Old Tue, Nov-14-2017, 09:44:31 PM   #31
TheGenius46M
TheGenius46M's Avatar
Default Re: S54 stubbornly high oil temps, thoughts?
Anyone running an in-line thermostat with the diverter valve and happen to have AN line dimensions to mate to the factory oil cooler? Looking to do this soon. Thanks
2003 E46 M3 TiAg/Cinnamon 6MT
Karbonius | MCS | Volk | Recaro | OMP | Hyperco | Ground Control | Besian | AKG | Schroth | Bimmerworld | Turner | PFC | CSF | SuperSprint | Radium Engineering |
Bay Area/ Nor Cal Coding and DME Tuning Specialist. PM for inquiries.
Old Tue, Nov-14-2017, 10:09:06 PM   #32
bigjae1976
I posted this in a different thread. I used the standard AN line adaptor and this thermostat...
https://rover.ebay.com/rover/0/0/0?m...2F122275115738
I used -10 lines.
2013 F30 328i - Melbourne Red
2004 E46 M3 - Imola Red
Old Wed, Nov-15-2017, 02:53:20 PM   #33
jayjaya29
Photographer
jayjaya29's Avatar
Originally Posted by m3elmo View Post
hood venting, especially the center one will help a lot with temps.
And will reduce high speed drag.
Old Tue, Nov-21-2017, 11:15:20 AM   #34
jsquared1013
jsquared1013's Avatar
Reputation: 0 jsquared1013 is on a distinguished road
Bahrain
Subscribed to see if there are any updates, I've had a similar issue with my E36, albeit with S50B30 (Japan-market S50B30 with OEM everything on the engine + CSR radiator, track days at Bahrain International Circuit). Oil temps within just a few laps get to 140*C (284*F). Either the factory oil cooler just doesn't get enough airflow down there below the radiator even with the duct, or the diverter valve claims are true (i.e. the oil thermostat just doesn't flow enough even when open). I'm installing the diverter valve this week before the track day on Friday, hopefully there will be an oil temp difference!
In BH: 1995 BMW M3 coupe (Avus Blue): "Euro" (but from Japan...), S50B32 installed while I rebuild teh B30 for POWA , UUC flywhl; X-brace, BW TrackCAB, sph-brng RTAB & Rear Arms, Revshift engine/trans/diff/subfrm mts, KW V2 w/ Vorshlag plates, UUC Sways; ECS caliper bushings, G-Loc R8 pads; AKG reinforcements for RTAB, front subfrm, rear sway mount; ARC-8 17x9
In US: 2005 Subaru STi (Obsidian Black Pearl): built EJ257, Blouch Dom3.0XTR, Hydra Nemesis, Whiteline bushings/Anti-Lift/Bumpsteer Correction/Rear Lateral Arms, Carbotech Pads + DBA rotors, Fidanza flywheel, ACT clutch, kartboy shifter, Perrin Rear subframe kit, CarLabs X-brace, Prodrive springs, and a bunch of other stuff I forget at the moment.
In US: 1992 Nissan 240SX coupe (Cherry Red Pearl... mostly): SR20DET, KTS coilovers, 5-lug swap (w/ Z32 Al. rear uprights), Z32 brakes, interior removed, lots of other little stuff; still in partially-working project mode because I keep moving before I can finish it
Jump to top jsquared1013 is offline   Reply With Quote
Old Tue, Nov-21-2017, 05:37:34 PM   #35
Bimmerman325i
Beardface McMountainMan
Bimmerman325i's Avatar
I'm curious how yours will do in that heat. My experiment is only a partial success since the ambient conditions were way cooler after installing better ducting and the diverter valve.
I have a feeling you'll notice slightly lower temps. Your oil cooler may not be sufficient enough though. While it won't fit in the nice duct, I've heard nothing but good things about the Zionsville S54/Z3 oil cooler kit from local E36+S54 racers. It's deeper than the factory cooler and ~twice as high, so you get a lot more cooling surface area and capacity. I'm tempted to try it next if this current approach isn't enough.
Please report back!
1998 BMW M3/4/5 -- DD rev1
Old Wed, Nov-22-2017, 04:38:23 PM   #36
Bimmerman325i
Originally Posted by nholmes View Post
Awesome, dude!
Pics of the new duct work?
Took me a bit to upload photos.
OE Euro Oil cooler duct, totally-not-taped to the bumper
Totally not speed taped to the radiator shrouding either
You can sorta see it in the lower half of the lower grill opening
Hard to tell, but it completely seals to the oil cooler. Stock US AC and AUX fan will NOT fit.
Old Wed, Nov-22-2017, 04:39:45 PM   #37
nholmes
Track Junky
nholmes's Avatar
Damn. Serious business.
Follow my build thread here:
Old Wed, Nov-22-2017, 04:40:39 PM   #38
Bimmerman325i
Srs bsns bcuz razekar
Old Sun, Feb-03-2019, 09:10:19 PM   #39
jsquared1013
Bahrain
Holy smokes, am I ever late to update with my results
I installed the oil thermostat "diverter" / eliminator whatever-ya-callit, and it seems to have completely solved the issue. Stock S50B30 "Euro" with OEM oil cooler and OEM duct, CRF radiator. Track temps = HOT (middle east, about 85-90*F even at night in "spring" and "fall" aka early summer and bonus summer ... winter nights are around 65*F and winter days around 75*F). I went from hitting 135*C (275*F) or higher in just under 3 laps, to being able to do a full 30-minute hard session and the oil temps would stay right between 105*C and 110*C (221*F and 230*F).
The downside is no more thermostat, so highway driving of 100-120 kph (62-75 mph) with 65*F-ish ambient temps would drop the oil temps too low for my taste, creeping down to 85*C (185*F) or less. Taking side streets to drive slower -- 60 to 80 kph (37-49 mph) was the temporary solution since it wasn't a daily driver I was going to see if a simple tape-over of the duct would fix the issue for highway driving, but the weather warmed up quickly enough that it didn't matter. When I eventually bring the car stateside, I'll look into an inline high-flow thermostat since the southeast has normal seasons for the most part
Discussing S54 stubbornly high oil temps, thoughts? in the M3 Track: Racing and DE Forum - Best mod for speed is learning to get the most out of what you currently have. Tracks and DE's is the place to start! at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
