Old Mon, Nov-14-2016, 04:23:15 PM   #11
GhassanM3
///M Power
GhassanM3's Avatar
Reputation: 0 GhassanM3 is on a distinguished road
Lebanon
Default Re: When to Replace Suspension?
Originally Posted by 4130 View Post
I had an OEM EDC shock fail recently at 50k miles. I decided to replace them all with Bilstein EDC and Swift Spec R springs. So far I'm happy with my decision.
Cool thanks for the insight. I will check out the Swift Spec R springs see what others are saying about them.
2003 Carbon Black M3 - Sold
Jump to top GhassanM3 is offline   Reply With Quote
Old Tue, Jan-03-2017, 01:40:20 PM   #12
hyenacousin7
hyenacousin7's Avatar
Reputation: 0 hyenacousin7 is on a distinguished road
I believe Bilsteins are a good alternative to the stock shocks you've got. I've had my Bilsteins for around 6 months so far and I must say I love the way they drive. Reasonably firm drive.
Last edited by hyenacousin7; Tue, Jan-03-2017 at 01:41:01 PM. Reason: typos in 2 words
Jump to top hyenacousin7 is offline   Reply With Quote
Old Thu, Mar-23-2017, 02:13:19 AM   #13
Jazzkat
Reputation: 0 Jazzkat is on a distinguished road
Originally Posted by GhassanM3 View Post
I heard that TRW was pretty good.
I am trying to get the OEM part numbers for all of the parts in that set so I can try to put together the set myself from getbmwparts and figure out which is cheaper.
Sourcing suspension bushings based on price will end in tears.
Listen to Ian - stick with OE.
Don't know if it is still an option, but I get a pretty deep discount as a retail customer at a local dealer via my Roadfly account.
Actually I don't even know how I got signed up for it...
Jump to top Jazzkat is offline   Reply With Quote
Old Thu, Mar-23-2017, 12:05:08 PM   #14
I'd go with the 100k mile recommendation. The deterioration is gradual and you don't really notice the incremental change until it's bad. But a fresh suspension is supple and makes the car ride like new again. Unfortunately to many people a new suspension means a set of stiffer shocks/struts and that actually makes the many old bushings and ball joints and links and mounts give a worse ride and handling.
You can buy an M3 suspension kit by TRW pretty cheap (cheap is relative but to me it looked like a good value and I will likely buy it in a year or two as I hit 100k). I think FCP sells a kit. TRW made the BMW parts.
You can also just replace parts here and there. Typically a few parts wear faster. If you are on a budget or not really into performance and the car drives fine to you this is ok.
Discussing When to Replace Suspension? in the E90 M3 (Sedan) | E92 M3 (Coupe) | E93 M3 (Convertible) (2008-2013) Forum - {Engine: S65 - Max Hp: 414 hp (420 hp Euro) at 8,300 rpm / 295 lb/ft at 3,900 rpm} at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
