Old Sat, Feb-11-2017, 03:23:35 PM   #1
HolyChitMeng
Alpine White Hoarder
HolyChitMeng's Avatar
Reputation: 0 HolyChitMeng is on a distinguished road
Default Broken Vanos Tab
Hey guys, are there any noticeable symptoms of a Broken Exhaust Hub Tab? Or is it just something that you just have to check up on regularly and it could just happen at anytime?
AW/BLK 09' 6MT ///M3: ESS VT2-650, BBS LM, Stoptech Trophy, Evolve, Full Supersprint Race, KW Sleeve Kit
TIAG/IR 04' 6MT ///M3: BBS CH, Eibach Pro-Street-S, Full SS Race, Eventuri, Evolve, AS 30% SSK, OE CSL Bootlid
AW/BLK 95' ///M3: 16k miles, LTW Strut Brace
Jump to top HolyChitMeng is offline   Reply With Quote
Old Sat, Feb-11-2017, 03:25:02 PM   #2
EricSMG
40 something
Default Re: Broken Vanos Tab
No sir. Where things change dramatically is when both tabs break as I've experienced first hand
Old Sat, Feb-11-2017, 03:28:18 PM   #3
Slowmobile
Na Na Na Na Na Na Na Na
Reputation: 0 Slowmobile is on a distinguished road
Fault codes? As Eric said usually only notice when both tabs break. But if one tab breaks and gets caught in the timing chain then you will hear something for sure.
Just get the oil pump disk drilled or the chromoly hub.
Legen... Wait For It... ///M
Jump to top Slowmobile is offline   Reply With Quote
Old Sat, Feb-11-2017, 03:35:57 PM   #4
HolyChitMeng
I'm guessing by a dramatic change the car suffers from a sudden loss of power?
Interesting, might have to go check it out. My valve adjustment has been done about 3k ago, apparently everything was in check, could anything catastrophic have happened to the tabs in that 3k? Does driving habits affect it aswell?
Old Sat, Feb-11-2017, 03:57:59 PM   #5
ThunderMoose
Have you done Beisan or Turbotoy upgrade to hub or oil pump?
#67 2017 NASA TX TT3 Champion
Old Sat, Feb-11-2017, 04:10:02 PM   #6
nasieg
nasieg's Avatar
It's one of those must do things on these engines. Basically BMW allowed slightly too much play between the tabs and the holes in the hub. Meaning the tabs can wiggle back and forth and over time they get fatigue and snap......at leas that is how I understood it.
The "play" is not much, just a few thousands of an inch (I forget the exact amount). So the fix is to get a Besian hub, which uses the same part, where they re-machined two new holes, 90 degree from the existing ones, but without any play in them. This is also why you have a core charge and need to send yours back, so they can use it for the next guy.
If you are lucky the tabs are still intact and you don't have to replace that part, or you will spend another $800 or so. The hardest part is to try to find someone that you trust to do it, unless you want to tackle it yourself. Besian has very well documented DIY, but I would not recommend doing it, if you are not familiar with working on cars. One mistake and it will cost you a lot more than you would save, which is really why I decided to have a pro do it.
My Journal
Besian VANOS, Euro Headers & Section1, TTFS tune, TMS under-dive pulleys, TC Kline S/A Coil Overs, Brembo 996 Calipers, ECS 2 Piece Rotors, Rally Road/P0lar Adapters, SS Brake Lines, Motul 600,Hawk HT-10 Pads, Braille Lightweight Battery, Hotchkis Sway Bars, SR2 CF Sunroof Panel,Apex ARC-8 & Sportline CS8's, Recaro Sportser CS Seats,SAP delete,Lightweight Cabin Filter Housing, SG CSL Diffuser, OEM CSL Trunk, Modified Stock Muffler
Jump to top nasieg is online now   Reply With Quote
Old Sat, Feb-11-2017, 04:13:58 PM   #7
EricSMG
40 something
If both tabs break then the cams are completely immobilized (locked) and the car goes into severe limp mode, massive misfires, rough idle, no power, etc. CEL immediately.
You KNOW right at that moment that the car needs to be shut down and diagnosed.
You really, really don't want this as the tab(s) can fall down the timing galley and cause severe damage.
Old Sat, Feb-11-2017, 04:21:49 PM   #8
HolyChitMeng
Not as of yet, but plan on doing the Beisan systems soon.
Thanks for the clarification! I'm gonna check it out as soon as I can. Some of the things on this car frighten me severely. I diy everything, so I hope I can tackle it. Just wanted to know if there were symptoms of it so I know what to look out for.
That sounds absolutely terrible. How does one get the tabs out after they fall down the timing galley?
It sorta just happened to you out of the blue? No noises or rattles?
Old Sat, Feb-11-2017, 06:05:22 PM   #9
basketball00011
basketball00011's Avatar
Reputation: 0 basketball00011 is on a distinguished road
I decided to start on my winter maintenance yesterday, just because I know these engines have issues and this is what I found. Broken tab. No warnings, nothing. Car sounded quiet, no codes. 76k miles. TurboHub for me.
Jump to top basketball00011 is offline   Reply With Quote
Old Sat, Feb-11-2017, 06:18:00 PM   #10
m3vos
Reputation: 0 m3vos is on a distinguished road
I need to inspect mine, but I wanted to know, if your tabs are intact, is all you need to do the Besian VANOS rebuild? If the stock exhaust cam tabs are there, is it safe to leave that alone?
Jump to top m3vos is offline   Reply With Quote
Discussing Broken Vanos Tab in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
