Old Sun, Jul-08-2018, 05:59:18 PM   #1
djdiplomat
Reputation: 0 djdiplomat is on a distinguished road
Default VDO temp gauge/Mishimoto temp sender
I want to install a water temp gauge and was thinking of splicing the mishimoto cooling fan sender. Has anyone done this? The sender is a 2 wire so I'm a little confused on the wiring. I tried to use as signal and ground but no go on the gauge.
Jump to top djdiplomat is offline   Reply With Quote
Old Sun, Jul-08-2018, 07:48:13 PM   #2
Default Re: VDO temp gauge/Mishimoto temp sender
That isn't a temp sender, it's a heat activated switch. Buy an actual temperature sensor designed to work with the gauge you are using.
Old Sun, Jul-08-2018, 08:32:35 PM   #3
djdiplomat
Thanks! I was not sure about it, thanks for confirming!
Discussing VDO temp gauge/Mishimoto temp sender in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
