Old Fri, Mar-11-2016, 11:31:26 PM   #11
andreialta
Reputation: 0 andreialta is on a distinguished road
Default Re: Car idle and acceleration hesitating
cam sensor also might play
Instagram: andreialta
1999 BMW M3 Coupe
2010 BMW X5 3.0
2008 Mini Cooper S
Jump to top andreialta is offline   Reply With Quote
Old Sat, Mar-12-2016, 02:16:05 AM   #12
MOTRSPRT
4CFEDM3
MOTRSPRT's Avatar
Reputation: 0 MOTRSPRT is on a distinguished road
Originally Posted by Rouzbeh View Post
Start with the easiest fix and move on up. It sounds to me like it's probably coils or ICV. Keep us posted though, also do you have better photos? Your ride is
Just cleaned the ICV. At first I couldn't hear the valve moving around and figured it was pretty dirty. Got it cleaned up and that valve was moving very freely. Crossed my fingers and started the car. There is absolutely no change.
I want to explain a little better about the idle and blipping the throttle. When the MAF is plugged in it doesn't idle very well. It has a miss to it. When I press on the gas and it goes to 1800 rpm it's very jerky. If I start blipping the throttle aggressively it dies. If I keep pressing on the gas past 2K rpm then the rpm's will climb. But it's not a pure clean sound.
Now when I unplug the MAF the idle is more stable. I can press on the gas to 2K rpm without any stumbling or jerkyness to it. When I blip the throttle aggressively it doesn't stumble or die. Driving is the same between the 2 scenarios where it's worse to drive with the MAF plugged in than without.
2007 M6
2003 M3
1998 M3
2011 Ducati 1198
MOTRSPRT
2003 M3 SMG Imola Red--AP headers, SGT sec. 1 w/200 cell cats, AR20'resonators sec. 2, SGT SCZA muffler, K&N cai, Tein springs, 19" factory wheels
1998 M3/4 Dakar Yellow--supercharged
Jump to top MOTRSPRT is offline   Reply With Quote
Old Sat, Mar-12-2016, 03:04:50 AM   #13
Pierre i am
ranch me brotendo
Pierre i am's Avatar
Reputation: 0 Pierre i am has a spectacular aura about
I would just get a new MAF at this point. It seems like it's your culprit.
I'm always been a huge fan of Dakar and your sedan is beautiful.
Sam 2/23/16
https://m.imgur.com/r/funny/vrjdqZ4
Jump to top Pierre i am is offline   Reply With Quote
Old Sat, Mar-12-2016, 04:11:50 AM   #14
MOTRSPRT
4CFEDM3
MOTRSPRT's Avatar
Default Car idle and acceleration hesitating
I've already replaced it though.
But thanks for the props on my car. Second owner from 2004 and 38000 miles. Now it has 180000 miles. Never had a car payment on it, so never had a reason to sell it .
2007 M6
2003 M3
1998 M3
2011 Ducati 1198
MOTRSPRT
Old Sat, Mar-12-2016, 04:15:17 AM   #15
MOTRSPRT
4CFEDM3
MOTRSPRT's Avatar
This ICV wasn't really dirty but it's really clean now...
2007 M6
2003 M3
1998 M3
2011 Ducati 1198
MOTRSPRT
Old Sun, Mar-13-2016, 06:02:59 AM   #16
MOTRSPRT
4CFEDM3
MOTRSPRT's Avatar
Unfortunately the ignition coils between an e46 and e36 have different plugs . So I've not been able to troubleshoot them.
Can I read the bad coils in any such way thru INPA or NCS Expert?
2007 M6
2003 M3
1998 M3
2011 Ducati 1198
MOTRSPRT
Old Sun, Mar-13-2016, 03:49:23 PM   #17
PITT M3 RR
PA
PITT M3 RR's Avatar
Originally Posted by MOTRSPRT View Post
I don't know how to do this?
2007 M6
2003 M3
1998 M3
2011 Ducati 1198
Well I solved the issue and documented it. I had a vacuum leak at the rear of the VC at one of the grommets. Check out the videos for the fix. My idle is rock solid and the car is pulling better It feels like, at the least its MUCH more smooth. very enjoyable now.
I document the "investigation" haha heres all the videos!
VIDEO 1 - Initial sign of smoke at the rear of motor on exhaust side ---------------------------------
VIDEO 2 - Closer look -----------------------------------------------------------------------------
VIDEO 2 - VC plasstic cover off, found it coming from the coil area of CYL 6-------------------------
VIDEO 3 - Coil out found loose grommet------------------------------------------------------------
VIDEO 4 - Loose bolt out, exposed leak -----------------------------------------------------------
VIDEO 5 - explanation of the test -----------------------------------------------------------------
VIDEO 6 - CLoser look at smoke machine in operation -----------------------------------------------
S54 E36 BUILD
Jump to top PITT M3 RR is online now   Reply With Quote
Old Sun, Mar-13-2016, 03:51:08 PM   #18
PITT M3 RR
PA
PITT M3 RR's Avatar
For a forced induction car, you should make sure to have absolutely zero leaks, that's a closed system after the compressor, only her out should be from the bypass valve not should enter back in after the HFM
S54 E36 BUILD
Old Sun, Mar-13-2016, 04:13:05 PM   #19
MOTRSPRT
4CFEDM3
MOTRSPRT's Avatar
Dang! Videos are very informative. I can see the advantage of using one now. Without the right tools a guy simply shotguns repairs or goes on a wild goose chase. Like me buying another MAF...all the other ideas I've tried haven't really cost me a lot of money but mostly time. And they've been things I've needed to fix or replace anyway. I wonder if I can rent something like this?
2007 M6
2003 M3
1998 M3
2011 Ducati 1198
MOTRSPRT
Old Sun, Mar-13-2016, 04:59:13 PM   #20
PITT M3 RR
PA
PITT M3 RR's Avatar
Well the one you see in the video there, I made using a water bottle from college a glow plug and the battery charger I'll get you the video of that when I first did it hang on
S54 E36 BUILD
Discussing Car idle and acceleration hesitating in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
