Old Tue, Oct-06-2015, 01:52:08 AM   #1
duracellttu
Default Who has installed Mason X-brace themselves?
I am in the process of getting the Mason rear strut bar and x-brace with subframe support. When I get them items delivered, I will be installing them myself. The Mason website has installation instructions for the x-brace but I feel like they lack enough detail for me to tackle this job with confidence. There is a lot of drilling involved and I dont want to mess that part up.
Has anybody out there install these pieces themselves? I was hoping to pick your brain on the drilling portion. I'm trying to get more detail from John Mason, but every time I call, nobody answers the phone.
2005 BMW M3 ZCP - Black/Black 2M Autowerks Full Restoration: RKP CF Roof Conversion, OE CSL Trunk, JCSL Diffuser
Paul Claudes Custom Tune | Kassel Performance CSL ECU Conversion+MAP Sensor | Lang Stage Stage 2.5 Head | 288/280 Schrick Cams+DLC Coated Followers | CSL Karbonious Airbox+OE Snorkel | SS V1 Stepped+Catted Sec 1+Resonated Twin Pipe+Race | 3.91 w/ 3 stage clutch
TCK SA 450/500 | Vorshlag Camber Plates | Rogue Engineering ASP, RSM | AKG FCABs, RTABs, SFBs | TMS Sway Bars, Camber Arms, Pullies | Mason Race Strut, Rear X-Brace | AS 30% SSK | SPAL Fan | Redish Reinforcement | Turbo Toys V2 Hub | WPC Treated Rod Bearings
Old Tue, Oct-06-2015, 02:31:26 PM   #2
poms302
Reputation: 0 poms302 is on a distinguished road
Default Re: Who has installed Mason X-brace themselves?
Have you tried PMing him on here?
I think you're over thinking this.
Take the rear subframe bolts out.
Find the center of the hole and drill up as plumb as possible.
Using a 1.5" hole saw with the same size pilot bit(if possible) as your pilot hole drill down in the trunk.
Drill out the last 1/4" of the hard point hole from the top or tap it for threads.
Jump to top poms302 is online now   Reply With Quote
Old Tue, Oct-06-2015, 05:45:49 PM   #3
ThrowinShapes
ThrowinShapes's Avatar
Reputation: 0 ThrowinShapes is on a distinguished road
My biggest concern is putting holes through the rear towers for the cross brace. I'd be interested to see how people are sealing these holes and preventing rust in the long term. I actually emailed John, and he responded in the same way, "I think you're overthinking this". Not reassuring, IMO. I have a rust box e30, I don't want my e46 turning into that.
[06' AW/Cinnamon] [6MT] [Slicktop] [Manual Seats]
Journal - Update 2017-02-28
FS: Center Console | US Headers / Rear O2 | Rent: SIR B90-BMW Rear Wheel Bearing Tool
Jump to top ThrowinShapes is offline   Reply With Quote
Old Tue, Oct-06-2015, 10:30:56 PM   #4
duracellttu
I think that I'm just going to prime them and seal them with weather sealer. Same thing I did for the subframe plates after they were welded in.
Old Tue, Oct-06-2015, 10:35:30 PM   #5
duracellttu
Do you know how far down the hard point holes are from the top of the trunk floor? Any specialty tools needed to tap to get down to the hard point? I've been reading the instructions more thoroughly and am starting to get an idea of the process a little more, but the devil is in the details...
Old Wed, Oct-07-2015, 01:47:51 AM   #6
MJTSUB
Reputation: 0 MJTSUB is on a distinguished road
I had the same concerns especially in an area where water can be thrown up in the wheel well and cause rusting easily.
I made my drill marks after mounting the bar and using a strike to create a small dent in the sheet metal and then using a drill to drill the correct size hole.
I then put primer on the drilled hole/bare sheet metal from drilling. I then used silicone and applied that to the threads of the bolt, the back of the washers and on the surface that primer was applied to. I used an abundance of it so that when the bolt would go through it would squeeze out additional silicone to help create a water tight seal. I then smeared additional silicone around on the openings and then wiped them clean. Not much more I could do to take preventative measures.
http://www.m3forum.net/m3forum/showt...ighlight=MASON
Jump to top MJTSUB is offline   Reply With Quote
mason, rear, rear strut bar, subframe, xbrace
Discussing Who has installed Mason X-brace themselves? in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
