Old Wed, May-17-2017, 08:12:19 PM   #1
Philby
Reputation: 0 Philby is on a distinguished road
Question rear shock mounts failing FAST
SO.... I must be doing something wrong
Blown out TWO sets of rear shock mounts in just a few miles.
Installing new Bilsteins on my own (E36 M3 of course)
First set of mounts was a fresh "upgrade kit" from Pelican Parts, said to be E46 mounts, includes reinforcement plate above the tower. My towers look fine.
This first set both pushed the rubber out of the steel mount on a big bump after about 2 miles of driving!
Second set was the previous mounts which looked fine (no cracks visible). One of these tore the rubber all around and pushed up and out, just a mile or two.
1. Maybe not torqued properly? I torqued these before installing in the car, upon further study I should torque after car is off the jacks on level ground? [though I will need a crowfoot wrench to torque it while holding the shaft?]
2. Needs new or at least correct upper and lower washers? These appear to be dished in the parts book, maybe not what was on the car when I bought it. I re-used these washers. My old lower washer slips all the way over the shock shaft, past the shoulder. Seems to me the lower washer should sit on the shoulder, which would allow it to transmit force to the rubber in the mount.
3. Could these be wrong shocks? Bavauto and Pelican list only one Bilstein, I think there used to be different ones for lowered vs. stock (my car is not lowered)
Thanks!
Jump to top Philby is offline   Reply With Quote
Old Wed, May-17-2017, 10:13:27 PM   #2
JGard
Reputation: 0 JGard is on a distinguished road
Default Re: rear shock mounts failing FAST
I have never heard of anybody blowing out their shock mounts. If you're getting that much travel (which is the only thing I can see causing that problem) then you likely have other problems. How are the bump stops? How are the rest of your bushings? Stock springs? Something else is likely wrong with your suspension and this is just one of the symptoms.
98 M3/4/5 Silver
Jump to top JGard is offline   Reply With Quote
Old Wed, May-17-2017, 10:15:07 PM   #3
englishtom1596q
englishtom1596q's Avatar
Washer on the bottom should not go over the shaft. Should stop at the bottom of the shaft to dissipate the load.
Old Thu, May-18-2017, 12:08:42 PM   #4
fiveightandten
fiveightandten's Avatar
It should look like this:
-Nick
Old Thu, May-18-2017, 01:16:23 PM   #5
I agree -- the OP is installing the shock to the RSM incorrectly.
Old Thu, May-18-2017, 03:09:10 PM   #6
Philby
Lower washer must be the problem, yes.
The old shocks had a slightly bigger diameter lower shaft, so the old washers sat on the shoulder.... just barely small enough inner diameter to sit on the shoulder.... looks like it was selected from the old-hardware bin.
Should have thought more clearly and checked when the lower washer went past the shoulder
Thanks folks!
Old Fri, May-19-2017, 11:57:14 PM   #7
PITT M3 RR
PA
PITT M3 RR's Avatar
You can press the rubber back in there. It's tough, but it'll go back in. Use oil
S54 E36 BUILD
Discussing rear shock mounts failing FAST in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
