Old Sat, Sep-24-2016, 12:00:19 AM   #91
MOTRSPRT
4CFEDM3
MOTRSPRT's Avatar
Reputation: 0 MOTRSPRT is on a distinguished road
Default Re: Car idle and acceleration hesitating
Update:
Got my car running to the point that it's drivable without worrying about it stalling. This is after 5 months of it sitting in the garage while I search for the fix to get it to idle properly. The latest change is a new silicone intake hose. However, after I pumped in a half tank of fresh gas the car is running nearly flawless. It idles rock steadily. There is still a slight miss at idle but it runs thru the rpms just fine. No longer stalling. The only thing I'll say is that I think it should pull harder than what it does now.
I can really enjoy the car again that I've missed driving nearly half year.
2007 M6
2003 M3
1998 M3
1997 318 vert
2011 Ducati 1198
MOTRSPRT
2003 M3 SMG Imola Red--AP headers, SGT sec. 1 w/200 cell cats, AR20'resonators sec. 2, SGT SCZA muffler, K&N cai, Tein springs, 19" factory wheels
1998 M3/4 Dakar Yellow--supercharged
Jump to top MOTRSPRT is offline   Reply With Quote
Old Sun, Oct-02-2016, 05:46:46 AM   #92
MOTRSPRT
4CFEDM3
MOTRSPRT's Avatar
99% of my original issues are solved. Starting is not an issue. Idling is rock steady. Pulling normally.
The 1% problem is occasionally it seems to drop a cylinder or 2 and sound like a Subaru. It still maintains idle and won't stall as before. The acceleration is slow due to the dropped cylinder(s). However, if I turn the car off and restart, the electrics is rebooted and the engine is back to normal running on all 6 cylinders. While I'm glad to have a remedy to this situation when it arises, it's only temporary. What can I check to find this issue?
MOTRSPRT
Old Sat, May-06-2017, 02:03:42 AM   #93
MOTRSPRT
4CFEDM3
MOTRSPRT's Avatar
Small update here to my last post. I removed the valve cover for when the car would drop a cylinder I could pull over and check the coils by just unplugging each one by one to see if anything changes. Sure enough the problem emerged, I pulled over, popped the hood and began unplugging the coils. When I got to #4 nothing changed. Gotcha! So I went home and swapped it for a new one. That issue hasn't resurfaced in a couple weeks.
But I need some clarification on the TPS. My Haynes manual says there should be 5 VDC at terminal 3 and ground at connector. Yes. Then it says there should be approx. 4K ohms between terminals 1 and 3 at harness. Nope. My old one was giving me ~4.850K. New one is giving me ~4.250K ohms. It seems high. Is there anything wrong w even the new one?
MOTRSPRT
Old Wed, May-10-2017, 02:08:11 AM   #94
MOTRSPRT
4CFEDM3
MOTRSPRT's Avatar
Bump!
MOTRSPRT
Discussing Car idle and acceleration hesitating in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
