Old Thu, May-11-2017, 06:46:01 PM   #11
omairtheman1
Default Re: Another cooling system thread...
ECS was kind enough to take back the vacuum filler.
FCP Euro and ECS have been extremely helpful.
Old Thu, May-11-2017, 07:54:11 PM   #12
camdinans3
Resident Rabble Rouser
camdinans3's Avatar
Reputation: 0 camdinans3 is on a distinguished road
sounds like there is still air in the system. takes a long time to bleed this car correctly. I've never used the vacuum method and it's been fine, just keep doing it.
Andrew: AVUS 1995
///95 Supercharged Club
Jump to top camdinans3 is offline   Reply With Quote
Old Fri, May-12-2017, 04:17:37 PM   #13
Adam E36
Adam E36's Avatar
Reputation: 0 Adam E36 is on a distinguished road
It's good to know you got it worked out. Keep a close eye on the coolant gauge for the next week or two to be sure you did fully bleed the system.
It's not clear to me why the term "ghetto" bleeding system is used--the method works. If you follow the Bentley manual, and if you raise the front of the car, that is the method that works best; it's not "ghetto."
The ECS tool is the solution to a problem that doesn't exist. According to your experience, it isn't a solution at all, since it didn't work. It's good to hear ECS took it back.
Jump to top Adam E36 is offline   Reply With Quote
Discussing Another cooling system thread... in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
