Old Sun, Nov-28-2010, 10:29:27 PM   #31
das borgen
Off-Topic King
das borgen's Avatar
Reputation: 0 das borgen is on a distinguished road
thread needs bump
Jump to top das borgen is offline   Reply With Quote
Old Sun, Nov-28-2010, 11:31:27 PM   #32
WRXEATR
The Frugal and Outspoken One
Reputation: 0 WRXEATR is on a distinguished road
Oh hai
Jump to top WRXEATR is offline   Reply With Quote
Old Tue, Mar-01-2011, 01:23:27 AM   #33
DriveThisRoad
DriveThisRoad's Avatar
Reputation: 0 DriveThisRoad is on a distinguished road
Default Re: The definitive guide to self diagnosing your ABS/ASC light.
I also have a 97 with permanent ABS/ASC lights upon start up, never had the intermittent/while moving issue.
Had the codes scanned by the GT-1
50 - Throttle valve actuator mechanically faulty
81 - wheel speed sensor: front left not installed or faulty
82 - wheel speed sensor: front right not installed or faulty
113 - wheel speed info-front left not detected
114 - wheel speed info-front right not detected
This honestly told me absolutely nothing. I cleaned the sensors and it didn't help. A few days later I started the car and no lights! however that only lasted a few days. After those few days I started the car and the lights were back on. I have a feeling it's not the sensors, based on the fact that I it would be highly unlikely for both left and right sensors to go out at the same time, then come back for a few days, then go out again. I tried a different main ABS relay, that didn't help. Don't think the ASC relay can cause an ABS light, just the ASC light so I didn't replace it. I looked at all ABS related fuses and they look good. My understanding that the brake travel sensor could not cause an upon start up ABS light without even pressing the pedal. Where does this leave me? Bad pump perhaps.
I'll try using this write up to diagnose it as well, although I'm a complete 0 when it comes to electricity
Jump to top DriveThisRoad is offline   Reply With Quote
Old Tue, Mar-01-2011, 01:36:42 AM   #34
M3_ATW
Reputation: 0 M3_ATW is on a distinguished road
great writeup!
thanks a bunch!
Jump to top M3_ATW is offline   Reply With Quote
Old Fri, Mar-18-2011, 10:22:33 PM   #35
DriveThisRoad
Can anyone tell me which relay is the ABS pump motor relay? The post states that it's the 5 pole one and not the 6 pole one. The 6 pole is obvious and is labeled "ABS" right on it, the one next to it on the right is labeled "ASC". I've searched and all I see is people referring to a gray relay (where my ASC relays sits), but we don't have them on the M3s?
I also have a 97 M3.
Old Sat, Mar-19-2011, 01:45:20 AM   #36
Picket Fence
Reputation: 0 Picket Fence is on a distinguished road
Excellent info!
This should be made sticky in the diy section.
Jump to top Picket Fence is offline   Reply With Quote
Old Sat, Mar-19-2011, 02:11:01 AM   #37
M3_ATW
I never got around to diagnosing my permanent ASC OFF light. Might as well try to figure it out now.
I'll tell you one thing, dont EVER let your friends near your M3.
My light has been on since my friend tried to rev my M3's engine using the electronic throttle in the engine bay.... ugh.
Old Thu, Mar-24-2011, 09:24:22 PM   #38
DriveThisRoad
I used this writeup to diagnose my ABS problem and ran into what might be the issue right away. The resistance test on all 4 sensors yielded good results on 3 of them, with the front right clearly having issues. Sometimes It would show some resistance numbers (although very weird numbers) and sometimes there would be no resistance at all. I went ahead and purchased a new sensor.
If it holds up, my conclusions are as follows:
1. ABS related codes are more often than not useless. IMHO getting your computer scanned might help, but it's far from being useful in many cases. Perhaps clearing the codes and rescanning would yield better results, but all of that costs money for most.
2. Most are under the impression that ABS light cannot be caused by sensors without the car having moved. I suppose there is a resistance check by the ABS computer right away.
3. This thread is extremely helpful. Thank you to the thread starter.
Old Thu, Apr-21-2011, 06:20:42 AM   #39
E36_M
Reputation: 0 E36_M is on a distinguished road
good thread... thank you
Jump to top E36_M is offline   Reply With Quote
Old Sat, Aug-20-2011, 06:40:45 PM   #40
chase240z
Reputation: 0 chase240z is on a distinguished road
bumping thread.
I have no voltage to 3 of the 5, 12V pins going to the control module.
I removed the ABS 6 pin relay and checked again to see if I had 12V to all the pins again on the connector. I did not, still no change to the 12V pins that didnt have power prior to removing the relay.
All 3 ABS fuses are getting 12V and I have checked the 6 pin relay per the DIY checking resistance and giving it 12V power to hear it click.
What next?
EDIT. MORE SPECIFICALLY. 95 M3 early production
I am getting 12V power from pins 53, 34. Those are coming straight off fuse 21 no power to 3, 15, 33.
Jump to top chase240z is offline   Reply With Quote
abs or asc, definitive, diagnosing, guide, light
Discussing The definitive guide to self diagnosing your ABS/ASC light. in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
