Old Fri, Nov-21-2008, 06:45:07 PM   #1
flightz71
flightz71's Avatar
Reputation: 0 flightz71 is on a distinguished road
Taiwan
Default Help with bleeding brakes
Bleeding brakes has become almost a nightmare for me.
If I accidentally sucked air into the reservoir tank in the engine bay, does that mean there is air in my ABS system for sure?
The first was trying madrussian’s method by utilizing a motive power bleeder. When bleeding, I might have accidentally tilted the tank so the little hose in the tank was sucking in air instead of fluid. I don’t understand why this would be a problem. The motive bleeder forces fluid into the top of the reservoir through a universal cap… so I’m guessing fluid trickles from the pressurize tank and waterfalls into the reservoir. If air is being forced in, the air will remain on top of the reservoir and wouldn’t enter the pool of fluid correct? I don’t see how this would allow air to enter the system.
The second try was with the buddy method. I would fill the reservoir up, cap it, and have him pressurize the brake system. Then he would hold the pedal down hard, and I would then open the valve on a caliper just enough so brake fluid rushes out. He would tell me stop before the pedal hit the ground, and I would lock the bleeder valve shut. We would repeat this 6x per caliper for all 4 calipers.
My mistake though is I think I forgot to keep and eye on the reservoir. I would refill after each 6x per caliper… but the fluid might have gotten too low one time. If air gets sucked in, is it in the abs system for sure?
This is really effin annoying. I’ve wasted so much damn brake fluid, spent money on a bleeder, but now might need to take my car to a shop with GT1 to get air out of the damn system.
In the end… upgraded stainless lines, did a full flush but not the brake pedal feels shitty and unresponsive.
Any help would be appreciated.
Thanks in advance.
-Calvin
Jump to top flightz71 is offline   Reply With Quote
Old Fri, Nov-21-2008, 06:59:32 PM   #2
playskool1
NorCal's S54 S65 S85 Rod Bearing spc.
playskool1's Avatar
Reputation: 0 playskool1 is on a distinguished road
sup calvin. how funny i am about to do the same thing and im hoping i dont run into the issues you are having. i also bought a motive power bleeder, SS lines, motul fluid. it would really suck to waste the fluid since i only bought 2 bottles of it.
01/01 build date[LSB][Cinn.][6 Spd.]MAXIMUM PSI TURBO 14psi PT6266 [230k total miles][original motor]
[115k supercharged miles][17k E85 miles][9k turbocharged miles][1.9k track miles]
INSTAGRAM: @skweakykleen
Full Beisan VANOS overhaul, TMS Subframe Reinforcement, WPC rod bearings = bulletproof
fully built S54 w/ Precision 6870 coming soon!
Jump to top playskool1 is offline   Reply With Quote
Old Fri, Nov-21-2008, 08:31:05 PM   #3
docwyte
Track addict
docwyte's Avatar
Reputation: 0 docwyte is on a distinguished road
If you sucked up air, it's probably in the ABS system. Go to the dealer and have them bleed the system with the GT1.
'98 BMW M3 Track Rat
'08 Lexus GX470 Daily Driver
'15 KTM 1190R Beastly Moto
Jump to top docwyte is online now   Reply With Quote
Old Fri, Nov-21-2008, 08:40:18 PM   #4
m3 hal
Someone (I think M3peat) posted a short cut method of bleeding the ABS w/o a GT1. IIRC it involved having the car cranked up while bleeding via the buddy method, so that when the bleeder valve opens the ABS kicks on and bleeds itself.
Old Fri, Nov-21-2008, 08:40:56 PM   #5
m3 hal
or if you know someone with an Autoenginuity tool it has the bleed function
Old Fri, Nov-21-2008, 09:20:13 PM   #6
flightz71
flightz71's Avatar
Taiwan
yah dude, just make sure you keep that reservoir topped off. And make sure the bleeder is perfectly level and the pipe doesn't suck up air. Have a buddy check or hold the tank the whole time you're bleeding.
Old Fri, Nov-21-2008, 09:21:32 PM   #7
flightz71
flightz71's Avatar
Taiwan
thx for the tip bro!
Old Tue, Dec-16-2008, 01:00:45 AM   #8
playskool1
playskool1's Avatar
how much do they charge at the dealership for bleeding the brake system with the GT1?
Old Tue, Dec-16-2008, 01:02:26 AM   #9
JeST
Old School
JeST's Avatar
Reputation: 0 JeST will become famous soon enough
China
Whatever the dealers standard brake flush runs for + an hour of labor.
Garage:
'05 ZCP 6spd M3
'94 Toyota Supra 6spd Red/Black
https://youtu.be/58MlI21LoGM
Gone:
'03 AW/Cinn e46 M3
'08 DTM B7 S4
'87 Mtech 1 S50 e30
'88 Hennarot e30 M3
'11 LeMans Blue/Chestnut Mtech 335d
'11 e70 VF stage 2 X5M
'08 Interlagos/Extended Fox Red e92 M3
'02 Steelgrey slicktop
Jump to top JeST is offline   Reply With Quote
Old Tue, Dec-30-2008, 03:36:53 AM   #10
travisbickle
Reputation: 0 travisbickle is on a distinguished road
Arghh, what a pain in the ass. I have the exact same problem. I used a Motive bleeder and made sure I didn't push air into the lines. I've got an Autenginuity scanner but I can't figure out how to do the ABS bleed procedure.
'03.5 M3|Jet Black|Cinnamon|Nav|HK Removal|BBS LM 19s|TCK D/A Coilovers 400F/500R|TCK Camber Plates|TCK Rear LCAs|Powerflex RTABs|TMS Subframe Reinforcement|Borla Cat Back|AA Stage 1 Gen 2 SC|Mach V Motorsports TLC
Jump to top travisbickle is offline   Reply With Quote
bleeding, brakes
Bleeding brakes sk8ermoo Pacific 3 Thu, May-29-2008 08:37:19 AM
Bleeding brakes? hondas2000 E46 M3 (2001-2006) 13 Wed, Apr-11-2007 06:46:25 PM
Bleeding brakes? Zuletzt E36 M3 (1992-1999) 29 Thu, Dec-07-2006 08:38:49 PM
Bleeding brakes - HELP NC03M3 Faults, Fixes and DIY 10 Fri, May-26-2006 03:32:22 PM
Bleeding the Brakes! Mash3 E46 M3 (2001-2006) 27 Tue, Apr-25-2006 07:42:03 PM
Discussing Help with bleeding brakes in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
