Old Fri, Jul-13-2018, 03:59:17 AM   #1
avusbluem3
avusbluem3's Avatar
Reputation: 0 avusbluem3 has disabled reputation
Default Airbag light
I've had the airbag light for a while. Finally got INPA working so I can view the code. Tried clearing the error. The airbag light turns off for a second and comes right back on. Below are the screenshots of the error and status. I swapped the door airbags to see if the error will show up on the passenger side. Same error. Any ideas? I did search and found a few threads with ZK5, nothing with ZK4.
Thanks.
95 E36 M3 Avusblue/Dove Gray :Sold
02 E46 M3 Steel Grey/Black Nappa/SMG II
Jump to top avusbluem3 is offline   Reply With Quote
Old Thu, Jul-26-2018, 04:16:08 AM   #2
avusbluem3
avusbluem3's Avatar
Default Re: Airbag light
Anyone?
Old Thu, Jul-26-2018, 08:52:19 AM   #3
daytonaviolet
OEM CSL Whoore
daytonaviolet's Avatar
when you swapped the bags from left to right.. when you say same error, the error is still the front left?
perhaps its a wiring issue on the front left and not the air bags?
Tischer aka GetBmwParts
Old Thu, Jul-26-2018, 07:11:55 PM   #4
avusbluem3
avusbluem3's Avatar
Thanks for the response.
Yes, when I swapped airbags, the error is still front left.
Thatís what I saw in other threads that it could be the wiring. Wanted to get some suggestions as the ignition circuit was different.
Thanks.
Discussing Airbag light in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
