Old Fri, Jul-13-2018, 12:52:00 AM   #21
guayo42
Reputation: 0 guayo42 is on a distinguished road
Default Re: Peeling/sticky interior rubber coating annoyance
That piece is pretty easy. Should take you like 15 minutes.
Yup. Not too bad at all. Make sure you have a trim removal kit at hand so you won't scratch anything. I recently changed it out while replacing the radio with an Xtron unit.
Jump to top guayo42 is offline   Reply With Quote
Old Fri, Jul-13-2018, 01:02:41 AM   #22
If you work the 303 in for a little longer, it looks amazing. If you just wipe with it quickly, it'll streak.
I live by it, but I gotta try the einzette products too, heard good things.
-NA S54-
·RE Trans Mounts · AKG poly SUB/DIFF 95a · SDW RTAB · Weighted ///M knob + UUC DSSR + delrin carrier bush · OE CSL trunk · APEX 75mm Studs · ZHP 13.7:1 P/S Rack
·Sportline 8S 18"x8.5/9.5" · MPSS 245/275 · Brembo 996 36/40 345mm CSL Textar FF & 28/30 328mm CSL ATE "D738" FF · CM brackets & ss/teflon lines
Old Fri, Jul-13-2018, 01:20:44 AM   #23
2006E46M3fan
2006E46M3fan's Avatar
Originally Posted by neopolymath View Post
Working with those pieces is stupid easy. Check out youtube for quick R&R procedure.
Thanks gents, what's another $169 amirite.
Jump to top 2006E46M3fan is online now   Reply With Quote
Old Fri, Jul-13-2018, 09:02:21 PM   #24
hlmiii
Reputation: 0 hlmiii is on a distinguished road
FWIW on the door panel speakers -
I had the same scuff issue and reaction (it really bothered me). I spent a couple of months thinking about all the details and +/- issues. There are 3 options - refinishing (didn't seem possible to match OEM finish, especially while assembled), separating panel pieces and refinishing (seemed very touchy, time consuming and difficult to reassemble reliably), or buying new or mint panels (costly and difficult to find).
I decided to try refinishing and it turned out virtually identical to OEM. Steps -
- mask all non-paint areas. Leather is critical. Use painter's tape and wrapper (plastic or paper) and cover EVERYTHING perfectly. Jam tape all the way down into seams between speaker covers and leather. Get it PERFECT so the leather is completely covered but flat and smooth, so that plastic is completely uncovered. It IS possible and not difficult. It just takes care and patience.
- completely remove OEM finish. Start with careful use of 400 grit sandpaper - the grit is necessary to bite into the paint. Then use 800 grit to finish the paint removal and smooth the surface. Remove ALL paint. Finally use 1000 or 1200 grit to polish the plastic. Get the surface perfectly smooth.
- use Krylon flat black spray paint. It is a nearly 100% perfect match for OEM. It may not seem like it but I promise it is. I tried several other types.
- spray the plastic using a VERY light coat of paint. Move fairly quickly and very evenly. The first coat will not and should not cover the surface completely. Let it dry for an hour; warm sunlight is a big help. Be sure to use quick light sprays from different angles.
- spray another light coat in the same manner.
- spray a third coat the same way.
- at this point the plastic, once dried, will/should look great and exactly like OEM.
- the next day remove tape and plastic masking VERY carefully. I used a dental pick, small needle-nosed pliers, hobby knife, etc. to nibble at tape that was at bottom where leather meets speaker cover and bottom pocket.
It will work great. Two things:
- inspect the first (especially) and second spray coats in great detail. If they are not perfect simply sand and start over. Additional coats will accentuate flaws, not diminish them.
- if you have any overspray on leather it can be 90% remedies with VERY CAREFUL use of acetone, Q-Tips and even a touch or two of a very sharp knife. Hopefully that won't be necessary as the acetone will start to remove the OEM leather finish pretty quickly.
Now that I've figured it out and done it, I'd have no hesitation in workng it again. It's quite doable - and done properly it's probably better and more durable than OEM.
Good luck.
Jump to top hlmiii is offline   Reply With Quote
Old Mon, Jul-16-2018, 02:42:09 PM   #25
I M Legend
Good luck.
Do you have any pics?
Old Mon, Jul-16-2018, 10:05:28 PM   #26
BearDeXPS
BearDeXPS's Avatar
Had the same... my buddy used some SEM product on mine and it looks perfectly OE. Glad I didn't take the risk on something foolish.
Cost me $30 and an import.
Old Mon, Jul-16-2018, 10:12:05 PM   #27
Rickyrosh
Reputation: 0 Rickyrosh is on a distinguished road
SEM product? Did you mean OEM?
Jump to top Rickyrosh is offline   Reply With Quote
Old Mon, Jul-16-2018, 10:16:15 PM   #28
BearDeXPS
BearDeXPS's Avatar
No. I meant SEM https://www.semproducts.com/
I'd link my journal here but photobucket
Here's a link from my journal on m3cutters... 3yrs ago and it still looks perfect.
http://forums.m3cutters.co.uk/showpo...0&postcount=83
Old Tue, Jul-17-2018, 02:23:32 AM   #29
Rickyrosh
Thanks! Got any latest pics of the work?
Old Tue, Jul-17-2018, 08:40:44 PM   #30
albino09
A Yankee South of the Mason-Dixon
I've tried both scotch pad removal, on my '99 323i of the center console, and plasti-dip on the center console pocket door. If done properly, the scuff pad looks the most consistent. The plasti-dip was close but not a perfect match.
I would just buy new pieces or try removing everything, sanding down and repainting in SEM trim black paint. Then it all looks the same and should be more durable.
1997 318i Silver/Black...Daily
Discussing Peeling/sticky interior rubber coating annoyance in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
