Old Thu, Nov-08-2018, 06:47:47 PM   #11
Lennon31987
Last of the Best
Lennon31987's Avatar
Reputation: 0 Lennon31987 is a jewel in the rough
Default Re: Diff from Coupe and Vert the same?--- 4.10 whine?
Originally Posted by OneFastSicilian View Post
Hey guys,
Swapping diffs with a buddy of mine who has 4.10s and he's putting his car to stock but I was wondering if there is any differences in the diffs themselves since his car is an 02 vert and mine is a 05 coupe.
Also, I wanted to ask those who have the 4.10s, how much whine do you really get? I'll be running oem diff cover bushings but the RE front diff mount. I'm not upgrading to the poly cover bushings because I want to keep the whine to a minimum. I know its common to get some whine on decel. but wanted to confirm from others.
Any feedback on these two questions is greatly appreciated!
-Frank
FRANK!
Had 3.91 and never had any whine whatsoever.
GL with install and i'd love to check your e46 out some time, im itching for another...
on land: 2013 mini cooper S JCW countryman (florida) 2003 911 turbo 'yellow bird' (not stock), 1967 c2 corvette droptop, 12 Turbo S drop
ON ORDER: 2015 McLaren 650S (Tarocco Orange or Aurora Blue?)
By sea: Riva Motorsports gp1300r stage 3, 2013 yamaha FZR with intake, tune, pulley. 2008 110' Lazzara, 2007 26' tender with twin 300 outboards
2 wheels: 2013 vespa (florida), 2014 899 Panigale Ducati
Sold: 2014 991 gt3 (tons over sticker and I never drove her)
2005 996tt Vert black/black
2010 SL65 AMG Black
2002 imolarot M3 coupe
Jump to top Lennon31987 is offline   Reply With Quote
Old Thu, Nov-08-2018, 09:32:01 PM   #12
OneFastSicilian
Frankie
OneFastSicilian's Avatar
Reputation: 0 OneFastSicilian is on a distinguished road
Italy
Originally Posted by Lennon31987 View Post
FRANK!
VIN! Nice to see you still browsing around over here lol
Anytime you're in westchester or hudson valley let me know. I dont really drive the car much anymore but if it's nice I'll bring it out
Previous:
  • 01 - AW/IR - Sold
  • 03.5 - IR/Impulse - Sold
  • 02 - TiAg/Blk - Sold
  • 05 - IB/Blk ZCP - Sold
  • 02 - LSB/Blk - Sold
  • 05 - SG/Blk - Current!
Check out my Journal!
*Instagram*
@_Frank_Stone_
Jump to top OneFastSicilian is offline   Reply With Quote
Old Thu, Nov-08-2018, 09:33:04 PM   #13
OneFastSicilian
Frankie
Italy
so many mixed things on the diff whine! Seems like most are saying the whine is normal between 60-80 mph and decel... some are saying no whine at all..
Previous:
  • 01 - AW/IR - Sold
*Instagram*
@_Frank_Stone_
Old Thu, Nov-08-2018, 09:36:15 PM   #14
E46Hoonigan
E46Hoonigan's Avatar
Reputation: 0 E46Hoonigan is on a distinguished road
I have Powerflex race bushings on my 3.91 and it whines a bit on the highway.
Instagram: sid_e46
CarbonBlack/Cinnamon E46 M3
Koni/Vogtland, Apex ARC-8 18" Square/PS4s, Powerflex, Megan Racing Sec. 3, WPC Rod Bearings, ECS OCC, Besian VANOS, Mishimoto Electric Fan, 3.91 Gears, 996 Brembo, OEM CSL Trunk/Diffuser
Alpine White/Sakhir Orange F10 M5 Comp
Stage 1 Vargas Turbo Upgrade
Jump to top E46Hoonigan is offline   Reply With Quote
Old Thu, Nov-08-2018, 10:11:44 PM   #15
Originally Posted by fattycharged View Post
Mine is constant, I wouldn't say I lost anything. Still young enough to have all the high frequencies
Have you ever been tested? Simplifying a lot, but tinnitus is more or less your brain's attempt to fill in missing information from your inner ear. I'm 27 with tinnitus, and have moderate-severe hearing loss in both ears.
Old Thu, Nov-08-2018, 10:24:05 PM   #16
M3AZ
///M3AZ
M3AZ's Avatar
Reputation: 0 M3AZ is on a distinguished road
I've been communicating with Jim Blanton at Performance Gearing about a diff upgrade. He mentioned that that there would be some increased noise (whine) with the 4.10 gears because BMW Motorsports gearsets are not lapped like production gears, and that around 2014 this got worse when BMW changed the surface treatment.
Jump to top M3AZ is offline   Reply With Quote
Old Thu, Nov-08-2018, 10:32:54 PM   #17
fattycharged
can't even
fattycharged's Avatar
Reputation: 0 fattycharged has disabled reputation
Zimbabwe
Of course, plenty of snake oils out there to help with it too! It probably took me close to 5 years before I got used to it enough to sleep through the night and I began to "tune" it out during the day. Sucks about your hearing loss, I did not suffer any, I just have lots of very high pitched constant ringing that feels like a string being pulled through my head if I concentrate on it.
Topo Chico
Jump to top fattycharged is offline   Reply With Quote
Old Thu, Nov-08-2018, 10:38:35 PM   #18
Loi-Spec
Loi-Spec's Avatar
Reputation: 0 Loi-Spec is on a distinguished road
My friend wing'd my car by using the stock shims on my 4.10 install.
No whine other than low rpm 20mph... and it's gone after that.
And it's very very minor. Drives perfect IMO As long as when you spin the diff, it's not too tight or loose, it should drive fine.
(OEM Diff bushings) Solid Subframe bushings.
Jump to top Loi-Spec is offline   Reply With Quote
Old Fri, Nov-09-2018, 04:54:48 AM   #19
Whine here with akg diff/subframe bushings.
Old Sat, Nov-10-2018, 06:50:49 PM   #20
red-m3
red-m3's Avatar
Reputation: 0 red-m3 is on a distinguished road
Bahrain
No whine here as well
Jump to top red-m3 is online now   Reply With Quote
Discussing Diff from Coupe and Vert the same?--- 4.10 whine? in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
