Old Wed, Feb-28-2018, 01:44:29 AM   #11
nholmes
Track Junky
nholmes's Avatar
Default Re: ABS Pump Bleeder Nipple?
That might explain why the local wrecking yard pump had a hard line on it and not a bleeder nipple...
Follow my build thread here:
Originally Posted by Nate047 View Post
Are you feeling loose in the rear end currently?
Old Wed, Feb-28-2018, 01:57:55 AM   #12
pat533i
pat533i's Avatar
Reputation: 0 pat533i is on a distinguished road
Yup, my 95 has a hard line in that spot. My 97 has the bleeder.
@shut_up_racing
Jump to top pat533i is offline   Reply With Quote
Old Wed, Feb-28-2018, 08:50:56 AM   #13
M_Parallel
Mr. OEM
M_Parallel's Avatar
Netherlands
ASC on the 97 vs no ASC on the 95?
Old Thu, Mar-01-2018, 03:19:53 AM   #14
frbz
Reputation: 0 frbz is on a distinguished road
The early cars have a 3 channel system ie the rear wheels are controlled in tandem, whilst the later cars use a 4 channel system. So pump must be different
Jump to top frbz is offline   Reply With Quote
Old Thu, Mar-01-2018, 02:12:51 PM   #15
M_Parallel
Mr. OEM
M_Parallel's Avatar
Netherlands
Hence my previous reply.
Old Mon, Mar-19-2018, 08:35:54 PM   #16
nholmes
Track Junky
nholmes's Avatar
To confirm, only the 96+ E36 M3 has a bleeder at that location.
For those cars, we're getting closer to producing complete modification kits for this bleeder relocation. Prices will be reasonable, as we're not looking to get rich off of this or anything mostly just to recoup our time and tools + machining.
This will include clear instructions with appropriate high quality components for your car that also include mounting solutions.
Old Mon, Mar-19-2018, 10:54:02 PM   #17
frbz
I do not follow your diagrams. There never was a 95 328i, in that year the top non m E36 was the 325i
Old Mon, Mar-19-2018, 11:14:09 PM   #18
nholmes
Track Junky
nholmes's Avatar
I just used the information provided by RealOEM:
It's possible that's incorrect, of course.
Old Mon, Mar-19-2018, 11:16:36 PM   #19
M_Parallel
Mr. OEM
M_Parallel's Avatar
Netherlands
Maybe US was later. Just as with the M3.
Old Mon, May-14-2018, 08:55:51 PM   #20
nholmes
Track Junky
nholmes's Avatar
Still making progress on this.
Used a coathanger to get the line routing and then measured it with a string.
EDIT: It's hard to tell in the video, but the line clears the connector and will route under the wiring.
Discussing ABS Pump Bleeder Nipple? in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
