Old Sat, May-14-2016, 01:51:22 PM   #41
vmbray
Reputation: 0 vmbray is on a distinguished road
Default Re: Car idle and acceleration hesitating
Originally Posted by MOTRSPRT View Post
No actually. Never even crossed my mind. How could the VANOS cause this engine to run so shi**y like it is? If it's a possibility point me in the direction of what maintenance should be performed on it.
Have you scanned for codes? My case was different BUT I learned if the dme thinks vanos isn't working it will set the cam angle at 90 degrees or so and engine will suck a lot. Inpa is invaluable here to see what's going on as it shows you the values while engine is running.
Any issue where it clears up or runs better around 3-4k warrants looking at vanos. It advances around 4.2k but can affect the engine at all rpm because it controls the cam angle. It's a must do maintenance item.
Sent from my SM-N910V using Tapatalk
Rear End Overhaul
Jump to top vmbray is offline   Reply With Quote
Old Sat, May-14-2016, 02:19:42 PM   #42
vmbray
Oh I see your codes, you would have vanos or camshaft errors.
Rear End Overhaul
Old Sun, May-15-2016, 03:36:40 PM   #43
MOTRSPRT
4CFEDM3
MOTRSPRT's Avatar
Reputation: 0 MOTRSPRT is on a distinguished road
I'll try pulling codes again today. Maybe something has changed because it's running worse than when I started this thread.
2007 M6
2003 M3
1998 M3
1997 318 vert
2011 Ducati 1198
MOTRSPRT
2003 M3 SMG Imola Red--AP headers, SGT sec. 1 w/200 cell cats, AR20'resonators sec. 2, SGT SCZA muffler, K&N cai, Tein springs, 19" factory wheels
1998 M3/4 Dakar Yellow--supercharged
Jump to top MOTRSPRT is offline   Reply With Quote
Old Mon, May-16-2016, 05:31:17 AM   #44
vmbray
2007 M6
2003 M3
1998 M3
1997 318 vert
2011 Ducati 1198
Can't hurt to service and test vanos anyway. My car had had the seal done and the timing was slightly off so it ran a bit better afterwards.
Also, injectors? Bad injector could maybe cause O2 sensor error. Also the other error looks like idle air valve, you said cleaning it didn't help, maybe it's fried.
Rear End Overhaul
Old Tue, May-24-2016, 12:24:39 PM   #45
MOTRSPRT
4CFEDM3
MOTRSPRT's Avatar
I didn't see this last post until now...
But I started in removing the intake manifold to replace the gaskets and all vacuum lines anyway. I found this:
That o-ring is tore, but I didn't have any fuel leaks. Might be a good time to remove these injectors and get them flow tested and balanced/repaired.
Also while I'm mentioning my intake manifold can anyone identify this cable? It's electrical, and not a vacuum line.
I think the only way to remove it is to remove it from intake manifold. Looks like I gotta remove the black box from underneath the manifold?
Im hoping that doing this maintenance addresses my issue or at least helps...
2007 M6
2003 M3
1998 M3
1997 318 vert
2011 Ducati 1198
MOTRSPRT
Old Tue, May-24-2016, 12:57:41 PM   #46
nrubenstein
That IS a vacuum line. It's not an electrical cable.
While you are doing work, clean your crank position sensor. It's magnetic, and just a little bit of gunk can make the car run like crap. And, you know, cleaning it is easy and free.
2006 GMC Sierra 2500HD 4WD Duramax LBZ/Allison
2002 BMW M3 Alpinweiß/Black - Dinan/Bilstein, AS SSK, JBL MS-62C, IDQ-12v3, JBL MS-8
Old Tue, May-24-2016, 01:23:18 PM   #47
MOTRSPRT
4CFEDM3
MOTRSPRT's Avatar
Okay that is good news knowing it's a vacuum line. I can pull harder .
As for the crank position sensor I actually have a new one to install. I already tried to replace it but couldn't get my arm and hand to bend correctly. LOL!
2007 M6
2003 M3
1998 M3
1997 318 vert
2011 Ducati 1198
MOTRSPRT
Old Tue, May-24-2016, 03:17:33 PM   #48
englishtom1596q
englishtom1596q's Avatar
that injector O-ring probably tore when you pulled the rail off. otherwise you would have had a catastrophic leak
Old Tue, May-24-2016, 03:25:46 PM   #49
MOTRSPRT
4CFEDM3
MOTRSPRT's Avatar
Agreed. Was thinking same thing.
2007 M6
2003 M3
1998 M3
1997 318 vert
2011 Ducati 1198
MOTRSPRT
Old Wed, May-25-2016, 05:48:15 AM   #50
vmbray
That's a good tip thanks
Rear End Overhaul
Discussing Car idle and acceleration hesitating in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
