Old Thu, Mar-30-2017, 08:17:10 AM   #1
jjrho
Reputation: 0 jjrho is on a distinguished road
Default e92 m3 Q about LED light bulb changing
Hi,have a '08 e92 m3… want to change as many incandescent light bulbs to LED and wanted to get your input….
on the rear stop/turn sig. assembly, instead of spending $500 on upgraded rear LED light units, is it possible to just change the LED bulbs for STOP and TURN signals ? without using load resistors or with ? and if it throws off bulb failure dash light, can this be CODED ?
how about the internal ligths and lic. plate light bulbs ??
please advise,
james R
Jump to top jjrho is offline   Reply With Quote
Old Fri, Mar-31-2017, 07:20:33 PM   #2
Ur3ss
Reputation: 0 Ur3ss is on a distinguished road
Armenia
Default Re: e92 m3 Q about LED light bulb changing
please advise,
james R
I'm not sure about the rear lights but I recently got a E92 335i and installed LED bulbs for the angel eyes. It has an extra control box I believe is so the car doesnt think the bulb is burnt out. With enough research and google'ing you should be able to find a LED replacement bulb that makes the car think the original bulb in installed.
For reference here is the product picture for the bulbs I ordered.
https://images-na.ssl-images-amazon....1BM-0uWpxL.jpg
Jump to top Ur3ss is offline   Reply With Quote
Old Mon, Apr-03-2017, 06:18:37 AM   #3
jjrho
yeah, it looks like the LED has load resistors with it...
I noticed that there are LED bulbs that simply replace the 1157/1156 or whatever incandescent bulbs that are supposedly 'CAN BUS' compliant... I wonder if they will work w/o throwing a code... I just want the bright/quickness of a LED bulb for stopping and amber turn signal in the back lighting assembly....
anyone have input on this ??
james R
09 e92 m3
Discussing e92 m3 Q about LED light bulb changing in the E90 M3 (Sedan) | E92 M3 (Coupe) | E93 M3 (Convertible) (2008-2013) Forum - {Engine: S65 - Max Hp: 414 hp (420 hp Euro) at 8,300 rpm / 295 lb/ft at 3,900 rpm} at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
