13
NolliM3
NolliM3's Avatar
For small head bolts the torx head with proper size torx socket and proper flush even seating of socket on bolt seems less strip able than Allen head bolts. I have Allen head on my driveshafts. They are cheaper to replace and easier to find, though. They would work fine if you can get the right gradeó probably 10.9 or 12.9.
Since those two toxr bolt will take an act of congress to remove, I decided to apply a government response by kicking the can down the road. The drive side wasn't leaking...only the passenger side that didn't present any problems removing. I had also hoped that remove the output flange would allow complete removal of the upper bolt of the lower rear control arm as I am replacing with adjustable ones. Here are pics of the two frozen torx bolt and my attempt at the upper bolt on the rear lower control arm.
Discussing Differential output Seal and Snap Ring in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
