Old Sat, Feb-18-2017, 12:12:15 AM   #1
AK_Topwise
Reputation: 0 AK_Topwise is on a distinguished road
Default Aftermarket front sway bar: worth it?
Just wondering if any of you guys that have upgraded your front sway bar can chime in and give me some real world/daily driving pros and cons?
I am thinking about pulling the trigger on either a st suspensions or hotchkis front sway bar to compliment my existing koni yellow and h&r springs setup (haven't installed the springs yet currently on the eibach pro-kit but can't stand the rake, the h&r's are the rear height adjustable ones).
What I am looking for out of the sway bar is:
- reduction in body roll (I can really feel the weight transfer in this car from front outside tire to rear inside tire under any regular day to day driving)
- go kart style steering response
- on rails feeling
I have already replaced rtabs/fcabs/steering guibo/rsm's/rear outer ball joints and previously had the car on st coilovers which were stiffer than the koni/eibachs setup but also super harsh and still had body roll.
I feel like my jaguar x-type on bilstein hd's and h&r springs actually corners flatter than my m3. Anyways, what are some of your experiences with adding a bigger front sway and is it worth it for a daily driver that sees one or two track days a year?
Thanks!
TiAg 2005 E46 ///M3 18" VMR VB3 / Macht Schnell Stage 1 Intake Kit / Status Gruppe Tuning Headers, Section 1 & Titanium Tip Muffler / Evolve-R Tune / Koni yellows / Eibach Pro-Kit / Rogue Engineering RTAB's + RSM's / AutoSolutions 30% SSK / ICONZ CSL Style CF Front Lip (painted matte black) / ICONZ CSL Style CF Rear Diffuser / Matte black grills & gills / Matte black roundels & emblems / Tinted taillights / Smoked corners & reflectors / Tinted windows
Jump to top AK_Topwise is offline   Reply With Quote
Old Sat, Feb-18-2017, 12:20:09 AM   #2
Default Re: Aftermarket front sway bar: worth it?
Yes imo. I just put a TMS 30mm up front on the medium setting (middle hole) and I can tell the difference from before.
Swaybars were one of my favorite mods on my E36 too.
Whether or not you need front or rear or both and what thicknesses and setting depends on what you want to achieve, the type of track, your driving style/preference wheel/tire widths types etc...
But a basic upgrade is a stiffer front. And you get new bushings.
/// 2004 SilberGrau M3 · Coupe · 6MT · slicktop · manual seats · zero options · JOURNAL
-NA S54-
·Evolve-R Alpha N · Evolve CSL CF Airbox · Eventuri Scoop · Supersprint V1 stepped 63mm · SS V1 S pipe 63mm + 200 cell HFC · OE sect 2 60mm · SS Sport 60mm
·Besian · RE pullies/fan delete · WPC rod bearings · GroundControl S/A (Koni/Eibach 440/550) + tall RSMs · TMS Camber & Subframe plates · SPC Adj alloy rear camber arms
·RE Trans Mounts · AKG poly SUB/DIFF 95a · SDW RTAB · Weighted ///M knob + UUC DSSR + delrin carrier bush · OE CSL trunk · APEX 75mm Studs
·Sportline 8S 18"x8.5/9.5" · MPSS 245/275 · Brembo 996 36/40 345mm CSL Textar FF & 28/30 328mm CSL ATE "D738" FF · CM brackets & ss/teflon lines
·Pioneer DEH-80PRS · Eclipse PA5422 · CDT HD-6 + WS-100i · CDT EX-530 · 8" Kicker
DD/Beater: 1999 Civic LX - Kenwood x998 · PPI 1600.4 · CDT HD-6 + HD-100 · CDT EX-530 · DVC 10"
Old Sat, Feb-18-2017, 12:25:32 AM   #3
2001E46m
Reputation: 0 2001E46m is on a distinguished road
Not worth for DD. Especially if your roads are full of imperfections. Sway-bar makes the suspension less independent between left and right. Rider quality will suffer.
Jump to top 2001E46m is offline   Reply With Quote
Old Sat, Feb-18-2017, 12:26:46 AM   #4
AK_Topwise
Thanks for the input.
