Old Mon, Apr-30-2018, 08:38:35 PM   #1
NolliM3
NolliM3's Avatar
Default Differential output Seal and Snap Ring
Does the snap ring goes inside the differential housing before installing the output shaft so that it locks in place? I am trying to envisioning so that I have a clear understanding as the Bentley says. The diagram (in Bentley) doesn't shed a great light.
Old Mon, Apr-30-2018, 09:34:33 PM   #2
Default Re: Differential output Seal and Snap Ring
It's inside the differential and not necessary to replace if you do not feel up to the task. There are no issues with the output flanges falling out, even after multiple output flange removals.
Google had your answer in pretty good detail; http://www.bimmerfest.com/forums/sho...56&postcount=9
Old Tue, May-01-2018, 02:19:38 AM   #3
NolliM3
NolliM3's Avatar
Thanks Braymond...I had watched a video, but they didn't show how they install the snap ring.
Old Tue, May-01-2018, 06:50:22 PM   #4
NolliM3
NolliM3's Avatar
The O-ring (33111214144)...really wished that was sold with the seal and snap ring...it appears that was what's causing the leak (Pax side)...now I'll have to order the o-ring from the local dealer who will have to order from the distributor as that would not be in stock.
Old Wed, May-02-2018, 12:58:37 AM   #5
NolliM3
NolliM3's Avatar
Then, some torx bolts on the driver side are so stuck they stripped...at least two and those suckers are expensive...$13.21 a pop...wow! What are the methods you guys used get them out? I am not sure a vice-grip would do the job.
Old Wed, May-02-2018, 01:05:22 AM   #6
jayjaya29
Photographer
jayjaya29's Avatar
Angle grinder...cut the heads off then use vice grips to get the remaining part of the bolt out once the half shaft is removed.
Old Wed, May-02-2018, 01:51:45 AM   #7
You can hammer a torx socket on. Don’t do the initial loosen with an impact. Do by hand first then use a tool to spin off. Also make sure you use the right size torx. You might have stripped because you were one size off. If you can’t hammer the torx on, then cut the head off with a grinder or Drexel. Once you have the axles out there will be enough strip left to vise grip out and chances are it will come out.
Old Wed, May-02-2018, 02:36:50 AM   #8
You probably used the wrong size torx socket. The bolt heads need to be clean and the torx socket needs to be tight and fully seated on the head. The right size takes a little effort to fully seat. The wrong size up goes on too easily.
Old Wed, May-02-2018, 11:08:01 AM   #9
As for replacement cost, shop around. Beware M3 bolts are a little longer than non M3 bolts do get the right length. One person used hex socket head bolts as a replacement. I don’t think there is anything wrong with that other than that the socket head actually strips more easily than the torx head.
Old Wed, May-02-2018, 02:25:48 PM   #10
NolliM3
NolliM3's Avatar
Originally Posted by pbonsalb View Post
You can hammer a torx socket on. Donít do the initial loosen with an impact. Do by hand first then use a tool to spin off. Also make sure you use the right size torx. You might have stripped because you were one size off. If you canít hammer the torx on, then cut the head off with a grinder or Drexel. Once you have the axles out there will be enough strip left to vise grip out and chances are it will come out.
Well, I had used the correct size and used a 3/8drive breaker bar with a 11/2 extension attached to avoid the axle boot and may have had a lean...meaning the socket wasn't flat on the torx bolt which mess up the bolt head. Then, when I go to take the bolt off, the socket would fit; so, I thought I might have picked up the wrong socket. I then picked the next socket size only to realize it's the 14mn. It may turn out that it's only one that really bad...I'll see later.
Discussing Differential output Seal and Snap Ring in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
