Old Tue, Jul-03-2018, 05:56:22 PM   #1
NolliM3
NolliM3's Avatar
Default Installing Motion Underpanel
Those that have installed this underpanel...what do you do with this bolt in pic with the green arrow points to below? I am thinking of using and just ream out the hole of the bracket...just for knowledge, what's that bolt for?
Old Tue, Jul-03-2018, 07:34:28 PM   #2
Default Re: Installing Motion Underpanel
That's where your original undertray attached and ripped off.
Do not use Motion's included expanding plastic nuts and do not reuse your original old ones. Buy new OEM parts. Motion's will pull out and your original are likely stripped.
You can also rivnut it as shown in my guide; http://www.m3forum.net/m3forum/showthread.php?t=590177
Old Tue, Jul-03-2018, 07:51:29 PM   #3
Bimmerman325i
Beardface McMountainMan
Bimmerman325i's Avatar
Dumb question, but my nuts from Motion have done exactly that and pulled out.
Do you know what the OE part number is for those? I can't make heads or tails of the diagrams to find it.
1998 BMW M3/4/5 -- DD rev1
Old Tue, Jul-03-2018, 10:43:32 PM   #4
bluptgm3
Originally Posted by Bimmerman325i View Post
My nuts from Motion have pulled out.
#6?
https://www.realoem.com/bmw/enUS/sho...diagId=51_2047
Old Tue, Jul-03-2018, 11:10:12 PM   #5
51718242741 is correct.
Old Wed, Jul-04-2018, 12:16:33 AM   #6
Bimmerman325i
Awesome, thanks!
Old Thu, Jul-05-2018, 07:06:48 PM   #7
NolliM3
NolliM3's Avatar
Awesome Brett...my local dealer had them in stock so I placed an order for four at $2 plus change total; however, I'll only have those two bolts as pictured in first post and what Motion supplied...I am also bidding on some stainless steel insert on eBay that I may cancel, since you used aluminum. Where did you get the inverted hex bolt?
Old Thu, Jul-05-2018, 07:22:00 PM   #8
Any home improvement store carries allen bolts. Home Depit, Lowes, Ace, True Value, etc etc
Old Fri, Jul-06-2018, 03:30:28 AM   #9
NolliM3
NolliM3's Avatar
Here, you can really see the difference between the stock plastic insert to Motion's which is at the far right. Glad Brett recommended the stock ones.
Old Fri, Jul-06-2018, 05:58:18 AM   #10
bluptgm3
I have found Ace or True Value to be better than Home Depot, and Lowe’s has slowly depleted stock over the years.
Discussing Installing Motion Underpanel in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
