Old Wed, May-10-2017, 10:23:29 PM   #1
Momo157
Reputation: 0 Momo157 is on a distinguished road
Default Ambient (exterior) Temp sensor
So, when I bought my car a few months back, the ambient temp sensor had been ripped from the wires and nothing was there. I purchased a repair kit from ESC Tuning in hopes of it being a quick repair. I digress, it doesn't seem to be that easy. Its still reading -35F and I can't seem to figure out the problem...maybe the wire is broken further back than I replaced? Or the sensor is bad? Is it possible to wire it up wrong? I did notice the temperature will gradually climb (Usually around 70F-80F) and then drop back down in temp. It doesn't alway return to -35F. However it consistently drops between +37F and -35F.....any input is welcome and appreciated.
Here's a link to the kit:
https://www.ecstuning.com/b-assemble...65816905133kt/
Jump to top Momo157 is offline   Reply With Quote
Old Thu, May-11-2017, 01:13:35 AM   #2
Default Re: Ambient (exterior) Temp sensor
What side did you install this on? Driver or passenger?
Old Thu, May-11-2017, 11:25:52 AM   #3
M_Parallel
Mr. OEM
M_Parallel's Avatar
Netherlands
I've seen this happen before. It could take a little time before it shows the right temp. Shouldn't take days or anything, but it's not uncommon either for it not to show the temp right away.
You could also reset the OBC and see if that helps. You need to access the 'hidden' menu to do this.
Old Fri, May-12-2017, 01:12:57 AM   #4
Hallatauer
Track Rat
Hallatauer's Avatar
Reputation: 0 Hallatauer is on a distinguished road
Should be plug and play. Trace the wiring as far as you can and make sure it is intact.
Sent from my SM-G930V using Tapatalk
Jump to top Hallatauer is offline   Reply With Quote
Old Fri, May-12-2017, 03:59:50 PM   #5
ECSTuning
ECSTuning's Avatar
Reputation: 0 ECSTuning is on a distinguished road
Make sure all your wire connections are solid and as Hallatauer said to trace the stock wires looking for pinches/frays. It should be a plug and done repair.
-James
Have questions? Need answers? Live Chat us! 8:30am to 12:00am Midnight EST
sales@ecstuning.com | customerservice@ecstuning.com
Customer Service Hours: M- F 8:00am - 8:00pm EST | Saturday: 10:00am - 7:00pm EST
Sales Team Hours: M - F 8:00am - 11:00pm EST | Saturday: 10:00am - 7:00pm EST
800.924.5172
Facebook | YouTube|OEM BMW Part Number Search
Jump to top ECSTuning is offline   Reply With Quote
Old Fri, May-12-2017, 04:29:05 PM   #6
Again... what side was the kit installed on. Too many people confuse the passenger side heated nozzle/door lock temp sensor for the OBC outside temp sensor located in the driver brake duct.
Old Fri, May-12-2017, 04:31:26 PM   #7
Also the kit linked is not specifically listed for the E36. The E36 sensor also differs in design and likely functionality.
Old Fri, May-12-2017, 04:41:00 PM   #8
M_Parallel
Mr. OEM
M_Parallel's Avatar
Netherlands
Amazing.
It just take 5 minutes for finding out which side is what.
Old Fri, May-12-2017, 07:34:32 PM   #9
Originally Posted by M_Parallel View Post
Amazing.
No shit, but did he look?
Old Fri, May-12-2017, 11:19:13 PM   #10
Momo157
I put it on the passenger side, because the previous owner informed me that's where it went. I took his word for it and just went with it. What color wires should I be looking for? Something happened and he didn't have all the duct work under the car so I didn't have a reference as to where it went, he just pointed out two wires and told me that's where I should wire up the new one. What does the other sensor do?
Discussing Ambient (exterior) Temp sensor in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
