Go Back   BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X) > BMW M3 Discussions > M3 Frequently Asked Questions
M3 Frequently Asked Questions First place to check if you've got a question about your BMW M3. UNDER CONSTRUCTION
Old Wed, Mar-12-2014, 02:09:33 PM   #11
Default Differentials 2
More...
Originally Posted by orangehatter View Post
Cracking into the limited slip:
Reassembly and replacing the old clutches (this is where I lol at the people who buy into the Bimmerworld clutches...)
The cover bolts on the limited slip carrier get torqued to 25ft-lbs with Loctite 242.
Also a parts breakdown for the limited slip carrier:
01 33141209653
Differential, LIMITED SLIP DIFFERENTIAL UNIT. 25%
01 33141209652
02 33141210615
Differential housing
03 33141210616
Housing cover
04 33147740005
Screw, Fillister-head. M8X16
05 33141201939
Stop disk. 1,80MM
05 33141201938
Stop disk. 1,85MM
05 33141201937
Stop disk. 1,90MM
05 33141201936
Stop disk. 1,95MM
05 33141201935
Stop disk. 2,00MM
05 33141201934
Stop disk. 2,05MM
05 33141201933
Stop disk. 2,10MM
05 33141201932
Stop disk. 2,15MM
05 33141201931
Stop disk. 2,20MM
05 33141203791
Stop disk. 2,25MM
05 33141203792
Stop disk. 2,30MM
06 33141206919
Stop disk
07 33141204367
DIAPHRAGM SPRING
08 33141203795
OUTER DISC. 1,90MM
08 33141203796
OUTER DISC. 2,00MM
08 33141203797
OUTER DISC. 2,10MM
09 33141210626
INNER DISC
10 33141206909
COMPRESSION RING
11 33141210623
SIDE GEAR
12 33141210624
BEVEL GEAR
13 33141203801
BEVEL MATE SHAFT
Also for those of you that have purchased Bimmerworld "Motorsport" limited slip clutches...
And...
There you have it. The clutch discs that Bimmerworld sells are nothing more than the same OEM discs that you can find through Tischer, Germain, or The BMW Part Store for half the price.
The BMW part number is 33141210626. I got them for $37.56 each through The BMW Part Store (Mike Kent @ The BMW Store in Cincinnati)
Old Wed, Mar-12-2014, 02:13:31 PM   #12
Default Differentials 3
and finally
My solution to adapt the 14mm ring gear bolt holes down to 12mm for the holes on my 3.46 ring gear:
Custom machined by Blue Chip Tool in Blue Ash, OH from 4140 preheat treated steel. Cost me $110 + tax.
I torqued my ring gear bolts to 110ft-lbs with Loctite 271.
Got this from RockAuto:
Then these:
Which resulted in this:
Races driven in.
Then I got these puppies from Sam at Kelly BMW:
My solution for pinion shims:
The shims are from a Mercury boat, but the choice of thickness is awesome enough to make some fine adjustments. Also the OD is 3" just like the BMW shim, ID is 2.5" which is slightly more than the BMW shim..
Now that I had the shims and my ring gear bolted to the carrier, it was time to check my carrier preload:
Came in at 22in-lbs
Temporarily installed the pinion and carrier to check backlash:
Came in at 0.004in
Then my wear pattern came to this with the original pinion shim:
I was happy with that...
So I went for the final install on the pinion. I precrushed the new crush sleeve down close to the old. A few small blips with the impact and I was at 21in-lbs of rolling resistance. I used Loctite 271 on the new pinion nut and installed a new retaining collar:
Discussing Cars 101. How engines work, how oil works, how to drive stick, etc. in the M3 Frequently Asked Questions Forum - First place to check if you've got a question about your BMW M3. UNDER CONSTRUCTION at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
