Old Tue, May-16-2017, 05:00:05 PM   #1
nholmes
Track Junky
nholmes's Avatar
Question Transmission Advice (friend's trans)
So, we recently replaced the seal for the input shaft inside the bell housing in my friends ZF320 5 speed and it won't stop seeping fluid.
Has anyone experienced this before? What's the cause and best fix?
Thanks!
Follow my build thread here:
Old Tue, May-16-2017, 05:15:37 PM   #2
j0rdan J
Reputation: 0 j0rdan J is on a distinguished road
Default Re: Transmission Advice (friend's trans)
Noah, try putting some "reinzoplast" or an equivalent product around the seal when you replace it again.
Thats what I use when I replace front or rear crankshaft seals and have never had them leak on me
Jump to top j0rdan J is offline   Reply With Quote
Old Tue, May-16-2017, 06:08:31 PM   #3
I haven't checked the holes, but the guide tube bolts have a thread sealant on them. If they pass through you will get leaks through the bolts.
Old Tue, May-16-2017, 07:00:32 PM   #4
nholmes
Track Junky
nholmes's Avatar
Where on the deal does this out? Along the outer edge?
Good point. We'll check those.
Old Wed, May-17-2017, 01:48:18 AM   #5
Anaerobic sealant on outer circumference of seal won't hurt and might help. But I like the idea of first checking the guide tube bolts to see if they are leaking.
If you punctured the skirt behind the seal dont worry. That won't cause a leak if the seal is installed right and the guide tube bolts are installed right.
Old Wed, May-17-2017, 03:06:08 AM   #6
englishtom1596q
englishtom1596q's Avatar
I remember reading something awhile back about installing the seal too deep in the case and causing it to leak. Did you install it to the same depth as the old one? I've never replaced mine because "if it ain't broke, don't fix it" attitude.
Old Wed, May-17-2017, 05:42:35 PM   #7
nholmes
Track Junky
nholmes's Avatar
It looked to be flush at the time of the install.
Discussing Transmission Advice (friend's trans) in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
