Old Mon, Jul-16-2018, 06:21:06 PM   #11
englishtom1596q
englishtom1596q's Avatar
Default Re: 5th gear lean/ slop in shifter
Originally Posted by Bimmerman325i View Post
OP-- the shifter bushings can be replaced without dropping the transmission. Unless it's a PITA to jack up the car, I'd rather do that twice than transmission R&R unnecessarily.
i would love to see this. There is no way you can do it in the car
Old Mon, Jul-16-2018, 06:23:59 PM   #12
Bimmerman325i
Beardface McMountainMan
Bimmerman325i's Avatar
Easy-- remove shifter linkage and carrier from under car, replace all bushings, cup, and maybe lever, re-install.
I'm not talking about the shift pins and detents in the transmission. If the shifter linkage bushings are worn to the point of fork-in-spaghetti, then that will cause vague nebulous shifting.
If those are in good condition, then you're already one step done towards pulling the transmission to do the detent/shift pins.
1998 BMW M3/4/5 -- DD rev1
Old Fri, Jul-20-2018, 06:12:39 PM   #13
TheLast13
Reputation: 0 TheLast13 is on a distinguished road
Originally Posted by abcurran View Post
If it were me, I'd drop the gear box and do the detent pins, linkage, clutch, flywheel, rear main/input/output/selector rod seals, guibo, and center support bearing all in the same go.
Big job, but you only want to have drop the transmission once.
Anyone in Ohio want to do this for me? I just bought everything to do this on my '99. I have zero interest doing this on my back in my garage with jack stands.
Jump to top TheLast13 is offline   Reply With Quote
Discussing 5th gear lean/ slop in shifter in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