I am running 245/40/18 and 275/35/18 pss.
I just like the car to feel flat and planted in corners driving to and from work everyday, taking on ramps fast and confidently and precise fast responding steering.
Old Sat, Feb-18-2017, 12:38:02 AM   #5
LINDW4LL
LINDW4LL's Avatar
Reputation: 0 LINDW4LL is on a distinguished road
Yes, 100%. The Turner Motorsport front bar was my first modification and one of my favorites.
The main improvement in my eyes though was not the reduction in body roll but rather that it significantly reduced (and basically eliminated) understeer. With the stock sway bar I would get some push when driving spiritedly on tight roads. The limit is far higher after installing the bigger front bar and on the same roads I can carry more speed through the same corners without any push occurring.
2003 ///M3
| Stahlgrau | FABSPEED Headers | Section 2 EVC | buildjournal |Turner MS Sway Bars | Bilstein | Pilot Sport 4S | Porterfield R4-S | OE LED Tails | M-Track DSC |
Jump to top LINDW4LL is online now   Reply With Quote
Old Sat, Feb-18-2017, 12:41:33 AM   #6
Chris_M
Chris_M's Avatar
Reputation: 0 Chris_M is on a distinguished road
A front sway bar does make a significant difference in the way the car handles. Whether you like the change or not is personal preference/driving style. I put one on mine, trying to set it up for some autocross this year. And I feel like the car is faster in lower speed corners/can put more power down coming out of a corner, and more precise in transitions. But overall, I think the stock balance is more fun for street driving.
Different ball game for people running square wheel setups, or running a bigger rear bar as well.
[2004 M3 Coupe - 1998 Wrangler Sport]
Jump to top Chris_M is offline   Reply With Quote
Old Sat, Feb-18-2017, 01:03:13 AM   #7
AK_Topwise
I never realized it would have a significant negative impact and ride quality and comfort, thanks for the feedback!
Old Sat, Feb-18-2017, 01:46:07 AM   #8
2001E46m
Sway bar links the left and right suspension.
Imagine a extreme case that the sway bar has infinite stiffness, what you end up is a solid axle like those used on trucks and Mustangs.
The stiffer the sway bar the more you give up on the independence between the suspension.
I'm a OEM purist guy and an Engineer by trade. The factory suspension geometry and metrics a refine tuned by the BMW engineers for best overall performance. I don't want to mess up with that unless I'm really know what I'm doing and I'm gonna track the car.
Old Sat, Feb-18-2017, 01:54:32 AM   #9
nasieg
nasieg's Avatar
I added the Hotchkis sway bar kit, front and rear. I have a TC Kline coil over suspension and GC camber plates and the sway bars did reduce body roll. My car is geared towards track performance and part of the motivation was to lose a few pounds of the front with the hallow sway bar. That being said, it is a nice handling improvement, but it is subtle.
Best way to describe it is that it made the car slightly sharper and it rolls a bit less. Definitely worth it.
My Journal
Besian VANOS, Euro Headers & Section1, TTFS tune, TMS under-dive pulleys, TC Kline S/A Coil Overs, Brembo 996 Calipers, ECS 2 Piece Rotors, Sportline CS8's, SG CSL Diffuser, OEM CSL Trunk
Jump to top nasieg is online now   Reply With Quote
Old Sat, Feb-18-2017, 06:34:39 AM   #10
silvergray545
silvergray545's Avatar
Reputation: 0 silvergray545 is on a distinguished road
How much lighter is the Hotchkis front bar? I was looking to get the front bar only. I like how my car feels with my current suspension set up and stock sways. I'm thinking to run a Hotchkis front bar at full soft since it's 11% stiffer than stock at that setting. The weight savings and increased roll resistance makes it seem worth it.
2004 BMW M3 6MT - TiAg/Gray
2016 BMW M3 ZCP 6MT - AW/SO
2000 BMW M Roadster 5MT - TiAg/Black
2014 VW GLI 6MT - Black/Black
E46 M3 Build Journal
Jump to top silvergray545 is online now   Reply With Quote
Discussing Aftermarket front sway bar: worth it? in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
